mbanus(at)hotmail.com Guest
Posted: Thu Jun 13, 2013 3:38 am Post subject: Hanger Antenna |
Bob,
I was wondering if there is an antenna type that I can install on the exterior of my hanger and wire it into the hanger that will provide signal to my FM music radio TV, and VHF handheld. I presently have antennas for each internally mounted inside the hanger. They work fine until I close the hanger door. If the outside hanger antenna had a “repeater” inside I think it would work. Is there such a device? I want to minimize the number of holes I put in the hanger wall.
TNX
Mark Banus
Posted: Thu Jun 13, 2013 4:43 am Post subject: Hanger Antenna |
At 06:38 AM 6/13/2013, you wrote:
| Quote: | Bob,
outside hanger antenna had a "repeater" inside I think it would
TNX
Mark Banus
I presume you're willing to use only one service
at a time. I.e. you don't need to watch tv and
listen to the hand-held at the same time.
There are some effective, broadband antennas most
notable of which is called the 'discone'. One
example is offered here
http://tinyurl.com/54fk
You can build these things pretty easily. It just
depends on how much your time is worth. If you're
inclined to hammer one out yourself, consider
http://tinyurl.com/kc9ruge
The discone is not an efficient antenna but it's
performance over a broad range of frequencies is
the selling point. If your TV/FM/VHF signals are
not 'fringe' levels, the discone is a good option.
rv8iator(at)gmail.com Guest
Posted: Thu Jun 13, 2013 5:18 am Post subject: Hanger Antenna |
Mark...
Jim Weir at RST Engineering has a dipole base station kit that works very well for FM radio and VHF com. You can build it to whatever center frequency suits you, typically 108-130 Mhz. I have built a couple and they work very well. They do require a lead-in of 50 ohm coax. from there you can use a splitter for VHF com radio and FM radio (use a balun to connect coax to twin-lead).
TV is another antenna as the VHF channels are centered around 75 Mhz.
http://www.rst-engr.com/rst/catalog/base_station_antenna.html
Chris Stone
RV-8
Newberg, OR
| Quote: | Bob,
I was wondering if there is an antenna type that I can install on the exterior of my hanger and wire it into the hanger that will provide signal to my FM music radio TV, and VHF handheld. I presently have antennas for each internally mounted inside the hanger. They work fine until I close the hanger door. If the outside hanger antenna had a "repeater" inside I think it would work. Is there such a device? I want to minimize the number of holes I put in the hanger wall.
TNX
Mark Banus
jay(at)horriblehyde.com Guest
Posted: Thu Jun 13, 2013 5:30 am Post subject: Hanger Antenna |
Wow- that practical antenna design document contains a wealth of
information; thanks for the link Bob.
Johannesburg Jay
Posted: Thu Jun 13, 2013 6:54 am Post subject: Hanger Antenna |
At 08:18 AM 6/13/2013, you wrote:
| Quote: | Mark...
and VHF com. Â You can build it to whatever
Mhz. Â I have built a couple and they work very
coax. Â from there you can use a splitter for
The off-air VHF tv channels run 59 to 88 Mhz for ch 2-6
and then skip over the fm broadcast, vhf aviation, ham
radio and pubic service frequencies to pick up at 175-
216 Mhz for ch 7-13. The dipole Jim describes is probably
no less efficient at the extremes of your range of
interest than the discone.
billp(at)wwpc.com Guest
Posted: Thu Jun 13, 2013 7:02 am Post subject: Hanger Antenna |
But since the digital TV conversion, most of the TV channels are now on UHF (even if they show up as "Channel 2" on your set) you need some antenna elements in the 500-800 MHz range too. At least in the Seattle/Tacoma area there are only 2 VHF TV signals left even though we have stations 2, 4, 5, 7, 9, 13 (plus a bunch of UHF).
Bill
On 6/13/13 6:18 AM, Christopher Cee Stone wrote:
[quote]Mark...
