bob88
Posted: Fri Apr 26, 2013 6:39 am Post subject: Quickbuild sequence for RV10 |
Given limited space, I am wondering whether to order QB wings or finishing kit next. I have QB fuselage and engine, still working in garage. Any experience with doing the wings more or less last?
rleffler
Posted: Fri Apr 26, 2013 7:11 am Post subject: Quickbuild sequence for RV10 |
I don't know of anyone that's done that, but I don't see any issues off the top of my head.
The finish kit is going to take up a lot of space until you get everything mounted on the fuselage.
http://forums.matronics.com/viewtopic.php?p=399436#399436
_________________ Bob Leffler
N410BL - Phase I
Mike Whisky
Posted: Fri Apr 26, 2013 7:16 am Post subject: Re: Quickbuild sequence for RV10 |
I don't see a problem doing the wings last. All you need to care about is the wire 6 tube/hose length in case you plan to wire it through from your panel all the way to landing lights, nav/strobe lights, trim & A/P servo, heated pitot AOA, stall warning.
Mike
_________________ RV-10 builder (flying)
#511 |
mds4878
Jim Berry
Posted: Fri Apr 26, 2013 8:39 am Post subject: Re: Quickbuild sequence for RV10 |
It wont take you long to finish the QB wings. If you do them first, they will just be taking up a lot of room while you finish everything else. I would do them last if you are space limited.
Jim Berry
