Cabin Door Locks
cv93436(at)windstream.net
PostPosted: Fri May 03, 2013 6:23 am    Post subject: Cabin Door Locks Reply with quote
Guys,
You can use your extra matched keyed lock sent with the kit (just like the baggage door lock) and install it in the left cabin door. Drill a hole through the Lexan and mount the lock so the lock bar is aligned with one of the geared sliding bars of the latch assembly. This will prevent the geared sliding bar from moving forward when someone tries to open the door. If you need, I have the dimensions for placing the lock, etc. Please feel free to email me your mailing address and I'll send you a sketch. This works very well and looks professional.
To lock the right hand cabin door, make a slide in the inside handle that slides a bar inside the handle to prevent someone from pushing the outside handle button to release the lock.
You'll have to use a little ingenuity to make it work.
Doc
RV-10 41087 N123CV
Bob Turner
PostPosted: Fri May 03, 2013 12:55 pm    Post subject: Re: Cabin Door Locks Reply with quote
For a slide inside the right door handle I just cut an L shaped piece of wood and sanded one arm to fit snugly. Because the wood has a small amount of give it won't fall out on its own.
If you are young and thin the cheapest locks are to make two of these, lock both doors, and climb out the baggage door!
Bob Turner
RV-10 QB
cooprv7(at)yahoo.com
PostPosted: Fri May 03, 2013 1:27 pm    Post subject: Cabin Door Locks Reply with quote
I have actually consider this option, sort of. My thought was to make a wedge to lock the right door as suggested, and then another on a telescoping rod that could reach the left door from the baggage door. The problem is it's not a straight shot due to the back seat and if the wedge became disconnected it might make for an interesting entry into the airplane.
Fun with experimentals!
Marcus
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=399914#399914
rv10flyer
PostPosted: Fri May 03, 2013 6:49 pm    Post subject: Re: Cabin Door Locks Reply with quote
I use a 1/4" wooden dowel. One piece about 2" long for copilot side and the other 36" for pilot side. Flatten one end with sander. With tow bar installed as my gust lock, seat forward to hold gust lock, lean seat back forward and install door lock by reaching over rear seat back. KISS.
Wayne G.
Greg McFarlane
PostPosted: Sat May 04, 2013 1:57 am    Post subject: Re: Cabin Door Locks Reply with quote
Hey Wayne, talkin about the KISS PRINCIPAL, how about doing a MR BEAN and just drill a hole through both doors to fit a piece of half inch water pipe, push one piece of pipe right through the cabin, then fit a PADLOCK on the pipe outside of each door! Pipe could double as a tow bar when not in use, and you wouldn't have to be POT BLACK champion to pot the wedge from the baggage compartment to unlock the door. Cheers from Western Auustralia.
Jim Berry
PostPosted: Wed May 08, 2013 10:53 am    Post subject: Re: Cabin Door Locks Reply with quote
Another way to make a lock for the right side door is to drill a 1/16" vertical hole through the push tab of the door handle. Buy a 1/16" stainless steel hairpin clip at HD; insert it through the hole. Done.
Jim Berry
RV-10
rv10flyer(at)live.com
PostPosted: Wed May 08, 2013 11:36 am    Post subject: Cabin Door Locks Reply with quote
not only done, but works well too!
aerosport1
PostPosted: Wed May 08, 2013 11:46 am    Post subject: Cabin Door Locks Reply with quote
I never found a lock that I really liked so I just take my door handles off
and put them in the baggage area.
If they want in that bad they are going to break something anyways.
(Stock door handles)
Geoff
Geoff Combs
Aerosport Modeling and Design
 Filesize:  354.96 KB
 Viewed:  10027 Time(s)
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
Strasnuts
PostPosted: Wed May 08, 2013 12:17 pm    Post subject: Cabin Door Locks Reply with quote
I do the same thing Geoff mentioned. I did this in Mexico and Bahamas.
Takes just as long to take them off as a lock would take.
On May 8, 2013, at 13:46, "Geoff Combs" <g.combs(at)aerosportmodeling.com> wrote:
[quote] I never found a lock that I really liked so I just take my door handles off
Geoff
Geoff Combs
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
PostPosted: Wed May 08, 2013 1:17 pm    Post subject: Cabin Door Locks Reply with quote
Easiest solution seen to date, thanks!
On May 8, 2013, at 3:46 PM, "Geoff Combs" <g.combs(at)aerosportmodeling.com> wrote:
Geoff
Geoff Combs
PostPosted: Wed May 08, 2013 1:21 pm    Post subject: Cabin Door Locks Reply with quote
Great idea, I just might use this or the wedge idea for the right door and remove the outside handle on the left. Thanks for all of the creative ideas on this thread.
Marcus
