aprazer
Posted: Sat Jul 27, 2013 9:17 am Post subject: Loctite |
Greetings from Idaho
I'm presently working on a couple of service bulletins and they are calling for the use of Loctite 620 and Loctite 7471. Neither of these products are available from your normal automotive stores, i.e., NAPA.
I finally found them (at) Granger.
For the smaller containers, shipping, etc., the total came to $110.00.
Pete (at) Jabiru USA is not available as he is in Oshkosh - so do any of you know what Jabiru recommends as a replacement?
Mack
601XLB
3300
_________________ The poh-oh-unemployed farm boy from Idaho |
Ray Henrie
Joined: 11 Feb 2012 Posts: 4 Location: Beech Bluff, TN
Posted: Sun Jul 28, 2013 4:39 am Post subject: Re: Loctite |
I recently rebuilt an engine and Pete had no recommended substitutions. I got them from a local industrial supply, but as you found out they were quite expensive. Wait until you buy new rubber T's...!!!
aprazer
Posted: Sun Jul 28, 2013 2:45 pm Post subject: Re: Loctite |
Thanks for your input.
It was recommended that I check Amazon - which I did and was able to order both products for under $40.00, including shipping.
I'm not looking forward to purchasing anything more for that engine, any time soon!
Thanks again,
Mack
pete(at)usjabiru.com Guest
Posted: Tue Aug 06, 2013 11:47 am Post subject: Loctite |
The Loctite is not that expensive. A small tube of 620 is about $2.00 from
Jabiru USA and less than that from McMaster.com. The small tube will
usually be enough for completing one engine. The primer 7471 is $18 for
enough to complete several engines.
Pete
jlcrowder(at)gmail.com Guest
Posted: Tue Aug 06, 2013 4:56 pm Post subject: Loctite |
Pete,
There was talk of a change in where Jabiru was asking for the 620 to be
used. Is it still required on the through bolt nuts and on the flywheel
attach bolts?
Thanks, Jim Crowder
aprazer
Posted: Wed Aug 07, 2013 8:22 am Post subject: Re: Loctite |
Thanks Pete.
I now know where to look in the future.
Hope you had a successful week at Oshkosh!
Mack
