		ftyoder(at)yoderbuilt.com Guest
				 Posted: Sun May 12, 2013 1:10 pm    Post subject: 3300 carb heat |
				I recently purchased  an ELSA and it was never fitted with carburetor heat. Is this not necessary on  Jabiru engines? It seems they are always on Cont. & Lyc.  carburetor engines.
  Thanks,  Tim
  |  | - The Matronics JabiruEngine-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		zeprep251(at)aol.com Guest
				 Posted: Sun May 12, 2013 3:54 pm    Post subject: 3300 carb heat |
				Tim,
  My 2200 is on a Kolb MK3 above the wing pusher.Because it is un-cowled, it ices readily in humid cool conditions and is now equipped with an electric conductive heat element mounted on the carb body at the throttle shaft casting nord.If your installation allows warmed air from under the cowl to enter the intake it may be all you need,but the Bing ices.
    G.Aman
		jlcrowder(at)gmail.com Guest
				 Posted: Sun May 12, 2013 4:16 pm    Post subject: 3300 carb heat |
				Tim,
 What is “nord” ?  I am looking for a place to attach a temperature sensor.  This would seem to be the place.
 Jim Crowder
 From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Gary Aman
 Sent: Sunday, May 12, 2013 4:53 PM
 Subject: Re: 3300 carb heat
 Tim,
   G.Aman
				Thanks for the information Gary, Is the heat element available  from Jabiru, do you turn it on or is it on all the  time?
 Tim,
   G.Aman
  -----Original  Message-----
 To:  jabiruengine-list <jabiruengine-list(at)matronics.com>
 Sent: Sun, May 12,  2013 5:10 pm
 Subject: 3300 carb heat
  Thanks,  Tim
 tor?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List
 tp://forums.matronics.com
 bution">http://www.matronics.com/contribution
 href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List
		marvinlnaz(at)yahoo.com Guest
				 Posted: Sun May 12, 2013 4:32 pm    Post subject: 3300 carb heat |
				Marvin
 Sent from my "Geeky" iPhone
 On May 12, 2013, at 5:15 PM, "Tim Yoder" <ftyoder(at)yoderbuilt.com (ftyoder(at)yoderbuilt.com)> wrote:
 [quote]     Thanks for the information Gary, Is the heat element available  from Jabiru, do you turn it on or is it on all the  time?
    From:  owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com)  [mailto:owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com)] On Behalf Of Gary  Aman
 To:  jabiruengine-list(at)matronics.com (jabiruengine-list(at)matronics.com)
 Tim,
   G.Aman
 From: Tim Yoder <ftyoder(at)yoderbuilt.com (ftyoder(at)yoderbuilt.com)>
 To:  jabiruengine-list <jabiruengine-list(at)matronics.com (jabiruengine-list(at)matronics.com)>
  Thanks,  Tim
		djtoddb
				 Posted: Sun May 12, 2013 5:03 pm    Post subject: 3300 carb heat |
				Here's where to get the Carb heater
  http://motionaero.com/Products-DualHeat.html
 Todd Bristol
   Great Entertainment isn't expensive... It's Priceless!
   Interactive Entertainment Events, DJs and Game Shows
    Mesa, Arizona
   480-755-4200
   www.djs4u.com
 www.gameshowsamerica.com
 www.condopenasco.com
  Sent: Sunday, May 12, 2013  5:15 PM
  Subject: RE: 3300 carb heat
 Tim,
 Jim Crowder
 Tim,
  G.Aman
  _________________ Titan Tornado II with Jab 3300 |
		JohnDRead(at)aol.com Guest
				 Posted: Sun May 12, 2013 5:12 pm    Post subject: 3300 carb heat |
				The carb heat from Jabiru has two levels controlled by switches. Can recall  the cost as it was part of the FWF package with the engine.
  Regards,  John
 CH701 - Colorado - Jabiru 3300
 Cell: 719-494-4567
 Home:  303-648-3261
   In a message dated 5/12/2013 7:04:13 P.M. Mountain Daylight Time,  djtoddb(at)yahoo.com writes:
   	  | Quote: | 	 		        Here's where to get the Carb heater
       Todd Bristol
    Mesa, Arizona
    480-755-4200
    www.djs4u.com
                 Tim,
    Jim    Crowder
 Subject: Re: JabiruEngine-List: 3300    carb heat
    Tim,
   G.Aman
       Thanks,    Tim
 01234567890123
 5 |
		matronics(at)rtist.nl Guest
				 Posted: Sun May 12, 2013 9:54 pm    Post subject: 3300 carb heat |
				Just to be pedantic, there is no electric carb heat *from* Jabiru.     There are several 3rd party sources for electric carb heat *for*     Jabiru, or even more accurate, for Bing carburettors. MotionAero     being one of them.
