roger(at)trevannan.wanado Guest
Posted: Sun Jul 21, 2013 12:42 pm Post subject: outrigger wheels |
Hi
I have an early classic Europa , the outrigger wheels have now given up the ghost. I am sorry I know this has all been discussed before but can anybody let me know where I can get some new ones?
Roger GBWIJ
spcialeffects
Posted: Sun Jul 21, 2013 1:00 pm Post subject: Re: outrigger wheels |
Also are they available in different colours other then blue i.e orange?
pete(at)lawless.info Guest
Posted: Sun Jul 21, 2013 1:50 pm Post subject: outrigger wheels |
Evening Roger
This is an extract from an email from the late William Mills giving a source
of an alternative supply. The email is dated May 2007 so phone numbers and
names may not work. I saved it for future use, but now mainly flying off
grass find my outrigger wear is minimal.
"Whilst on the outrigger subject, I have found a source of much better
outrigger wheels with proper sealed bearings and shielded hubs. They are
obtained from: MSA Wheels and Castors Ltd, 10 Maclure Road,
Rochdale, Lancs., UK.
The spec is: 170299 EP100 Wheel + 8 mm Bush. The bush was inserted as a
special order for me, to suit the existing outrigger bolt, so please make
reference to the Europa aircraft outrigger wheel.
If 'phoning the number is + 44(0)1706 516640 and ask for Neal and mention my
name and the wheel's purpose. He knows all about it.
You will have to make up two pairs of aluminium spacers about 3/16" thick to
accommodate the narrower hub. (the rubber tyre is the same width as the
blue ones) I made mine out of 8mm drilled 1/2" dia. solid aluminium bar."
Pete
Fred Klein
Posted: Sun Jul 21, 2013 3:46 pm Post subject: outrigger wheels |
On Jul 21, 2013, at 1:42 PM, trevannan wrote:
| Quote: | Hi
Roger GBWIJ
A while back I did some back of the envelope computations and as I recall I figured that on touch down we are asking our outrigger wheels to spin up from zero to 5000 rpm in an instant.
I can't vouch for the math today, but decided at the time that it was worth my time to investigate a bit and discovered the world of precision bearings...I now have some 100mm wheels with ABEX #9 bearings purchased at a inline skate shop...still building, so no direct experience.
I had originally substituted sealed roller bearing wheels for those which were supplied w/ the kit; however, I had second thoughts about using them after seeing the identical wheel on supermarket carts...in this use, they are rarely subject to extreme accelleration.
These wheels w/ the ABEX #9 bearing spin up like there's no tomorrow.
Fred
A194
richard collings
Joined: 08 Jul 2011 Posts: 73 Location: warwickshire england
Posted: Mon Jul 22, 2013 2:26 am Post subject: outrigger wheels |
Hi Roger
I have a pair of outrigger wheel along with a lot of other Mono parts not
used on my Tri-gear. The deal is half list price. Let me know if you would
like them
Regards Richard
Europa Tri-gear, 912ul Woodcomp prop
Aircraft flying well, Pilot getting better.
