Old kit new problems
rvsimons
PostPosted: Wed Jun 19, 2013 8:43 pm    Post subject: Old kit new problems Reply with quote
I bought a older 701 kit last year which the previous owner bought most of the SP upgrades to turn it from a 950 gross weight to an 1100 gross weight plane. I have been upgrading the wing spars by installing the heavier plate where the struts mount and installed the doubler at the spar roots. The plans called for a heavier wing attachment bracket (1/8 to 3/16). I bought the material only to find that my old cabin receiver will not except the 3/16 metal thickness. The old cabin was made with slots to take 1/8 only. My question is can make my wing attachment brackets out of 1/8 4130 instead of using the old 1/8 6061. I feel this will strengthen the wing attachment without having to rebuild the slots in the cabin. Thoughts?
Thank you
Vance Simons
Post Falls ID.
Vance Simons
Post Falls, Idaho
Zenith 701
n801bh(at)netzero.com
PostPosted: Thu Jun 20, 2013 5:07 am    Post subject: Old kit new problems Reply with quote
Personally I would say yes.....
Ben Haas
N801BH
www.haaspowerair.com
john.marzulli(at)gmail.co
PostPosted: Thu Jun 20, 2013 5:36 am    Post subject: Old kit new problems Reply with quote
Have you called Zenith about it? They must have supported retro fits when they upgraded to the SP airframe.
John Marzulli
http://MarzulliPhoto.net/
http://701Builder.blogspot.com/
On Thu, Jun 20, 2013 at 6:04 AM, Ben <n801bh(at)netzero.com (n801bh(at)netzero.com)> wrote:
Ben Haas
N801BH
rvsimons
PostPosted: Thu Jun 20, 2013 5:39 am    Post subject: Old kit new problems Reply with quote
I'm calling them this morning. On Jun 20, 2013 6:37 AM, "John Marzulli" <john.marzulli(at)gmail.com (john.marzulli(at)gmail.com)> wrote:[quote] Have you called Zenith about it? They must have supported retro fits when they upgraded to the SP airframe.
John Marzulli
Ben Haas
N801BH
Vance Simons
Post Falls, Idaho
Zenith 701
dougsnash
I tend to agree with Ben but would suggest a call to Zenith to get Caleb's opinion.
Doug M
CH-701 from scratch
NW Ontario, Canada
Sent: Thursday, June 20, 2013 8:04:42 AM
Subject: Re: Zenith701801-List: Old kit new problems
Ben Haas
N801BH
rvsimons
PostPosted: Thu Jun 20, 2013 9:51 am    Post subject: Re: Old kit new problems Reply with quote
Update. So I called and spoke with Caleb this morning. He said my cabin was made out of mild steel and since 2000 they were made of 4130. I told him I thought it was made out of 4130. When I asked about changing the spar attachment to 1/8th 4130 instead of using the 6061 1/8th inch so I would not have to cut up my cabin he said he didn't have an answer for me and honestly was to busy to get one but if I would email him the question again he could look into it in two weeks... Confused After talking to him I ran home and looked at my cabin. Sure enough it was made out of 4130 as it was printed right on the tubing. So my plan now is to talk to my EAA advisor and make the new attachments out of 1/8th 4130. 4130 has a tensile strength of 97 psi where 6061 is rated at 45 psi. I strongly believe using the 1/8th 4130 verses the 6061 will more than compensate for the strength difference between the 1/8th and the 3/16th 6061 material thickness change. A little discouraged but pressing on.
Vance Simons
Post Falls, ID.
Vance Simons
Post Falls, Idaho
Zenith 701
rvsimons
PostPosted: Fri Jun 21, 2013 7:27 am    Post subject: Re: Old kit new problems Reply with quote
Here are the new mounts I built last night out of 1/8th inch 4130 chrome moly.
 Filesize:  1.57 MB
 Viewed:  11768 Time(s)
Vance Simons
Post Falls, Idaho
Zenith 701
