Go Pro mounts
Strasnuts
PostPosted: Tue Jul 16, 2013 3:45 pm    Post subject: Go Pro mounts Reply with quote
I have some mounts for sale at PlaneAround that screw into any tie down ring on RV's. It has worked well for under the tail or wings and filming video. I recently made another mount which uses the tie down mount but is made to mount on the wingtip. I know it fits an RV-10 and RV6 and it should fit all the RV's and actually a lot of other aircraft. I test flew it today and dove over 200mph to make sure the side load wouldn't distort the skin. It doesn't. I pointed it at a 45 degree angle thinking this would produce the strongest side load at 200 mph. No problem for the mount. It has a rubber bottom so it won't scratch the paint and is made out of aluminum. Just looking to see if others are interested to see how many I should start with. I still have the fuel cap mount but thought the wingtip would be more popular. They can be pointed any direction.
 Filesize:  104.05 KB
 Viewed:  4067 Time(s)
 Filesize:  119.99 KB
 Filesize:  100.06 KB
 Filesize:  82.92 KB
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
Strasnuts
PostPosted: Wed Jul 17, 2013 6:25 am    Post subject: Re: Go Pro mounts Reply with quote
My website is updated to show the wingtip mount and the tie down mount sold separately or together.
780 Hours
SuperSTOL 60 hours
