Metals used in Aircraft Engines
galinhdz(at)gmail.com
PostPosted: Sun Jun 16, 2013 7:01 pm    Post subject: Metals used in Aircraft Engines Reply with quote
I found this document that has metals commonly used in aircraft piston engines. It is good information to have to augment an engine oil analysis program.
Metals_in_Aircraft_Engines.pdf
 Filename:  Metals_in_Aircraft_Engines.pdf
 Filesize:  96.84 KB
 Downloaded:  253 Time(s)
