bob88
Posted: Fri May 31, 2013 6:04 pm Post subject: Floscan location and Matronics fuel line pulsation damper |
I'm trying to decide whether to place the floscan in the tunnel (standard location) vs engine compartment. Anyone have strong opinion? What about experience with the Matronics pulsation damper which seems like it would solve the problems the tunnel location has?
rv10flyer(at)live.com Guest
Posted: Fri May 31, 2013 6:58 pm Post subject: Floscan location and Matronics fuel line pulsation damper |
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=99641917?KEYS=pulsation_damper?LISTNAME=RV10?HITNUMBER=1?SERIAL=1955173315?SHOWBUTTONS=YES
Have mine in the tunnel. I had a low fuel pressure warning twice- it was
0ver 85F on a climb, otherwise never had any issue with it's accuracy.
Many will tell you to move it to the firewall, Dynon, for one, tells the
installers not to, and all I can think is that it would be even hotter there
than in the tunnel.
