Posted: Sun Jun 11, 2006 5:41 am Post subject: Antenna switchbox for handheld, was Antenna for hand-held tr |
Howdy Carlos and Dale-
RE:
| Quote: | I think I didn't quite understand your setup. Let me ask.
> I've got a permanently mounted socket / switch unit from iCom.
You mean a power socket, right?
Nope.
> The panel
> mount radio and antenna coax are permanently mounted to it, and I have
a
> length of feedline for the handheld that terminates in a plug. If I
should
> need the handheld, all I do is plug it's feedline into the socket.
The
> panel mount is disconnected from the antenna, and the handheld is now
on
> line. Very neat and simple. No making or breaking of BNC connex
while
> flying the plane.
You say "no making or breaking of BNC connex while flying the plane",
but you said " the panel mount (radio) is disconnected from the
antenna". Is it something like Bob has in the Aeroelectric connection, a
panel mounted antenna plug, or am I missing something?
The antenna switchbox is approximately 1" x 2" x 4". It is mounted to the
back side of any convenient sheet metal. It has a socket on it's mounting
face as well as 2 BNC connectors on it's rear side. One BNC is for the
external fixed com antenna and one for the com radio. There is a separate
feedline that attaches to the handheld radio. The free end of the feedline
is fitted with a plug. When you insert this plug into the antenna
switchbox socket, the antenna is disconnected from the panel mount com and
connected to the handheld com.
| Quote: | Is there a Icom part number for this socket/switch/feedline? Checked their
web site and found nothing like your description.
It is curious that it doesn't show up there, but you can see it on the
Pacific Coast web site at:
http://www.pacific-coast-avionics.com/detail.asp?id=4024
The part # is ANT-SB.
Hope this helps-
Glen Matejcek
aerobubba(at)earthlink.net
Posted: Mon Jun 12, 2006 8:42 am Post subject: Antenna switchbox for handheld, was Antenna for hand-held tr |
Robert shows how to build one of your own at:
| Quote: | > It is curious that it doesn't show up there, but you can see it on the
http://www.aeroelectric.com/articles/commtap/commtap.html
-- Craig
