Windshield seal
teamgrumman(at)yahoo.com
PostPosted: Wed Apr 24, 2013 9:17 am    Post subject: Windshield seal Reply with quote
Someone asked about sealing the windshield. Personally, I think the whole strip caulk thing is a dumb idea.
Using a canopy bow seal around the base of the windshield is a lot of work too, but, it won't leak. The only problem I've seen is the left side working its way up the window after a year or so. Weird.
PostPosted: Wed Apr 24, 2013 9:19 am    Post subject: Windshield seal Reply with quote
Once more with pics.
 Filesize:  2.07 MB
 Viewed:  3575 Time(s)
 Filesize:  1.99 MB
George(at)oilhelp.com
PostPosted: Thu Apr 25, 2013 4:53 am    Post subject: Windshield seal Reply with quote
Gary, are you using the black RTV that is used for the bow for the base of the w/s also? If so are you applying the bonding agent to the w/s like you do for the bow?
Best Regards,
George Douglas
Amsoil Distributor
office 407-856-1564
toll free 800-887-6698
cell 321-663-5391
www.oilhelp.com
From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of Gary L Vogt
Sent: Wednesday, April 24, 2013 1:18 PM
To: Teamgrumman List
Subject: Windshield seal
PostPosted: Thu Apr 25, 2013 10:20 am    Post subject: Windshield seal Reply with quote
I glue the canopy bow seal (it's the flat seal at the front of the canopy bow) to the bottom of the windshield with contact cement.
Sent: Thursday, April 25, 2013 5:53 AM
Subject: RE: Windshield seal
Best Regards,
George Douglas
Amsoil Distributor
office 407-856-1564
cell 321-663-5391
www.oilhelp.com
http://www.matronics.com/Navigator?TeamGrumman-Listw" target="_blank" href="http://www.matronics.com/contribution">http://=======================
george(at)oilhelp.com
PostPosted: Thu Apr 25, 2013 10:47 am    Post subject: Windshield seal Reply with quote
Ok I understand now. Don't you worry about the sun eventually destroying it?
Sent via BlackBerry by AT&T
PostPosted: Thu Apr 25, 2013 11:00 am    Post subject: Windshield seal Reply with quote
Hadn't thought about the sun. I've had mine in there for 8 years.
Sent: Thursday, April 25, 2013 11:42 AM
Subject: Re: TeamGrumman-List: Windshield seal
Ok I understand now. Don't you worry about the sun eventually destroying it?Sent via BlackBerry by AT&T
Sender: owner-teamgrumman-list-server(at)matronics.com
Date: Thu, 25 Apr 2013 11:20:15 -0700 (PDT)
To: teamgrumman-list(at)matronics.com<teamgrumman-list(at)matronics.com>
ReplyTo: teamgrumman-list(at)matronics.com
Subject: Re: Windshield seal
I glue the canopy b= ow seal (it's the flat seal at the front of the canopy bow) to the bottom o= f the windshield with contact cement.
Subject: RE: TeamGrumman-List: Windshie= ld seal
Gary, are= you using the black RTV that is used for the bow for the base of the w/s a= lso? If so are you applying the bonding agent to the w/s like you do for th= e bow?
Best Regards,
George Douglas
Amsoil Distributor
office = 407-856-1564
cell 321-663-5391 www.oilhelp.com
From: owner-teamgrumman-list-server(at)m= atronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Beh= alf Of Gary L Vogt
Sent: Wednesday, April 24, 2013 1:18 PM To: Teamgrumman List
Subject: Windshiel= d seal
Someone asked about sealing t= he windshield. Personally, I think the whole strip caulk thing is a d= umb idea.
Using a canopy bow seal around the base of the windshield is a lot of = work too, but, it won't leak. The only problem I've seen is the left side working its = way up the window after a year or so. Weird.
=0A=0A
http://www.matronics.com/Navigator?TeamGrumman-List=
w" target=3D"_blank" href=3D"http://www.matronics.com/contribution">http://=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=0A=0A=
</=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> http://www.matronics.com/Navigator?TeamG=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3DD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D [/b][b]
