deej(at)deej.net Guest
Posted: Tue Apr 23, 2013 6:06 am Post subject: What's the nose and main wheels required tire pressure? |
On my Glastar, the left main typically needs air every couple of months.
The right main typically needs air every 6-7 months. The nose wheel
only needs air about once per year.
Ironically, the left main is one of the special "leak guard" tubes,
whereas the right main is just a regular old cheap tube. Go figure.
I think it has more to do with the tube construction and valve seating
rather than what type of gas you put in.
-Dj
Dj Merrill - N1JOV - VP EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
