woxofswa
Posted: Sat Apr 20, 2013 10:48 pm Post subject: "Matched" wings to spars |
In my building process I built the fuselage kit after the empennage kit by ordering the spar box kit with the fuse kit.
I later bought a QB wing kit from another builder.
There was concern expressed by some that I might have difficulties by not having the wing spar and spar box "matched" by serial number set.
Van's said it shouldn't be a problem even though they still recommend a matched set, so it always lingered in the back of my mind that I could get caught in a pickle. However, I am happy (and relieved) to report that at initial mating everything lined up perfectly.
At least with the 10, (and I assume beyond), the Van's fabrication process is so accurate that the venerable practice of matching the components is unnecessary.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
rv10flyer
Posted: Mon Apr 22, 2013 3:41 am Post subject: Re: "Matched" wings to spars |
Certain holes are oversized, different for each of us and noted on a form with the extra bolts. Did all hole diameters match on yours?
_________________ Wayne G. |
tsts4
Posted: Mon Apr 22, 2013 5:10 am Post subject: Re: "Matched" wings to spars |
| rv10flyer wrote: | | Certain holes are oversized, different for each of us and noted on a form with the extra bolts. Did all hole diameters match on yours? |
Just curious, but you're saying that some of the wing attach bolt holes were drilled oversized and annotated as such? I mated my wings a few weeks ago and don't recall anything anywhere indicating oversized holes. My wings were SB--is this a QB thing?
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
rv10flyer
Posted: Mon Apr 22, 2013 6:06 am Post subject: Re: "Matched" wings to spars |
No QB's on mine.
woxofswa
Posted: Mon Apr 22, 2013 9:09 am Post subject: Re: "Matched" wings to spars |
I can't imagine why any holes would be non-standard unless there was a flaw discovered that they re-drilled to salvage. I think that would definitely require paperwork and close scrutiny. Everything matched on mine except the serial numbers.
Mesa, AZ
Flew May 10 2014 |
