sigmatero(at)yahoo.com Guest
Posted: Fri May 17, 2013 7:42 pm Post subject: S700-2-10 master switch |
I have an Aeroelectric recommended electrical system for a Rotax 912S with a S700-2-10 master switch that has about 350 hours on it. I've recently been seeing the overvoltage protection light coming on periodically so today I went through the troubleshooting checklist for the Rotax alternator and regulator/rectifier. When I got to testing the master switch the OVP would kick on an off when the switch was pulled and wiggled so I'm pretty sure the switch is bad. Is that pretty common and should I be using another switch that's more robust? Or are there multiple manufacturers of this switch, some with better quality than others?
Posted: Sat May 18, 2013 5:53 am Post subject: S700-2-10 master switch |
At 10:40 PM 5/17/2013, you wrote:
| Quote: | | I have an Aeroelectric recommended electrical system for a Rotax 912S with a S700-2-10 master switch that has about 350 hours on it. I've recently been seeing the overvoltage protection light coming on periodically so today I went through the troubleshooting checklist for the Rotax alternator and regulator/rectifier. When I got to testing the master switch the OVP would kick on an off when the switch was pulled and wiggled so I'm pretty sure the switch is bad. Is that pretty common and should I be using another switch that's more robust? Or are there multiple manufacturers of this switch, some with better quality than others? |
When you say the ov protection light comes
on, is this the light associated with the
alternator disconnect relay in the B&C
PM alternator control kit?
The 2-10 switching protocol is offered by
many manufacturers. If you purchased the 2-10
from B&C, then it's a Carling with riveted
fast-on tabs. It may be that one of these
joints is loose. I'd like to have your failed
switch for analysis.
I'm forwarding a copy of this to B&C. I think
they'd be happy to send you a new switch if
you send the old one to me. We'd like to know
what's going on. Will report finding to the
List.
Give Greg a call at 316-283-8000. Send the
switch to Box 130, Medicine Lodge, KS 67104
Bob . . . [quote][b]
Posted: Sat May 18, 2013 12:27 pm Post subject: S700-2-10 master switch |
Thanks Bob. Yes, I have the disconnect relay kit.
I'll get a hold of Greg and then send you the switch after I swap it.
I must not have good luck with switches, the first ACS key switch I had was bad right out of the box. The replacement they sent was just fine.
To: aeroelectric-list(at)matronics.com; Greg Jones <greg(at)bandc.biz>
Sent: Saturday, May 18, 2013 6:51 AM
Subject: Re: S700-2-10 master switch
List.
n801bh(at)NetZero.com Guest
Posted: Sat May 18, 2013 2:42 pm Post subject: S700-2-10 master switch |
Ben Haas
N801BH
www.haaspowerair.com
