jconnell(at)fmwildblue.co Guest
Posted: Mon Jun 24, 2013 7:47 am Post subject: Subject: RotaxEngines-List: ground wire |
Hi,
My 582 brown wire is grounded to the engine. The ground wire from the Key West regulator is grounded to the frame. The engine is grounded to the frame with a braided strap – it needs to be heavy to handle the load when the starter is engaged. A lot of guys bring everything to a common ground on the aircraft. I did this in my RV-9A. See attached pictures for RV common ground and 582 ground strap.
All the best...
Joe
Time: 11:24:01 PM PST US
From: TURBO T <turbot(at)shaw.ca (turbot(at)shaw.ca)>
Where should the brown ground wire on a 532 be attached to ?
To airframe & engine block ?
Am in process of installing a Key West regulator that has a 12Volt DC plug that
is labeled to ground.
It should probably go to frame & block also, But would it be a good idea to connect
it to the brown engine wire also ?
597.39 KB |
1909 Time(s) |
386.55 KB |
1909 Time(s) |