      They all work on the same principle, a module with one or two heater     elements (big resistors) that gets attached to the opposite side of     the throttle lever. They usually generate between 30W and 70W of     heat and seem to work well to keep ice from forming in the venturi.
      Jabiru recommends an air filter box that can accept hot air as carb     heat, see their installation manual.
      Rob
      On 5/13/2013 3:12 AM, JohnDRead(at)aol.com (JohnDRead(at)aol.com)       wrote:
      [quote]                              The carb heat from Jabiru has two levels controlled by           switches. Can recall the cost as it was part of the FWF           package with the engine.
          Regards, John
              Cell: 719-494-4567
              Home: 303-648-3261
				 Posted: Mon May 13, 2013 4:22 am    Post subject: 3300 carb heat |
				Jim,
  I'll let you research the (nord).I have always considered it an un-machined out-cropping on a casting.As for the placement of that temperature sensor,that would depend on whether it is an oral or rectal model.Pun intended,have a good day James!
				 Posted: Mon May 13, 2013 4:29 am    Post subject: 3300 carb heat |
				Tim,
  It's switched on 2 levels.The one from Jabiru  is what I have but the link the guys provided to the after market one is where I would go.The price is similar but mine has failed already and the other type has got to be more rugged.
  G.A.
		zcrj90(at)yahoo.co.uk Guest
				 Posted: Mon May 13, 2013 7:55 am    Post subject: 3300 carb heat |
				In my experience Jab engines aren't prone to carby ice. I've don't think I've ever had it in the air in 1500 hrs of flying Jabs. I don't do regular 6 min carb heat checks though I do have a play with it now and again at the beginning of  a trip.
 I've never had carby ice on the ground but I know  of a two 3300's that have had it while taxiing out. Even one with the little electric thing bolted to the carby.
 My engine does get a bit of ice as every so often, how do I know?, it eats a small blob of water an tells me it has, then my alarm system says 'what was that' (my wife bless her). Or if I have the bowl off there's a little ball of water in the fuel sometimes. I think this comes from taxiing in and it melts after shut down.
 What would one do if one met those ideal conditions for carby ice  and your light bulb sized heater on the side of the carby can't cope, or it pops and you haven't checked it lately and you don't have that knob in the panel. At worse, land if you can, at best get a fright.
 Would I fly a Jab engine without a hot air carby heat?, nope,
 Regards, Clive
  Sent: Monday, 13 May 2013, 6:53
      Rob
          Regards, John
              Cell: 719-494-4567
              Home: 303-648-3261
        http://www.matronics.com/Navigator?Ja="_blank" href="http://forums.matronics.com/">http://forums.matronics.c-> [b]
				 Posted: Mon May 13, 2013 2:02 pm    Post subject: 3300 carb heat |
				Thanks to everyone for the helpful  input.....Tim
    From:  owner-jabiruengine-list-server(at)matronics.com  [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of  Clive
 Sent: Monday, May 13, 2013 8:54 AM
 Subject: Re: Re:  3300 carb heat
  Regards,  Clive
 Rob
    Regards, John
 Cell: 719-494-4567
 Home:    303-648-3261
				 Posted: Mon May 13, 2013 4:08 pm    Post subject: 3300 carb heat |
				Clive,
  My engine never shut down at cruise power settings,although it did get really rough as it ingested the ice chunks.If there is fog the elements are ripe for ice,but you can have ice at temps in the 60'sF if the humidity is high.The only time it might cause the engine to quit would probably be at reduced power settings and almost for sure at idle on decent.
  G.Aman
				 Posted: Mon May 13, 2013 11:19 pm    Post subject: 3300 carb heat |
				Thanks Gary, power to the argument for hot air carb heat.
 I forgot to mention I do use carb heat as I reduce power below 2000.
 I'd feel lost without it but as Gary's says and my experience is, ice forms best at low revs when there is the biggest pressure drop across the carby.
 Remembering of course, foggy mistys days are not necessarily the worst days for carb icing conditions. They are just when you think about it...
 As with all these things it's your plane and you can do what you like!
 Regards, Clive
  Sent: Tuesday, 14 May  2013, 1:08
 Clive,
  G.Aman
