tonyrenshaw268(at)gmail.c Guest
Posted: Wed Jul 10, 2013 11:59 pm Post subject: Rogue Hole in FL16 |
The hole n the square end are supposed to be to suit the brackets from the cross tube. So, it's a rogue hole, and if it came from Europa, as I imagine it must of as a fast build kit, with the bearing possibly pre installed as well, get a new one. I don't think you can use it due to the proximity of the wrong hole, compromising the bracket.
I undid my temporary setup and now will use some sort of nylon to avoid the friction scored marks in my setup.
Hope this he's.
Tony Renshaw
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2013-07-10&Archive=Europa
________________________________ Message 2 _____________________________________
Time: 11:51:53 AM PST US
Subject: Any idea what hole in FL-16 Flap Hing Arm is for?
Hi Group
Anyone have any idea why both of my FL-16 Flap Hinge Arms have a hole on the square
end?:
https://skydrive.live.com/redir?resid=550FC20DBDDB521D!1655&authkey=!AF7B8FVUzjNaSt8
Thx.
Ron Parigoris
http://forums.matronics.com/viewtopic.php?p=404403#404403
________________________________ Message 3 _____________________________________
Time: 12:01:08 PM PST US
Subject: Foot well got burned!
Hi Group
I accidentally burned my starboard foot-well!
I replaced my lanterns alkaline battery (EverReady) ~ Christmas 2010. It hasn't
seen any use since then.
I sit down in front of my Europa XS Mono to study the undercarriage mounting frame,
need some light. No problem, I grab my lantern that I always store with the
lens up (in case it is left on), turn it on and use it for 5 or so minutes
90.18 KB |
1919 Time(s) |
pete(at)lawless.info Guest
Posted: Thu Jul 11, 2013 12:52 am Post subject: Rogue Hole in FL16 |
Morning Tony
Why not use some proper jointing compound between the parts. It will also
prevent corrosion. I was given a tin of a yellow paste by my original
inspector. I have just had a look in the garage to see if I could find the
name but I think the tin has been passed on to another builder.
Pete
Posted: Thu Jul 11, 2013 1:18 am Post subject: Rogue Hole in FL16 |
Pete
it's called Duralac. Should always be used when bolting things together. As you say it
inhibits corrosion between dissimilar metals. That should have been in the manual but I never saw it.
Graham
Sent: Thursday, 11 July 2013, 9:51
Subject: RE: Rogue Hole in FL16
--> Europa-List message posted by: "Pete Lawless" <pete(at)lawless.info (pete(at)lawless.info)>
Morning Tony
Pete
Posted: Thu Jul 11, 2013 2:05 am Post subject: Rogue Hole in FL16 |
That’s the stuff Graham. Certainly anytime I have disassembled anything the mating surfaces have always been in good condition.
Pete
