graybeard
Joined: 20 Sep 2011 Posts: 33 Location: Grants Pass, OR
Posted: Tue Apr 30, 2013 9:40 am Post subject: Filter-to-Pump Fuel Line |
I am looking for advice on the best way to bend this line. The instructions are not very helpful. At least I have only one line through the gear tower to bend as I am going with a carbureted engine. I have bent a practice line in two sections that meet inside the gear tower just to get the bends at each end right, but I don’t know how much this will help with the final line. I will leave it in place while I bend the brake line just to occupy the space. Bending and flaring this line looks near impossible to me at this point, but I know that cannot be the case. I am also not sure when the best time is to install the line. I may be premature. My fuselage is still wide open as I want to do as much as possible inside before I install the top skins. I will greatly appreciate all suggestions including any viable alternatives to in-place fabrication.
Stan Loer
RV-8 QB
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
N38CW
Joined: 16 Apr 2008 Posts: 57 Location: Winston-Salem, NC
Posted: Tue Apr 30, 2013 12:44 pm Post subject: Filter-to-Pump Fuel Line |
I tried this myself more than once. All my other fuel lines turned out really good except that one and the one from the Facet pump to the firewall. I finally decided there was no way I was going to be able to do a respectable job with them, so I went ahead and had Tom at TSFlightlines make a couple of braided lines for me. Turned out great. Now that they're installed, I've decided to go fuel injection instead. So now I get to redo them again.
Bill Settle
RV-8 Slow Build
To: rv8-list(at)matronics.com
Sent: Tue, April 30, 2013 1:42:09 PM
Subject: Filter-to-Pump Fuel Line
Stan Loer
RV-8 QB
| Quote: | http://www.matronics.com/con================
_________________ Bill Settle
RV-8 Fuselage |
