Posted: Mon May 27, 2013 9:36 am Post subject: altimeter encoder problem |
Bud, Today I have finally got round to removing my panel
and tracing the wiring. I found a faulty connection in the
middle row of the multiple small pin connector to my Blue
Mountain EFIS, corresponding almost certainly to the A"
pin, which activates over 6000 ft (as predicted by Mike
Gregory). Having resoldered it everything now works
precisely up to 10,000 ft Many thanks for your input.
Regards, David
On Sun, 21 Apr 2013 16:11:50 -0400
"Bud Yerly" <budyerly(at)msn.com> wrote:
[quote] David,
Not that I am an expert on the 328, but we have a number
flying successfully. It is pretty much a plug and play
piece of equipment.
It sounds as if your altitude encoder is separate and
not part of an EFIS.
If it is encoding properly at low altitude or sea level,
but not at altitude, then your wiring is sound, it is the
encoder. You can use your Z component of your GPS to
verify that the rest of your static system is sound in
flight.
If the altitude encoding is in error as altitude
increases only, then it is in the encoder static pot
itself. However, to be safe, check your pitot tube for
the W34 black static port attached well and secure to the
lower pitot tube also. Any leak in the system
(especially in the wing) will cause errors with speed and
angle of attack. Of course if the W34 is missing, your
static system is hooked to a pitot source which is really
bad.
Ameriking encoders as well as ACK are quite reliable,
but if they fail, which it sounds as if it has an
internal static leak, you will need a proper pitot static
check by a qualified avionics shop to verify.
A crude check is to disconnect the static line from the
encoder and run it to a very light suction hand pump to
check pressure vs readout. Of course you will need the
temp and atmospheric tables also to establish the proper
QNH. For the very brave, only connect the altimeter and
encoder together with a static line and use a light duty
vacuum hand pump to increase the altitude and verify the
readout on the 328 display with the altimeter. If you
pull too much suction or leave the airspeed attached, you
will break costly equipment. So as you can see, it is
best to just go to an avionics shop and get a proper
checkout as they have the calibrated equipment to do the
job quickly and correctly... If you built your panel for
easy removal, your avionics shop will appreciate it.
Note to all, it is prudent to have the pitot static
system verified prior to first flight, and every two
years after that by a qualified avionics shop.
Altimeters, encoders, and EFIS systems do fail. It is
best to have them checked periodically. For years, I
have simply pulled one inch of vacuum on my static system
and checked the altimeter at 1000 feet increase, and the
airspeed increases to 135 KIAS, the Vertical Speed
Indicator is checked for rate of climb and the entire
system checked that it will hold for 60 seconds.
However, at altitude, our absolute indicators may have
small leaks and lie to us. I still do my 1000 foot check
just as a security blanket, but insist on a proper
certified pitot static check prior to first flight.
Best Regards,
Bud Yerly
Posted: Mon May 27, 2013 9:40 am Post subject: altimeter encoder problem |
Remi, Today I have taken off my panel and traced all the
wiring to find a faulty connection on the A2 wire coming
out of my EFIS. Now works perfectly up to 10,000ft tested.
thanks for your help. David
On Mon, 22 Apr 2013 04:43:12 -0700
"Remi Guerner" <air.guerner(at)orange.fr> wrote:
Hi David,
I propose to share with you my personal experience on
that subject :
My aircraft was originally fitted with a Garmin GTX320
and a Terra AT3000 encoder. After a few years flying, I
started to experience altitude reporting problems. ATC
was occasionally seeing me at 6000 ft or below ground
level while I was flying at 2000 ft AMSL. I was once
wrongly accused of having busted the class A London TMA
while I was flying well below the max allowed altitude.
Then I reworked the wiring without success, then I had
the encoder tested by an avionic shop and it was found to
be ok. Then I borowed another GTX 320 from a frend for a
few flights and the system was working ok. So the culprit
was clearly the transponder which was intermittently
reporting an altitude different from the one transmitted
by the encoder.
I have since installed a mode S GTX328, keeping the
Terra encoder and it has been working fine for the last
five years.
Conclusion : in most of the cases the culprit is the
altitude encoder but it could also be the transponder
itself.
I hope that helps.
Remi
F-PGKL
http://forums.matronics.com/viewtopic.php?p=399096#399096
Un/Subscription,
Forums!
Admin.
budyerly(at)msn.com Guest
Posted: Mon May 27, 2013 1:43 pm Post subject: altimeter encoder problem |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Way to go David.
Nine times out of ten, it is a bad ground or broken pin connection. It just takes time to troubleshoot.
Bud
Remi Guerner
Posted: Mon May 27, 2013 11:53 pm Post subject: Re: altimeter encoder problem |
Hi David,
Good to know you have solved the problem. Thank you for the update.
Remi
