Aligning landing gear
Goto page 1, 2  Next
johngilpin
PostPosted: Sun Apr 21, 2013 1:31 am    Post subject: Aligning landing gear Reply with quote
Here's a means that we found for easily aligning the landing gear on a FireFly.
Pretty self-explanatory....
The hard-drawn copper pipe fits exactly through where the axles go.
JG
 Filesize:  66.4 KB
 Viewed:  15403 Time(s)
johngilpin
PostPosted: Mon Apr 22, 2013 12:19 am    Post subject: Aligning landing gear Reply with quote
I had attached a photo to that post, which shows up in my sent mail, but doesn't appear in the post for some reason????
Anyhow, it's just a matter of removing both axles, and sliding a length of 1/2" hard-drawn copper pipe through from one side to the other. There's enough flexibility in the pipe to handle the camber angles of the axles.  The pipe locks both gear legs to a straight ahead position, or by forcing the center of the pipe a bit back you can set for a slight toe-in, equal on both sides.
JG
Larlaeb
PostPosted: Mon Apr 22, 2013 5:58 am    Post subject: Re: Aligning landing gear Reply with quote
Picture came through fine for me.
zeprep251(at)aol.com
PostPosted: Tue Apr 23, 2013 4:25 pm    Post subject: Aligning landing gear Reply with quote
The picture showed up here JG.Easy way to do it except for the 200.00 dollars worth of copper tubing.
G.Aman
west1m
PostPosted: Mon Apr 21, 2014 7:58 pm    Post subject: Re: Aligning landing gear Reply with quote
I just purchased a used Firefly with some damage to the cage and fiberglass nosecone. What is the bar in the picture? Is that some kind of protection for the nose if it goes over? what is it attached to?
West1m
Hastings, MN
williamtsullivan(at)att.n
PostPosted: Tue Apr 22, 2014 2:57 am    Post subject: Aligning landing gear Reply with quote
There is no photo attached.
    Bill Sullivan
Sent: Monday, April 21, 2014 11:58 PM
Subject: Re: Aligning landing gear
--> Kolb-List message posted by: "west1m" <west1m(at)hotmail.com (west1m(at)hotmail.com)>
West1m
http://forums.matronics.com/viewtopic.php?p=422227#422========================http://www.matronics.com/Navigator?Kolb-Li> [quote][b]
Richard Pike
PostPosted: Tue Apr 22, 2014 6:27 am    Post subject: Re: Aligning landing gear Reply with quote
G.Aman
Right on. So go to Lowe's, buy a 5/8" grounding rod and use it, it's what I used on the MKIII years ago, since the MKIII has 5/8" axles, and I expect the FS does too. When you get done, take it back to Lowe's for a refund.
http://www.lowes.com/pd_70861-28781-70861_0__?productId=3446272&Ntt=grounding+rod&pl=1&currentURL=%3FNtt%3Dgrounding%2Brod&facetInfo=
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
lcottrell
PostPosted: Tue Apr 22, 2014 7:24 am    Post subject: Aligning landing gear Reply with quote
Shouldn't you at least pay them rent, or contribute to the coffee fund???????
Larry
On Tue, Apr 22, 2014 at 8:28 AM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
--> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Richard Pike
Kingsport, TN 3TN0
My soul shall be joyful in the LORD; It shall rejoice in His salvation. Psalm 35:9
http://forums.matronics.com/viewtopic.php?p=422248#422248
" target="_blank">http://www.matronics.com/Navigator?Kolb-List
MS -
e -
Richard Pike
PostPosted: Tue Apr 22, 2014 9:46 am    Post subject: Re: Aligning landing gear Reply with quote
I was trying to be funny. The grounding rod I bought back when I was building my MKIII is still hanging on my garage wall, even though I have no use for it.
[quote="lcottrell"]Shouldn't you at least pay them rent, or contribute to the coffee fund???????
Larry
On Tue, Apr 22, 2014 at 8:28 AM, Richard Pike <richard> wrote:
--> Kolb-List message posted by: "Richard Pike" <richard>
Richard Pike
Kingsport, TN 3TN0
Richard Pike
Kingsport, TN 3TN0
lcottrell
PostPosted: Tue Apr 22, 2014 10:54 am    Post subject: Aligning landing gear Reply with quote
I was trying to be funny. The grounding rod I bought back when I was building my MKIII is still hanging on my garage wall, even though I have no use for it. [quote="lcottrell"]Shouldn't you at least pay them rent, or contribute to the coffee fund??????? Larry
I did laugh, I guess both of us should have used a funny face with our comments. Smile
Larry
On Tue, Apr 22, 2014 at 11:46 AM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
Larry
>  http://www.lowes.com/pd_70861-28781-70861_0__?productId=3446272&Ntt=grounding+rod&pl=1&currentURL=%3FNtt%3Dgrounding%2Brod&facetInfo= (http://www.lowes.com/pd_70861-28781-70861_0__?productId=3446272&Ntt=grounding+rod&pl=1&currentURL=%3FNtt%3Dgrounding%2Brod&facetInfo=)
>  Richard Pike
>  Kingsport, TN 3TN0
Richard Pike
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=422265#422265
MS -
e -
beauford173(at)tampabay.r
PostPosted: Tue Apr 22, 2014 11:05 am    Post subject: Aligning landing gear Reply with quote
Brother Pike:
The thunderstorm season in East Tennessee is nearly upon us... Do the
honorable thing, sir....
Select some irreplaceable thing to protect...(e.g., the Missus... or your
Kolb)... Drive the rod and secure the
strap.... Then hit your recliner and rest easy that honor, fair play and
Lowes were all served well...
