GBWFH2010
Posted: Wed May 22, 2013 10:16 am Post subject: Airmaster AC200 Feather light on during flight |
When flying today the Airmaster propeller appeared to function perfectly, however every so often at seemingly random intervals the green FEATHER lamp would light for one or two seconds and then extinguish. The propeller did not attempt to feather but it is somewhat disconcerting to see this illuminated.
What I did notice was a very slight flickering of all the instrument needles. Could this be coincidence or is this linked to the spurious prop indication? I have checked all the earthing on the aircraft and could not find any obvious fault.
Does anyone have any suggestions regarding what could be causing this problem and what I should check?
_________________ Gordon Grant
G-BWFH |
ward.t(at)xtra.co.nz Guest
Posted: Wed May 22, 2013 11:50 am Post subject: Airmaster AC200 Feather light on during flight |
Hi Gordon,
If the prop is operating within its optimum range than the feather green light should definitely not be flickering on.
The other flickering lights indicate which way the propeller is adjusting to fine the best pitch to optimize the performance. Green light is the prop is going to a finer pitch and the yellow light means it is trying to find a coarser pitch.
Martin at Airmaster will be able to help. Contact him via the Airmaster web site.
Maybe a connection problem. Does the RPM change with the feather light on? If not then it is an indication problem.
Cheers,
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
On 23/05/2013, at 6:16 AM, "GBWFH2010" <gaxuk2001(at)gmail.com> wrote:
Gordon Grant
G-BWFH
http://forums.matronics.com/viewtopic.php?p=401126#401126
max8992
Posted: Wed May 22, 2013 11:19 pm Post subject: Airmaster AC200 Feather light on during flight |
Hi there,
To me this is normal as the controller tries permanently to adjust the pitch
and lights just indicate the way it moves. At least it's how our's works!
You can also refer to the user's guide or contact your local Airmaster rep.
Cheers,
Max Cointe
mcointe(at)free.fr
F-PMLH Europa XS_TriGear
Kit #560-2003 912ULS/AirmasterAP332 450 hours
F-PLDJ Dyn’Aéro MCR 4S
Kit #27-2002 912ULSFR/MTProp MTV7A 1550 heures
-----Message d'origine-----
De : owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] De la part de Tim Ward
Envoyé : mercredi 22 mai 2013 21:49
À : europa-list(at)matronics.com
Objet : Re: Airmaster AC200 Feather light on during flight
Hi Gordon,
coarser pitch.
site.
Cheers,
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
illuminated.
_________________ Max8992
Europa XS #560 F-PMLH |
GBWFH2010
Posted: Thu May 23, 2013 3:21 am Post subject: Re: Airmaster AC200 Feather light on during flight |
Thank you for you replies. Just to confirm the FINE/COARSE green/amber indicators seem to be working correctly as the propeller adjusts in flight.
I have been in contact with Martin at Airmaster and he has suggested cleaning the slip rings and checking the brushes, which has been done recently but I will do again. Also, he suggested it could be a faulty feather microswitch and I have some additional tests to perform.
It could well be the controller is misinterpreting the signals, but this will be more difficult to prove. Of course there could well be an underlying electrical problem (I have a Rotax 912 UL), but I can't find anything obvious.
G-BWFH |
GBWFH2010
Posted: Wed May 29, 2013 8:37 am Post subject: Re: Airmaster AC200 Feather light on during flight |
I think I have solved the problem. Despite having removed the brushes and cleaned the slip ring once, I decided to do the whole operation again. What I found was the inner ring brush had a very sticky spring and was sometimes getting stuck at the mid-way point, thus making intermittent contact with the ring. (When I removed the brushes the first time everything appeared fine so I missed the problem.) It is possible the vibration caused by the landing run and stopping the engine might have been enough to cause the brush to contact the inner ring as all ground feathering tests were fine.
A short test flight showed the propeller and all light indications to be functioning perfectly with not a hint of the FEATHER light illuminating!
G-BWFH |
Posted: Thu May 30, 2013 12:45 pm Post subject: Airmaster AC200 Feather light on during flight |
Gordon,
Well done. Good to know for future reference.
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
On 30/05/2013, at 12:37 AM, "GBWFH2010" <gaxuk2001(at)gmail.com> wrote:
Gordon Grant
G-BWFH
http://forums.matronics.com/viewtopic.php?p=401522#401522
budyerly(at)msn.com Guest
Posted: Fri May 31, 2013 2:09 pm Post subject: Airmaster AC200 Feather light on during flight |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Gordon,
Sorry to here of your lost time with the Airmaster.
Please note that when inspecting the brushes, it has come to my attention that the braded copper wire has to be twisted nearly to the point of making a curl. Once nice and tightly wound, it stays inside the spring and is trouble free.
If the braded copper is not wound tightly, it tends to bend under spring compression and get caught in the spring, partially jamming the brush. Normally this is fairly close to brush replacement time. Should the copper lead get caught in the spring wire gaps, this makes the brush hang up and eventually loose contact as it wears. I have even seen one where the spring cut the braded copper. Either way the prop control stops working properly shortly thereafter until the brush is changed. I have never had problems with carbon dust in the brush guide, but that too has been a reason for sticky brushes.
I'm afraid I have seen the wire jam up the works twice now and it really has nothing to do with your operations. The Airmaster manual is clear on how to wind the copper braid, but I am afraid, we don't all wind the copper the same.
On annual inspections I tend to take my brush block off and check my brushes carefully. Any sticking and I am into it, cleaning and inspecting. But I am anal like that.
Best Regards,
Bud Yerly
US Airmaster Distributor.
GBWFH2010
Posted: Sat Jun 01, 2013 4:41 am Post subject: Re: Airmaster AC200 Feather light on during flight |
Bud,
Thank you for your very informative comments. I have cured the problem short term but you have given me some excellent pointers regarding removing the root cause. I will have the block off again and check the wiring.
G-BWFH |
