berkut13(at)berkut13.com Guest
Posted: Thu Jul 04, 2013 9:53 am Post subject: Narco Transponder Tray Coax Connector |
Can someone point me to the part number/source for a replacement 90-degree,
bulkhead, slide-on, coax connector used on the Narco AT-150 transponder
tray? Any of the usual suspects (Mouser, Digi-Key, Allied, etc) carry
them?
James
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
douglist(at)macnauchtan.c Guest
Posted: Thu Jul 04, 2013 10:43 am Post subject: Narco Transponder Tray Coax Connector |
At 12:52 -0500 7/4/13, <berkut13(at)berkut13.com> wrote:
Can someone point me to the part number/source for a replacement 90-degree, bulkhead, slide-on, coax connector used on the Narco AT-150 transponder tray? Any of the usual suspects (Mouser, Digi-Key, Allied, etc) carry them?
<http://www.brackemfg.com> Bracke Manufacturing, LLC CC.
sales(at)brackemfg.com
<http://www.pasternack.com> Pasternaclk Enterprises, Inc CA
techsupport(at)pasternack.com
Both of those keep sending me catalogs but I have never bought anything. Prices are way up in the sky and they seem to want to know how many thousands you want.
The Digi-key web site tells all. Mouser is catching up rapidly.
I may have a used Narco tray here. Offline to dmcnutt AT same domain with Narco in the subject.
Is that transponder still legal? There were some problems with it two decades ago.
--> The best programming tool is a soldering iron <--
Kellym
Posted: Thu Jul 04, 2013 1:08 pm Post subject: Narco Transponder Tray Coax Connector |
Single AD to comply with a Narco service bulletin back in 2004 with
regard to responses to mode S interrogation. Only applies to a certain
serial number range.
Any Narco transponder from AT-50 up through AT165 use same tray and
pinout. So even if one specific unit is bad, there are plenty of good
ones in service to get a replacement.
On 7/4/2013 11:42 AM, Doug McNutt wrote:
Checked by AVG - www.avg.com
KCHD |
john(at)carpenteravionics Guest
Posted: Thu Jul 04, 2013 1:19 pm Post subject: Narco Transponder Tray Coax Connector |
If you are referring to the tray mounted coax connector which is typically a
TED brand connector like is used on most tray mount avionics of that
generation, you can probably use the Deklin DBA-600. It mounts to the tray
the same way (cir-clip) but has a BNC on the other end so you don't have to
try to solder the coax on which is a challenge.
Best regards,
John DenDekker
www.carpenteravionics.com
800.300.0352 Toll Free
615.355.9970 office
NOTICE: This electronic transmission (including any referenced or attached
materials) is covered by the Electronic Communications Privacy Act, 18
U.S.C. Sec. 2510-2521, and is PRIVILEGED, WORK PRODUCT, PROPRIETARY and/or
CONFIDENTIAL. It is not intended for transmission to, or receipt by, any
unauthorized person. If you have received this transmission in error you are
PROHIBITED from disclosing, disseminating, reproducing, using or relying
upon it. Please immediately delete it from your system without copying and
notify the sender by return e-mail of the erroneous receipt. Thank you.
