scc_ron(at)yahoo.com Guest
Posted: Mon Jun 12, 2006 6:52 am Post subject: GPS antenna firewall quick disconnect |
Does anyone know how to properly make up a disconnect at the firewall for my GPS antenna?
I have mounted the antenna for my Garmin 396 under the engine cowling. What I don't know is how to splice into the antenna wire and make up a proper firewall quick connect/disconnect that will enable me to take off the cowl without fishing the antenna wire through the firewall every time.
Is it OK to splice the antenna wire? how? which connectors do I use?
Appreciate your ideas.
Ron
Posted: Mon Jun 12, 2006 7:18 am Post subject: GPS antenna firewall quick disconnect |
I did this with mine....got a bulkhead connector from Digi-key and a standard BNC end and built it up.
Works fine - I'll look for pictures and part numbers.......
[quote]--
markacarey(at)msn.com Guest
Posted: Mon Jun 12, 2006 8:39 am Post subject: GPS antenna firewall quick disconnect |
I placed my antenna in the baggage compartment with the thought that the
signal could transmit through the cabin since it is non-metallic. I bought
an extra length of cable in lieu of trying to make one up due to the
intricacy of the connections.
[quote]From: "Ralph E. Capen" <recapen(at)earthlink.net>
Reply-To: aeroelectric-list(at)matronics.com
Subject: Re: GPS antenna firewall quick disconnect
Date: Mon, 12 Jun 2006 11:17:21 -0400 (GMT-04:00)
nuckollsr(at)cox.net Guest
Posted: Mon Jun 12, 2006 5:07 pm Post subject: GPS antenna firewall quick disconnect |
At 09:36 AM 6/12/2006 -0700, you wrote:
bought an extra length of cable in lieu of trying to make one up due to
the intricacy of the connections.
B&C also stocks the needed parts at:
http://bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?23X358218#s605bf
< with experiment. >
< --Lawrence M. Krauss >