Tech note: If you elected to ground the Missus vice the airplane, you might
need to put the recliner
out in the hangar...fer a while, anyway... just a thought....
Always glad to help out.... As usual, worth what ye paid fer it...
beauford
FF-076
use for it.
byoungplumbing(at)gmail.c
PostPosted: Tue Apr 22, 2014 11:09 am    Post subject: Aligning landing gear Reply with quote
I liked the straight edge behind the wheels and the carpenter square along the side.  Seems more accurate than the axle method
Boyd [quote][b]
Richard Pike
PostPosted: Tue Apr 22, 2014 3:09 pm    Post subject: Re: Aligning landing gear Reply with quote
OK - when doing pre-marital counseling, I need to remember not to let either of the hopefully happily-married-newlyweds-to-be get anywhere near Beauford.
Got it!
beauford173(at)tampabay.r wrote:
Brother Pike:
beauford
FF-076
use for it.
Richard Pike
Kingsport, TN 3TN0
west1m
PostPosted: Tue Apr 22, 2014 4:41 pm    Post subject: Re: Aligning landing gear Reply with quote
I was not refering to the horizontal grounding bar but the verticle tube in the foreground. is this to protect the front in case of a noseover?
West1m
Hastings, MN
PostPosted: Tue Apr 22, 2014 6:02 pm    Post subject: Aligning landing gear Reply with quote
Brother West1m:
To address your repeated question, sir:
The U-shaped tube under the nose was reportedly installed by some builders
to keep the machine from going up on the nose
if mishandled...repeat MISHANDLED. It does not appear on my 1998 factory
Fire Fly plans and, near as I can tell, is not mentioned in the factory
building manual for the Fly as it was sent to me at that time. There is no
such U-tube device on my Fly.
IMHO, if the would-be Fly aviator applies the throttle gradually on takeoff,
uses average to good tail wheel technique, and refrains from stomping on the
brakes while in motion, the U-tube is not required for normal Fly operation.
As I recall, I have never seen it installed on any Fire Fly I have
personally observed. I have no clue about what it was connected to when it
was installed, or how well it did, or did not, work.
If you have safety or structural concerns about it, I advise you to consult
with Travis at the New Kolb Aircraft Co..
Your results may vary. The laws of physics apply. Do what you think
appropriate. Gravity is a bitch who ultimately wins...
Worth what ye paid fer it...
beauford
FF-076
Brandon, FL
west1m
PostPosted: Tue Apr 22, 2014 6:16 pm    Post subject: Re: Aligning landing gear Reply with quote
Thanks for the reply! As I have been working to repair the fiberglass nose cone obviously cracked up from a noseover it looked like something that belonged there.
West1m
Hastings, MN
pj.ladd(at)btinternet.com
PostPosted: Wed Apr 23, 2014 1:46 am    Post subject: Aligning landing gear Reply with quote
Hi,
If you are referring to the bow which appears under the nose of some
Kolbs,forget it. In theory it stops the plane standing on its nose. In
practice, if you have got things wrong the nose will be yawing anyway and
the bow will be laid flat. Ask me how I know.
Just ensure that the stick is RIGHT BACK when you taxi, and open the
throttle gently.
Good luck
Pat
west1m
PostPosted: Wed Apr 23, 2014 4:28 pm    Post subject: Re: Aligning landing gear Reply with quote
So... Maybe I need to stop at Northern Tool and pick up one of the big casters with a 4 inch inflatable tire? OK I'll try easy on the throttle when I get this thing back together.
West1m
Hastings, MN
PostPosted: Thu Apr 24, 2014 5:04 am    Post subject: Aligning landing gear Reply with quote
Brother West1M:
As you note, being easy on the throttle from a standing start ought to take
care of the largest part of the business... With my
excessive flab (213) perched in the front, it is easily possible to get my
Fly's tail to come up, regardless of the
full aft position of the stick, by just advancing the throttle abruptly. As
a positive, it is possible to learn to use this in order to
swing the tail around while taxiing -- forward on the stick, hold the
appropriate brake/rudder, give it just enough throttle
to get the tail wheel an inch or two off the ground and you can put the tail
wherever you want it without placing
any side loads on the non-swiveling tailwheel and its support structure.
Back in the days of tailskids on airplanes, this
was a standard technique. Use it at your own risk.
I practice this because side loads on Kolb tail wheels are generally to be
avoided and some wise Kolbers have seen the need to install reinforcing side
straps on the wheel structure. You can find more on that subject in the
archives... It was well covered.
Have also found that taxing across a good sized rut or dropping a wheel into
an unexpected hole can bring the Fly's tail
up if there is a sudden stop... It pays to look at the ground ahead,
especially with 'dillos and wild hogs such as we have around here.
All that said, you should have no problems operating without the training
bib under the nose. Look around at all of the Fly photos
out on the net... Would bet that you will have difficulty finding even one
or two with that gizmo installed on it... Just use sound tailwheel control
inputs/techniques and you ought to be OK. Northern Tool stuff tends to be
kinda heavy...
Good luck... Enjoy your Fly.
Beauford
FF-076
Brandon, FL
west1m
PostPosted: Thu Apr 24, 2014 5:24 pm    Post subject: Re: Aligning landing gear Reply with quote
They must be a little rough on the tail wheel system. The round bar that the wheel connects to takes several turns from the boom to the wheel. I bought a new piece of aluminum to replace it with but did not get to it after looking at how well it is connected to the airframe.
West1m
Hastings, MN
Goto page 1, 2  Next
Page 1 of 2
