Torque Wrench
pdelano(at)telus.net
PostPosted: Wed May 22, 2013 5:48 pm    Post subject: Torque Wrench Reply with quote
Hi all,
Any suggestions on a torque wrench for AN3 nuts/bolts. 20 in*lb range.
Also, there is a min. Edge distance, but is there also a minimum distance to a bend line.
Perry
Sent wirelessly from my BlackBerry device on the Bell network.
Envoyé sans fil par mon terminal mobile BlackBerry sur le réseau de Bell.
JohnDRead(at)aol.com
PostPosted: Wed May 22, 2013 6:40 pm    Post subject: Torque Wrench Reply with quote
Sears carries a suitable toque wrench.
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 5/22/2013 7:49:01 P.M. Mountain Daylight Time, pdelano(at)telus.net writes:
--> Zenith701801-List message posted by: pdelano(at)telus.net
Hi all,
Perry
Envoyé sans fil par mon terminal mobile BlackBerry sur le réseau de = Use ilities ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
infow(at)shaw.ca
PostPosted: Wed May 22, 2013 7:07 pm    Post subject: Torque Wrench Reply with quote
Princess Auto has 3/8", 1/2"... work ok and the price is right! I bought a 1/4" on ebay!
:--)> Hi all,
:--)> Any suggestions on a torque wrench for AN3 nuts/bolts. 20 in*lb range.
:--)> Also, there is a min. Edge distance, but is there also a minimum distance to a bend
:--)> line.
:--)> Regards,
:--)> Perry
:--)> Sent wirelessly from my BlackBerry device on the Bell network.
:--)> Envoyé sans fil par mon terminal mobile BlackBerry sur le réseau de Bell.
dougsnash
PostPosted: Thu May 23, 2013 6:59 am    Post subject: Torque Wrench Reply with quote
Perry, Princess auto has a very nice 1/4" drive vernier torque wrench for a reasonable price.
http://www.princessauto.com/pal/en/Torque-Wrenches/1-4-in-dr-Click-Type-Torque-Wrench/2922045.p
The problem with the vernier style torque wrench is you are supposed to calibrate them before using them in aviation.  The el-cheapo bending arm style wrench has the advantage of being cheaper than the vernier style and they do not need calibration. Unfortunately, Canadian Tire, Princess Auto nor Acklands list 1/4" inch lb beam type torque wrenches on their web sites.
As for the edge distance from a bend, it is generally the same as from the actual edge of the piece. Realistically, however, it is often difficult to maintain the edge distance from both a bend and an actual edge. If you have to choose which edge to cheat against, go with the bend as the material will be stronger.
Hope this helps
Doug M
NW Ontario, Canada
From: "pdelano(at)telus.net" <pdelano(at)telus.net>
To: Matronics <zenith701801-list(at)matronics.com>
Sent: Wednesday, May 22, 2013 8:48:40 PM
Subject: Torque Wrench
--> Zenith701801-List message posted by: pdelano(at)telus.net (pdelano(at)telus.net)
Hi all,
Perry
Envoyé sans fil par mon terminal mobile BlackBerry sur le réseau701801-List" target="_blank">http://www.matronics.com/Navigator?Zenith701801-Lista href="http://forums.matronics.com/" target="_blank">http://forums.mat &nbs//www.matronics.com/contribution" target="_blank">http://www.matronics.co==================
Terry Phillips
PostPosted: Thu May 23, 2013 10:10 am    Post subject: Torque Wrench Reply with quote
I have been well satisfied with the beam-type wrenches from Park. The TW-1 is sized for 0-60 in-lbs (fine for AN3's); the TW-2 is sized for 0-600 in-lbs. Not cheap, but good, see, e.g.,
http://www.amazon.com/s?ie=UTF8&keywords=torque%20wrench%20park%20tool&page=1&rh=i%3Aaps%2Ck%3Atorque%20wrench%20park%20tool
Terry
[img]cid:part1.06090800.09000507(at)gmail.com[/img]
Wednesday, May 22, 2013 7:48 PM
Hi all,
Perry
Terry Phillips
ttp444~at~gmail.com
Corvallis MT
ZU-601XLB/Jab 3300 s .. l .. o .. o .. o .. w build kit - Tail & flaps are done;
Upgrading wings & ailerons per the AMD Safety Directive
http://www.mykitlog.com/N47TP/
 Filesize:  770 Bytes
 Viewed:  12227 Time(s)
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
raymondj(at)frontiernet.n
PostPosted: Thu May 23, 2013 10:47 am    Post subject: Torque Wrench Reply with quote
Perry,
I'm building a 750.
I bought this one from this company.  I was very happy with the cost and their customer service.
I did have to buy a ratcheting device separately.
http://www.emaxaction.com/cdi3002ldin-1.aspx
Raymond Julian
Kettle River, MN.
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
Hi all,
Perry
PostPosted: Fri May 24, 2013 2:45 pm    Post subject: Torque Wrench Reply with quote
Hi Doug,
As always thanks for the help, we have a PA relatively close, I'll check it out.
WRT the edge distance I contacted Caleb at Zenith. He told me to look in the construction standards (cs)??? Didn't know what my problem was. Except for the blurb in the photo manual (circa 2004 paper) I had no idea what he was talking about. Turns out they published a more indepth cs in 2011 and it was on the cd of the const. Manual I bought about the same time. It shows the edge distance from a bend and a lot more stuff. If you want a copy I can email it to you.
Perry
PostPosted: Fri May 24, 2013 8:45 pm    Post subject: Torque Wrench Reply with quote
Hi Terry,
Thanks for the tip on the torque wrench. For the small torque I’m looking at the beam type from 0-60 inch*lb looks good and it would not take too much to calibrate it.
Perry
PostPosted: Fri May 24, 2013 8:55 pm    Post subject: Torque Wrench Reply with quote
Hi John,
Thanks for the tip on Sears. They do have a wide selection.
Perry
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of JohnDRead(at)aol.com
Sent: Wednesday, May 22, 2013 7:40 PM
Subject: Re: Torque Wrench
Regards, John
Cell: 719-494-4567
Home: 303-648-3261
