barryjedwards(at)btintern Guest
Posted: Thu Jun 20, 2013 12:50 am Post subject: Pulsar-List: Tailwheel replacement |
Hi Scott, if you carefully mount the wheel in lathe you should be able to bore out the hub to allow it to take suitable bearings. Bore all the way through and fit a spacer between the bearings. Did mine like this 20 years ago and been great ever since.
Barry
G-XPXP
Sent from my HTC Raspberry Device
----- Reply message -----
From: "Scott - Special Effects Armourer" <scott(at)s-f-x.com>
To: "pulsar-list(at)matronics.com" <pulsar-list(at)matronics.com>
Subject: Pulsar-List: Tailwheel replacement
Date: Thu, Jun 20, 2013 08:37
Hello - does anyone know where I can source a replacement for my tailwheel as the bearings have failed and a new set will be a loose fit in the recess.
Hoping to find a new wheel. 5 inch dia. 1.5 inch width. Half inch spindle.
Scott MacIntyre