Chris Stone
RV-8
Newberg, OR
| Quote: | Bob,
TNX
Mark Banus
| [b]
Posted: Thu Jun 13, 2013 10:27 am Post subject: Hanger Antenna |
At 10:02 AM 6/13/2013, you wrote:
| Quote: | But since the digital TV conversion, most of the TV channels are now on UHF (even if they show up as "Channel 2" on your set) you need some antenna elements in the 500-800 MHz range too. At least in the Seattle/Tacoma area there are only 2 VHF TV signals left even though we have stations 2, 4, 5, 7, 9, 13 (plus a bunch of UHF).
Bill |
Interesting. I'd not kept up with those changes.
In that case, I think the discone cut for a lower
frequency on the order of 75 MHz is called for.
That would capture the FM and aviation frequencies
with some efficiency with pretty decent coverage
in the upper reaches.
Bob . . . [quote][b]
Posted: Thu Jun 13, 2013 10:34 am Post subject: Hanger Antenna |
Plan C . . .
As long as you don't want to use the antenna
for talking with your hand held, there's another
option for a broad spectrum receive only antenna.
http://tinyurl.com/kex8u4k
Posted: Fri Jun 14, 2013 10:19 am Post subject: Hanger Antenna |
At 06:50 AM 6/14/2013, you wrote:
| Quote: | Thanks All,
I think I will build a discone centered on 75MHZ. If that doesn't
work I'll try one of the commercial units. Just have to have music
while I work
Mark
Not 'centered' but cut so that lower edge is at 75 . . . or even
90 Mhz.
See:
http://www.changpuak.ch/electronics/calc_11.php
This is still a pretty big antenna . . . 'legs'
of cone nearly a meter long. Actually, if you
shoot for 91 Mhz, the legs come out exactly
3' long . . . which may be the handly stocking
length for brass or aluminum tube from the store.
Posted: Sat Jun 15, 2013 3:47 am Post subject: Hanger Antenna |
You are right. 3' is a little large. I am trying to be discrete.
Mark
Posted: Sat Jun 15, 2013 4:42 am Post subject: Hanger Antenna |
At 06:42 AM 6/15/2013, you wrote:
Mark
If the 'full size' discone is not an option,
consider the active antenna I linked earlier
This antenna is a simple whisker on a box similar
to a car antenna.
ralphmariafinch(at)gmail. Guest
Posted: Sat Jun 15, 2013 6:08 am Post subject: Hanger Antenna |
BTW, Radio Shack carries a discone antenna:
http://www.radioshack.com/product/index.jsp?productId=2103160
Many years ago I put this up on our house for 2m ham radio operations and it worked well.
On Sat, Jun 15, 2013 at 5:42 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Mark
to a car antenna.
http://forums.matronics.com
le, List Admin.
Posted: Sun Jun 16, 2013 4:19 am Post subject: Hanger Antenna |
Yes, the Ramsey AA7C looks as inconspicuous as I could get. I'll order one and give it an OPEVAL. Thanks
Mark
Posted: Sun Jun 16, 2013 7:21 am Post subject: Hanger Antenna |
At 07:18 AM 6/16/2013, you wrote:
| Quote: | Yes, the Ramsey AA7C looks as inconspicuous as I could get. I'll order one and give it an OPEVAL. Thanks
Mark
Okay. Some further considerations for the utility of
this product. It will come as a kit so assembly required.
It's designed to offer GAIN which may not be useful in
your situation.
Your task is to get energy from a short whisker antenna
(e-field probe) coupled into a low impedance feedline.
I suspect that signal strengths OUTSIDE your hangar are
adequate so adding gain brings some risks for overload
from local strong signals. Is there a tower or unicom
station on the field?
The kit is for an INDOOR accessory designed to sit
on a desk. It's BATTERY powered and designed to be
locally controlled by means of front panel switches
and knobs.
http://tinyurl.com/lrrylbk
Mounting this outside calls for hardening against
the elements. Sealed plastic or aluminum box?
The kit version has both HF and VHF/UHF capability
and all you need is VHF/UHF. Further, the ECB is
rather BIG for the small amount of electronics you
want to exploit. Here's Van Roon's schematic
trimmed down for VHF/UHF remote mounting.
[img]cid:.0[/img]
It looks like you could move R5, R4, C4, C5 and
C6 to the other end of the coax feedline. This would let
you run 9v up to the amplifier on the same coax that
brings the signals down.
