Posted: Wed Jul 03, 2013 9:53 am Post subject: Dawn to Dusk Challenge |
I am planning an attack on the all time distance record
for the D2D Challenge on Sunday if the weather turns out
as good as currently forecast. It stands at 2500nm
currently, and I calculate that a figure of 8 round UK,
Hebrides Orkney & Shetland mainlands and Ireland will do
the trick! It will need rather a long time in the air
averaging 150kts, but if the weather Gods smile and the
donkey keeps going it might just be possible. Plan to fly
it atFL95 apart from the lower level bit round SE England.
Regards, David Joyce G-XSDJ (mono 914 Woodcomp
SR3000W + purpose built, LAA approved 100litre long range
tank)
PS the 3 planes at the top of the distance record list
are:
1 Beech Baron;
2. Mooney;
3. Hawk Jet!!
max8992
Posted: Wed Jul 03, 2013 10:38 am Post subject: Dawn to Dusk Challenge |
Hi David,
May the weather Gods and saint-Rotax be with you but I'm sure all the Europa
fellows will!
Max Cointe
mcointe(at)free.fr
F-PMLH Europa XS_TriGear
Kit #560-2003 912ULS/AirmasterAP332 450 hours
F-PLDJ Dyn’Aéro MCR 4S
Kit #27-2002 912ULSFR/MTProp MTV7A 1550 heures
-----Message d'origine-----
De : owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] De la part de David Joyce
Envoyé : mercredi 3 juillet 2013 19:53
À : europa list
Objet : Dawn to Dusk Challenge
--> <davidjoyce(at)doctors.org.uk>
I am planning an attack on the all time distance record for the D2D
Challenge on Sunday if the weather turns out as good as currently forecast.
It stands at 2500nm currently, and I calculate that a figure of 8 round UK,
Hebrides Orkney & Shetland mainlands and Ireland will do the trick! It will
need rather a long time in the air averaging 150kts, but if the weather Gods
smile and the donkey keeps going it might just be possible. Plan to fly it
Regards, David Joyce G-XSDJ (mono 914 Woodcomp SR3000W + purpose built,
LAA approved 100litre long range tank)
_________________ Max8992
Europa XS #560 F-PMLH |
ivanshaw(at)btinternet.co Guest
Posted: Wed Jul 03, 2013 1:03 pm Post subject: Dawn to Dusk Challenge |
David,
Good luck and following winds.
Ivan
Sent from my iPad
On 3 Jul 2013, at 18:52, "David Joyce" <davidjoyce(at)doctors.org.uk> wrote:
I am planning an attack on the all time distance record for the D2D Challenge on Sunday if the weather turns out as good as currently forecast. It stands at 2500nm currently, and I calculate that a figure of 8 round UK, Hebrides Orkney & Shetland mainlands and Ireland will do the trick! It will need rather a long time in the air averaging 150kts, but if the weather Gods smile and the donkey keeps going it might just be possible. Plan to fly it atFL95 apart from the lower level bit round SE England.
Regards, David Joyce G-XSDJ (mono 914 Woodcomp SR3000W + purpose built, LAA approved 100litre long range tank)
PS the 3 planes at the top of the distance record list are:
1 Beech Baron;
2. Mooney;
3. Hawk Jet!!
