Updated Nose Wheel Assembly Information
galinhdz(at)gmail.com
PostPosted: Wed Apr 24, 2013 5:21 pm    Post subject: Updated Nose Wheel Assembly Information Reply with quote
Here is an updated nose wheel assembly information booklet. I replaced some photos with better ones and added missing information.
KIS_Nose_Wheel_Assembly_Details.pdf
 Filename:  KIS_Nose_Wheel_Assembly_Details.pdf
 Filesize:  1.33 MB
 Downloaded:  423 Time(s)
mark_trickel
PostPosted: Wed Apr 24, 2013 11:58 pm    Post subject: Re: Updated Nose Wheel Assembly Information Reply with quote
Galin,
Thank you for documenting the TR-4 nose gear with such detailed precision. I do not think the springs came from McMaster.com, I did a quick check there and they do not have a die spring listed with these dimensions. I will try looking elsewhere.
Mark T.
PostPosted: Sun Apr 28, 2013 7:21 pm    Post subject: Updated Nose Wheel Assembly Information Reply with quote
I updated the Nose Wheel Assembly information since it contained an error with the part number for the alternate rubber bushing. This version has the correct part number (90948-01003  GR4).
PostPosted: Sun Apr 28, 2013 7:26 pm    Post subject: Updated Nose Wheel Assembly Information Reply with quote
Oops. I re sent the wrong one. Here is the CORRECT version dated 4/28/2013.
On Sun, Apr 28, 2013 at 10:20 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
I updated the Nose Wheel Assembly information since it contained an error with the part number for the alternate rubber bushing. This version has the correct part number [url=tel:%2890948-01003](90948-01003[/url]  GR4).
et="_blank">http://www.matronics.com/Navigator?KIS-List
tp://forums.matronics.com
 Filesize:  1.44 MB
 Downloaded:  301 Time(s)
