Tail Wheel Upgrade Video...
Site Admin
PostPosted: Mon May 27, 2013 8:47 am    Post subject: Tail Wheel Upgrade Video... Reply with quote
Dear Listers,
I upgraded the tail wheel assembly on The Flyer last weekend and installed a new spring, fork, wheel, control arm, and upgraded to a single spring push rod, replacing the original dual springs and chains. The original tail wheel appeared to have been mis-drilled at a slight angle which caused the tire to wear at an angle which could have also been caused by the single arm/axle arrangement I suppose. In any case, steering The Flyer was somewhat of a suggestion rather than a positive decision so I decided to upgrade the whole thing. Once I got in and started looking at what I had to do, it became obvious that I was going to have to remove the horizontal and vertical stabilizers to be able to have the access I needed to drill the hole for the replacement tail spring. Nothing is easy, it seems. Anyway, the installation came out great, and I can't believe how much BETTER the plane steers with the semi-ridge control rod! Wow! Amazing. I also like the looks of the traditional Van's fork and the tail rides a little bit lower now giving the plane a bit more rake which I like too.
Here is a video I made of the installation. I used a mix of time-lapse stills from the hangar security cams along with some high resolution stills from my Nikon D300. The video was really more of an exercise in honing my Adobe Premier Pro video editing skills, but it came out pretty cool! Check it out!
Be sure to select a high-resolution such as 720p or 1080p and click the full-screen view to be able to see the detail in the time-lapse photos.
http://youtu.be/H-wHdtxNX_U
Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
Status: 150+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
Scot
PostPosted: Tue May 28, 2013 5:35 am    Post subject: Re: Tail Wheel Upgrade Video... Reply with quote
Nice video. I think I spent more time checking out your hanger. My t-hanger does not have the upgrades you have done to yours.
Scott
Site Admin
PostPosted: Tue May 28, 2013 9:40 am    Post subject: Re: Tail Wheel Upgrade Video... Reply with quote
Yeah, it's my little home away from home! Smile The only thing I wish it had was a heater and an air conditioner.
Matt
Scott
Michael Wynn
PostPosted: Tue May 28, 2013 11:02 am    Post subject: Tail Wheel Upgrade Video... Reply with quote
I'll second the air conditioner. Gets a little warm at LVK on summer afternoons. I bought an evaporative cooler that helps considerably.  Nice video.
Michael Wynn
In a message dated 5/28/2013 11:53:33 A.M. Pacific Daylight Time, dralle(at)matronics.com writes:
[img]res://C:\Program Files\Nuance\NaturallySpeaking10\Program\web_ie.dll/QMARK.GIF[/img][img]res://C:\Program Files\Nuance\NaturallySpeaking10\Program\web_ie.dll/ARROW.GIF[/img]--> RV-List message posted by: "Matt Dralle" <dralle(at)matronics.com>
Matt
Scott
http://forums.matronics.com/viewtopic.php?p=401486#401486
Michael Wynn
RV 8
San Ramon, CA
