Posted: Sun Jun 16, 2013 11:57 am Post subject: Fwd: RE: Routing electrical conduit |
I ran my conduit straight forward like picture #8 on both sides (step
drill works nice here) and made a side panel cover out of some thin
aluminum I had laying around. Some PEM nuts/screws hold the side panel
on. I don't use the long angled piece at all.
Linn
The attached photos are the only ones I can find that have more detail. The
conduit ends after it goes forward through the side rib lighting holes (the
ones where I installed the large grommets). Forward of that the runs just
use snap bushings like Van's has in his plans. I think I had to add one
additional hole on one side.
Note - there is no way to get all the wires and such past the panel bulkhead
just using the left side (with the supplied cover plate) per the planes. I
ran a 1" or so wire bundle up the inside of the last right side rib then
past the panel bulkhead in the side channel. I slightly enlarged the panel
notch that straddles the side channel for added clearance. I used some
plastic mesh conduit for this run. Most of it is hidden behind the little
side cover plate (photos #8 & #9).
Carl
253.72 KB |
2233 Time(s) |
300.26 KB |
2233 Time(s) |
300.59 KB |
2233 Time(s) |
296.76 KB |
2233 Time(s) |
johngoodman
Posted: Mon Jun 17, 2013 5:56 am Post subject: Re: Fwd: RE: Routing electrical conduit |
Why is this a separate thread?