This circuit could be built on a very tiny board to be
mounting inside a die-cast aluminum enclosure possibly
sealed with RTV.
There's only three components in the box on the roof.
The 2SC2570 is a leaded plastic device
The transistor, resistor and capacitor could probably
be 'spider webbed' between two BNC connectors in the
roof mounted box.
65.65 KB |
7710 Time(s) |
handainc(at)madisoncounty Guest
Posted: Sun Jun 16, 2013 7:48 am Post subject: Hanger Antenna |
Bob, -
I am interested in this antenna too, but need the HF as one of my available stations is an HF signal. Can the antenna be mounted outside and enclosure remain inside?
M. Haught
On Jun 16, 2013, at 10:19 AM, Robert L. Nuckolls, III wrote:
Mark
your situation.
and knobs.
<181d66a.jpg>
sealed with RTV.
roof mounted box.
Posted: Sun Jun 16, 2013 9:16 am Post subject: Hanger Antenna |
At 10:47 AM 6/16/2013, you wrote:
| Quote: | Bob, -
M. Haught |
Sure. There are lots of HF active antenna products
and DIY designs out there. Are you looking to build
or buy one? What's your range of interest for frequencies?
What is the nature of the proposed outside antenna
and feedline?
Posted: Sun Jun 16, 2013 9:36 am Post subject: Hanger Antenna |
I do not know even enough to talk intelligently about the subject! I would like a single antenna to where I can improve TV reception, FM radio reception, and use as a receiver antenna for my hand held aircraft radio. Only receive, not transmit.
I have a "wiring closet" with the hangar wall immediate to that location. I would run the coax out an up the wall to the antenna mounted at the edge of the roof, right straight up from the wiring closet, and house the enclosure in that closet. Was looking at the Ramsey AA&C for that purpose, but with an externally mounted antenna. Or is there a better alternative? Oh, I live in a 60 x 60 metal hangar, and reception inside is pretty poor.
M. Haught
On Jun 16, 2013, at 12:16 PM, Robert L. Nuckolls, III wrote:
| Quote: | At 10:47 AM 6/16/2013, you wrote:
| Quote: | Bob, -
M. Haught |
and feedline?
Bob . . . | Quote: |
Posted: Sun Jun 16, 2013 10:09 am Post subject: Hanger Antenna |
When had a Port-A-Port hangar in Oakland, CA I had a similar problem. These are T hangars and the corrugated roof has about a 4" overhang on the back edge. I punched a hole for a whip I cut to the aircraft band for the scanner I used to listen to ATIS and Tower frequencies and punched another hole and mounted a car radio antenna for everything else. Since the holes were in the overhang area there was never a problem with leaks. The coaxial from the antennas I just brought in at a high spot in the corrugations. If you're in a metropolitan area this should work. If you're out in the countryside somewhere, you'll need a TV antenna pointed toward where the TV transmitters are.
If you send me your airport ICAO code I'll tell you what you need and where to point the antennas.
Bill Putney
Navion owner
A&P/IA
WB6RFW
Chief Engineer - KPTZ FM
Port Townsend, WA
On 6/16/13 10:36 AM, H. Marvin Haught wrote:
[quote]I do not know even enough to talk intelligently about the subject! I would like a single antenna to where I can improve TV reception, FM radio reception, and use as a receiver antenna for my hand held aircraft radio. Only receive, not transmit.
M. Haught
| Quote: | Bob, -
M. Haught |
and feedline?
| [b]
Posted: Sun Jun 16, 2013 10:16 am Post subject: Hanger Antenna |
On my hangar in Oakland I installed a screwdriver antenna (the one I had was from in the middle of the roof and ran the coax and control wire down to the edge and under the High Sierra one I bought at HRO but they're all about the same. Worked well with my ICOM IC-706.
Bill Putney
On 6/16/13 10:16 AM, Robert L. Nuckolls, III wrote:
[quote] At 10:47 AM 6/16/2013, you wrote:
| Quote: | Bob, -
M. Haught |
and feedline?
Bob . . . [b]
