vernon.franklin(at)gmail. Guest
Posted: Sat Apr 27, 2013 5:16 pm Post subject: Door Question |
I have started working on the doors.
I drilled the fwd and aft index holes as indicated on 45-02, but when I lay the door up, only the aft index hole matches. The forward hole is about 4 inches higher than when the fuselage "missing" rivet is.
Both doors are like this, with the fwd dimples about 4 inches higher than the plans show.
Has anyone else run into this issue?
Vernon Franklin
davidsoutpost(at)comcast. Guest
Posted: Sat Apr 27, 2013 7:01 pm Post subject: Door Question |
Mine were that way also. I made a rivet hole transfer tool to locate the empty dimpled rivet hole on the door. IIRC, Avery Tool carries these.
David Clifford
RV-10 Builder
Howell, MI
From: "Vernon Franklin" <vernon.franklin(at)gmail.com>
Sent: Saturday, April 27, 2013 9:15:32 PM
Subject: Door Question
Vernon Franklin
Bob Turner
Posted: Sat Apr 27, 2013 7:02 pm Post subject: Re: Door Question |
As I recall, the index holes on the inner and outer door halves did not all line up for me, either. The lines and scribe marks on my fiberglass parts were hard to impossible to see.
_________________ Bob Turner
RV-10 QB |
