Cylinder Head Service and Overhaul
Jabiruworkshop
PostPosted: Wed May 08, 2013 11:41 am    Post subject: Cylinder Head Service and Overhaul Reply with quote
Hi
I have just produced another e-manual ‘Cylinder Head Service and Overhaul’.
Apart from routine servicing, overhauling the cylinder head is probably one of the most common jobs undertaken on the Jabiru engine. Removing the head is a simple task but what is often missed are the clues as to what the problem is and why it occurred in the first place.
This e-manual has been published to provide a step-by-step pictorial guide to assist owners in servicing and overhauling Jabiru cylinder heads. It should be used in conjunction with the Jabiru Technical Manuals. Readers can also refer to my e-manual ‘Building the Jabiru Engine from the Crankshaft Up’ for more information on removing and re-installing the cylinder heads.
The manual costs £15 - and don't forget we can produce bespoke e-manuals for any specific jobs you wish to carry out on your engine.
You can find it on my website: http://www.jabiruworkshop.com/store/e-manuals/
Bespoke e-manuals can made up on request.
Roger
Preview Cylinder Head Service & Overhaul.pdf
Preview the contents and sample pages of the e-manual
 Filename:  Preview Cylinder Head Service & Overhaul.pdf
 Filesize:  1.88 MB
 Downloaded:  1043 Time(s)
