robintaylor
Builder_Bill
Joined: 19 Sep 2012 Posts: 7 Location: Newport News, VA USA
Posted: Sat Apr 27, 2013 11:05 am Post subject: Re: Radio interference |
Hey Bob, if the noise gets worst at higher alt output, does that implicate a rectifier diode exclusively? I was trying to think if there was another source of noise that would follow the alt load.
Bill
robintaylor
Posted: Thu May 02, 2013 4:25 am Post subject: Re: Radio interference |
Thanks for the response Bob,
I had to wait until I flew again.
I am flying with twin Dynon Skyviews, as I turn each off, the noise progressively reduces.
The frequency of the noise increases with the speed of the engine.
I have a common ground on the firewall that everything is connected to.
Posted: Thu May 02, 2013 4:58 pm Post subject: Radio interference |
At 07:25 AM 5/2/2013, you wrote:
<robintaylor(at)airteccc.co.uk>
Hmmmm . . . Do the Dynon units have audio outputs
for annunciation/warning signals?
robintaylor
Posted: Thu May 02, 2013 9:46 pm Post subject: Re: Radio interference |
Yes, the Dynons do have an audio output.
Robin
Posted: Fri May 03, 2013 5:22 am Post subject: Radio interference |
At 12:46 AM 5/3/2013, you wrote:
Robin
Okay, the first experiment is to disconnect these
two signal sources and record the effect on the
noise.
robintaylor
Posted: Mon May 20, 2013 11:12 am Post subject: Re: Radio interference |
Hi Bob,
I have disconnected the audio output from the Skyviews and the noise goes away.
Robin
sttwig
Posted: Mon May 20, 2013 11:37 am Post subject: Radio interference |
Did you connect a ground wire to the case of the Skyview per their
instructions toward the bottom of page 4-17: To minimize the possibility
of audio “humming”, a 16 AWG wire may optionally be connected between
the ground point for the intercom/audio panel/radio(s) and SkyView
display case(s). To attach the wire to the SkyView display case, a 4-40
x 3/16” long screw maybe be screwed into the threaded boss above the USB
ports on the back of the SkyView display.
Steve
sprocket(at)vx-aviation.c Guest
Posted: Mon May 20, 2013 5:46 pm Post subject: Radio interference |
I found a great reduction in SkyView noise by disconnecting pin 30 totally.
Both my audio system and the SkyView power ground are connected to the same
point. Connecting pin 30 actually creates a ground loop in the system.
It's easy to try it as long as your audio cables are grounded to the
intercom end. Connecting the case to ground may make the problem worse,
depending on your wiring.
See details here: http://makerplane.org/forum/viewtopic.php?f=23&t=137
Thx,
Vern
robintaylor
Posted: Wed May 22, 2013 2:17 am Post subject: Re: Radio interference |
Thanks for the advice.
I haven't connected a ground to the Skyview case, I couldn't see it in my instructions.
My noise is not a hum, it is a distinct beep or pulse at a about two per second on tick over and increases in frequency with the rpm's.
I will disconnect the grounds from pin 30 and see if this has any effect.
I have spoken to Dynon and their view is that the problem is with the main ground to the engine either in size or quality. It is a 4g wire so it should be OK. I will check the terminals but I think they are OK.
Every ground in the plane goes back to a forest on the fire wall with the engine ground connected to the securing bolt for this.
Someone has suggested putting a condenser on the alternator output. Would this help.
