Kelly McMullen
Posted: Sun May 26, 2013 1:05 pm Post subject: Spinner Size |
I'm about to order my prop. Is there any reason to go with anything other than stock 13" with the stock cowling?
- sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
cooprv7(at)yahoo.com Guest
Posted: Sun May 26, 2013 1:20 pm Post subject: Spinner Size |
Stock works great on mine.
Marcus
On May 26, 2013, at 5:04 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
robin(at)PaintTheWeb.com Guest
Posted: Sun May 26, 2013 1:45 pm Post subject: Spinner Size |
| Quote: | Ha! Probably the best choice is stock. I had a James Cowl disaster that is well documented. I switched over to the first production Showplanes cowl and have been very pleased. Perfect temps all the way around plus an induction system that is well designed and executed. The finish on the SP cowl is superior to any Vans fiberglass. But you will need a 15" spinner which is pricy.
In general plans built is best but I have yet to see a downside to the SP cowl. Very well designed, and produced.
Robin
Checked by AVG - www.avg.com
r>
Posted: Sun May 26, 2013 4:04 pm Post subject: Spinner Size |
Here is a source for the polished aluminum 14" Hartzell spinner, at a much reduced price, if you decide to do the James Cowl:
Chris Tieman
Mustang Aeronautics, Inc.
1470 Temple City
Troy, MI 48084
(248) 649-6818
www.MustangAero.com
Chris Tieman [Chris(at)MustangAero.com]
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Sunday, May 26, 2013 5:45 PM
To: rv10-list(at)matronics com
Subject: Re: Spinner Size
| Quote: | | Ha! Probably the best choice is stock. I had a James Cowl disaster that is well documented. I switched over to the first production Showplanes cowl and have been very pleased. Perfect temps all the way around plus an induction system that is well designed and executed. The finish on the SP cowl is superior to any Vans fiberglass. But you will need a 15" spinner which is pricy. In general plans built is best but I have yet to see a downside to the SP cowl. Very well designed, and produced. Robin Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote: |
| Quote: | | p://www.matronics.com/Navigator?RV10-ListIn general plans built is best but I have yet to see a downside to the SP cowl. Very well designed, and produced. | 0 | Quote: | | In general plans built is best but I have yet to see a downside to the SP cowl. Very well designed, and produced. | 1 | Quote: | | In general plans built is best but I have yet to see a downside to the SP cowl. Very well designed, and produced. | 2
r>
| Quote: | | In general plans built is best but I have yet to see a downside to the SP cowl. Very well designed, and produced. | 3 | Quote: | | In general plans built is best but I have yet to see a downside to the SP cowl. Very well designed, and produced. | 4 - List Contribution Web generous nbsp; --> http://www.matronics.com/c=[/b]In general plans built is best but I have yet to see a downside to the SP cowl. Very well designed, and produced. [/quote]5
Posted: Sun May 26, 2013 6:39 pm Post subject: Spinner Size |
| Quote: | I have one of those 14" plus another sitting on the shelf if interested.
Robin
Chris Tieman
1470 Temple City
Troy, MI 48084
(248) 649-6818
www.MustangAero.com
Carl
| Quote: | | Ha! Probably the best choice is stock. I had a James Cowl disaster that is well documented. I switched over to the first production Showplanes cowl and have been very pleased. Perfect temps all the way around plus an induction system that is well designed and executed. The finish on the SP cowl is superior to any Vans fiberglass. But you will need a 15" spinner which is pricy. | 0 | Quote: | | Ha! Probably the best choice is stock. I had a James Cowl disaster that is well documented. I switched over to the first production Showplanes cowl and have been very pleased. Perfect temps all the way around plus an induction system that is well designed and executed. The finish on the SP cowl is superior to any Vans fiberglass. But you will need a 15" spinner which is pricy. | 1 | Quote: | | Ha! Probably the best choice is stock. I had a James Cowl disaster that is well documented. I switched over to the first production Showplanes cowl and have been very pleased. Perfect temps all the way around plus an induction system that is well designed and executed. The finish on the SP cowl is superior to any Vans fiberglass. But you will need a 15" spinner which is pricy. | 2 | Quote: | | Ha! Probably the best choice is stock. I had a James Cowl disaster that is well documented. I switched over to the first production Showplanes cowl and have been very pleased. Perfect temps all the way around plus an induction system that is well designed and executed. The finish on the SP cowl is superior to any Vans fiberglass. But you will need a 15" spinner which is pricy. | 3
r>
| Quote: | | Ha! Probably the best choice is stock. I had a James Cowl disaster that is well documented. I switched over to the first production Showplanes cowl and have been very pleased. Perfect temps all the way around plus an induction system that is well designed and executed. The finish on the SP cowl is superior to any Vans fiberglass. But you will need a 15" spinner which is pricy. | 4 | Quote: | | Ha! Probably the best choice is stock. I had a James Cowl disaster that is well documented. I switched over to the first production Showplanes cowl and have been very pleased. Perfect temps all the way around plus an induction system that is well designed and executed. The finish on the SP cowl is superior to any Vans fiberglass. But you will need a 15" spinner which is pricy. | 5 http://forums.matronics.com - List Contribution Web generous nbsp; --> http://www.matronics.com/c= | Quote: | | Ha! Probably the best choice is stock. I had a James Cowl disaster that is well documented. I switched over to the first production Showplanes cowl and have been very pleased. Perfect temps all the way around plus an induction system that is well designed and executed. The finish on the SP cowl is superior to any Vans fiberglass. But you will need a 15" spinner which is pricy. | 6 | Quote: | | Ha! Probably the best choice is stock. I had a James Cowl disaster that is well documented. I switched over to the first production Showplanes cowl and have been very pleased. Perfect temps all the way around plus an induction system that is well designed and executed. The finish on the SP cowl is superior to any Vans fiberglass. But you will need a 15" spinner which is pricy. | 7
| Quote: | | Ha! Probably the best choice is stock. I had a James Cowl disaster that is well documented. I switched over to the first production Showplanes cowl and have been very pleased. Perfect temps all the way around plus an induction system that is well designed and executed. The finish on the SP cowl is superior to any Vans fiberglass. But you will need a 15" spinner which is pricy. | 8
r>
Kellym
Posted: Sun May 26, 2013 6:44 pm Post subject: Spinner Size |
Since I have been stuck at the 90/90 level for awhile, I am NOT looking
to do any more mods/expense, even though the Showplanes cowling looks
very nice.
So 13" it will be on stock cowl.
Robin
Chris Tieman
1470 Temple City
Troy, MI 48084
(248) 649-6818
www.MustangAero.com <http://www.MustangAero.com>
Carl
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Robin Marks
*Sent:* Sunday, May 26, 2013 5:45 PM
*To:* rv10-list(at)matronics com
*Subject:* Re: Spinner Size
Robin
*p://www.matronics.com/Navigator?RV10-List*
*ics.com*
*.matronics.com/contribution*
Checked by AVG - www.avg.com <http://www.avg.com>
r>
*&nbs====================http://www.matronic=================*
<http://www.matronics.com/contribution>
>http://www.matronics.com/Navigator?RV10-List* <http://www.matronics.com/contribution>*
ics.com
r>
KCHD |
