john(at)fureychrysler.com Guest
Posted: Thu Jun 08, 2006 4:59 pm Post subject: FF Kit |
I'm building an RV7. Anyone have experience with the Firewall Forward kit from Van's, or is it better to piece meal?
John
dan(at)rvproject.com Guest
Posted: Thu Jun 08, 2006 7:57 pm Post subject: FF Kit |
If you're a first-time builder and you're going mostly "stock" in terms of your engine/carb/FI/induction/baffles/oil & fuel systems, the FWF kit will be of high value (convenience in terms of $time$ saved). What type of engine are you hanging?
The more you stray from Van's stock setups, the less useful the FWF kit will be imho. For example, if you were going with a Sam James cowl & plenum, the FWF kit wouldn't be a 100% perfect match for you.
Next time around, I will still probably order the FWF kit but I will most likely omit several items that I would customize.
I know this is kinda vague, but it really depends on your setup.
)_( Dan
RV-7 N714D (933 hours)
http://www.rvproject.com
lhelming(at)sigecom.net Guest
Posted: Fri Jun 09, 2006 3:21 am Post subject: FF Kit |
I am pretty much standard engine, cowling, and the FWF kit saved lots of time. There were some parts supplied I did not use but the convenience of having almost everything was nice. I am not an A&P with lots of spare parts laying around. I wanted parts that was the right part and the right size. The FWF kit worked very well with my TMX-O-360 engine installation. I am sure it would work well with a lycoming as well. Larry in Indiana
rv8striker(at)hotmail.com Guest
Posted: Fri Jun 09, 2006 4:23 am Post subject: FF Kit |
I did the FWF kit and I'd do it again. If you already have some of the parts that are included in the kit, Van's will custom tailor the kit to your needs. Just let them know what you do not need. They will send the rest and bill you accordingly.
Just my two cents worth.
Steve Struyk
RV-8, 50 hours.
Posted: Fri Jun 09, 2006 4:24 am Post subject: FF Kit |
Thanks Dan, I am going with the Sam James cowl and probably a TMX IO-360 (still looking for advice here) I have built 2 RV6A in the past. I am learning a lot from your web site.
John
Posted: Fri Jun 09, 2006 4:26 am Post subject: FF Kit |
Larry, I am leaning towards the TMX O or IO-360 and would appreciate any input.
John
Posted: Fri Jun 09, 2006 5:00 pm Post subject: FF Kit |
I have been happy at every step taken with Mattituck. I would buy another engine from them again but would consider others also. Things to change and at the time I bought mine, I felt it was the best value available. Mattituck has exceeded my expectations at every opportunity. Larry in Indiana
highflight1(at)gmail.com Guest
Posted: Sat Jun 10, 2006 4:33 pm Post subject: FF Kit |
John,
I bought the Mattituck TMX IO-360 w/AFP fuel injection plus two P-mags. My engine was built with the hollow crank in case I might later want to change to a CS prop, but I am going to install and fly with a Catto 3-blade FP.
Like you, I also had to do some head scratching about the FWF kit and what I came up with was that the best match for my engine was to get the FWF item #FF-7A O-360 FP.
However, I still made some changes of either straight deletions or exchanges as follows:
I deleted the gascolator (don't need it with the AFP-FI).
I deleted ALL the electrical harnesses and master relay and starter solenoid. (I'll get what I need elsewhere).
I deleted the throttle and mixture cables and bracket (I'm using a throttle quadrant from DJM).
I changed out the standard FWF 60a alternator for the new 60a alternator w/internal OV protection.
I deleted the standard oil cooler and instead bought the Stewart Warner replacement from Pacific.
I deleted the standard Vetterman exhaust and instead bought the same exhaust directly from Vetterman except with the mufflers.
You can obviously see that most of those changes were as per my personal preference as opposed to changes mandated by my engine installation. For the most part, I think if you just delete the gascolator, you might be able to use all the rest.
I am also using the Sam James Cowl and Plenum, so be aware that you need to ask Mattituck to get the special bracket from AFP that's made to fit with the Sam James Plenum.
I hope that gets you in the right direction.
Vern Wanzong
RV7-A
Houston, TX
On 6/9/06, John Furey <john(at)fureychrysler.com (john(at)fureychrysler.com)> wrote: | Quote: | Larry, I am leaning towards the TMX O or IO-360 and would appreciate any input.
John
michele.delsol(at)microsi Guest
Posted: Mon Jun 12, 2006 4:44 am Post subject: FF Kit |
Thanks for the info as I myself also ordered a TMX-IO360 – AL sump, PMags and Vans standard cow. As you did, I am going personal on all the electrical stuff; Mufflers – also via Vetterman direct. As for gascolators, I am putting a couple of Andairs at the wing roots.
Not sure about the cables and brackets – what would you recommend?
Oil cooler – same here – going SW from Pacific – great people to work with – good advice.
It seems that after removing the above, all that is left is all of the little items which a first time builder is sure not to have on hand, each of which will take tons of time to get.
Michele – RV8 Fuselage (France)
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Vern W.
Sent: dimanche 11 juin 2006 02:25
To: rv-list(at)matronics.com
Subject: Re: FF Kit
Importance: High
John,
Vern Wanzong
RV7-A
Houston, TX
John
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Mon Jun 12, 2006 9:57 am Post subject: FF Kit |
Aerosport Power installed the Airflow Performance fuel injection on a Superior IO-360-B1B (180 hp) engine for my RV-8A. I ordered the firewall forward kit from Vans. There were some duplications. I remember that the plate that attaches the filtered air box (F.A.B.) to the fuel meter box came from both AFP and Van’s, but I had to make a custom one anyway to move the F.A.B. about 3/8” to one side to center it in the bottom cowl scoop. This is the part that several have experienced cracks with, so I built it out of heavier aluminum than the original. It’s a simple flat oval, so it wasn’t difficult to make.
I have a couple of hoses left over that I didn’t need, and had to order two more that I didn’t get from either source. One is the 42” long ¼” firesleeved line that runs from the purge valve on the top of the engine back to the firewall. The other is the 3/8” firesleeved line with a 90 degree pipe bend on one end that runs from the firewall to the mechanical fuel pump. Mine will be 15” long. I ordered both from Airflow Performance last week and expect to get them today or tomorrow. I think the two hoses will cost just a little under $200.
I did install an Andair gascolator in the left wing root, although I now don’t think that was any improvement over the AFP fuel filter that I did not install. But all that bent tubing looks impressive.
Terry
RV-8A firewall forward almost done
Seattle
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Michèle Delsol
Sent: Monday, June 12, 2006 5:42 AM
Subject: RE: FF Kit
