jill(at)m-14p.com Guest
Posted: Sat Apr 20, 2013 7:08 am Post subject: Hydraulic Lock |
Group,
A lot of good comments this morning. I have a couple of items to add:
A link to an article that Carl wrote in 1995; which is relevant to any
radial engine owner: http://www.m-14p.com/hydraulic_lock_cwh_1995.pdf .
We recommend against replacement of a link rod in the field. The rod may
not be the only damage to the engine. Typically, the rear cheekplate on the
crank will turn. (This is secured with a pinch bolt.) If the engine is not
torn down with this existing condition, you will be flying with a wobble on
the front end of the crank. In turn, the cam drive gear will bind and the
teeth will shear. The dual drive gear also typically fails. You have now set
yourself up for a catastrophic engine failure. If you sell your airplane to
someone and do not reveal and perform a field repair of replacement of the
link rod only, you are putting them in harm's way. (My opinion.)
Besides overhauling the M-14P, we do a lot of hydraulic lock and prop strike
teardowns. We see more accessory shaft damage with hydraulic lock than with
a prop strike teardown.
I think pulling a prop through 50-60 times may be great aerobic exercise,
but unnecessary. Yes, fear is good motivator and insurance against
hydraulic lock. It does not take many blades on a 2- or 3-bladed prop to
make sure you do not have hydraulic lock. If the cylinders are full of oil,
of course, it will take more to clear them.
Jill
M-14P, Inc.
samira.h(at)shaw.ca Guest
Posted: Sun Apr 21, 2013 12:15 am Post subject: Hydraulic Lock |
The other day someone told me that
one actually can bend a rod on those
radials by just using the air start system
with the magnetos in off position and the
booster coil disconnected.
I doubt it very much that the air pressure
alone will have enough energy to damage
the engine in the event of a hydraulic lock,
the prop will merely stop turning.
Just my 2 cents.
cheers
Elmar
richard.goode(at)russiana Guest
Posted: Sun Apr 21, 2013 12:55 am Post subject: Hydraulic Lock |
I would be very sure that you can bend a rod just with the air start, as
long as the engine has built up a little momentum. I have heard it said that
you can also do it by pulling the propeller through by hand, but this I
personally doubt, and I have never heard of an actual case where it has been
done!
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +94 (0) 81 241 5137 (Sri Lanka)
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
I’m currently in Sri Lanka but this Mail is working,and my local phone is
+94 779 132 160.
coolade2(at)gmail.com Guest
Posted: Sun Apr 21, 2013 8:31 am Post subject: Hydraulic Lock |
elmar--you are incorrect--if you determine the area of the piston it is around 12 square inches--the air pressure is 50 to 70 atmospheres, so you get over 7000 pounds of pressure on the rod----It will bend!
On Apr 21, 2013, at 3:11 AM, Elmar & Manuela Hegenauer wrote:
Just my 2 cents.
cheers
Elmar
Posted: Mon Apr 22, 2013 8:29 am Post subject: Hydraulic Lock |
YAK-52 at New Bern N.C. Inexperienced pilot did exactly that. Piston
Rod let go on the same flight taking a big chunk out of the case and
cylinder. Flew home on 8 out of 9 and landed safely.
Jill, you said:
"We see more accessory shaft damage with hydraulic lock than with a prop
strike teardown."
Are you sure you did not mean it the other way around? When the engine
is turning over during a start process it is turning over very slowly.
If there is too much oil in a cylinder, you end up with the piston being
between a rock and a hard place, meaning that the link rod is pushing
it, and it simply can't move any further "up" because the oil cannot
compress, so something has to "give", and that typically is the piston
rod, and it BENDS. There does not have to be any sudden change in
rotation speed during this process. With no sudden change in rotation
of the crankshaft, I fail to see how the accessory shaft would be
damaged at all.
On the other hand, during a hard prop strike, there is a lot of MASS
moving at high speed and any sudden change in crankshaft RPM will most
certainly damage the accessory shaft. In fact, the first inspection
that should ever be done on an engine that suffered a prop strike is to
see if the timing of the MAGS has shifted. It timing has changed, then
most certainly the accessory shaft has been twisted, and a complete
engine tear-down is mandatory.
Of course, every once in awhile a hydraulic lock situation will result
in the rod being bent enough where the bottom piston ring drops out of
the cylinder itself and "jams" the engine. In this one specific case, I
could see where stress would be imposed on the accessory shaft, but
again nowhere near as much as would be the case in a sudden change in
engine RPM caused by a Prop Strike, or sudden engine stoppage at speed.
Energy = mass times speed. The accessory shaft bends as a function of
the spinning mass it is driving versus the change in speed of the force
driving IT. If the speed of the driving force changes very suddenly,
the output mass energy will cause the shaft to twist.
The short version is this is: The faster the RPM of the engine when it
has a sudden change in speed, the more likely the accessory shaft will
twist.
You're saying that bending a piston rod will cause this (twisting the
accessory shaft) more often at starting RPM, than a prop strike
occurring with the engine developing power at running speeds? If you
say so OK, but it is hard to fathom.
Mark Bitterlich
Just a comment about bending a rod by hand-propping:
When I hand prop the M-14P, I am making that engine move through a compression stroke FAR faster than the normal compressed air starter ever could.
Lever arm length (prop) with big guy on the end equals one heck of a lot of force. Of course, I am rather "big".
Then we have to talk about being stupid. Let's say the prop is pulled through by hand and then just stops because there is oil in the cylinder and the piston now is in a hyd. lock condition. Which do you think would put more force on a link rod at this point? Hitting the starter and putting compressed air into the engine, or a 250 pound man hanging from the end of the prop?
I believe there is no question that a rod could be bent by "hand" (per se). I believe the reason we don't see if happen that often (if at all) is because most of us don't hand prop and are also educated enough not to do something quite this dumb.
Of course with the engine in the Yak-52 where it happened here, the guy who was flying it forgot to pull it through, so he asked someone else to do it for him. When the gent pulling it through said: "Hey, the prop won't turn anymore", the pilot said: "Stand Back, I'll clear it with the starter!".
Like I said, sometimes we have to talk about being stupid.
Mark
Posted: Tue Apr 23, 2013 12:58 pm Post subject: Hydraulic Lock |
Good feedback, Mark.
Most prop strikes occur with wood composite or carbon fiber blades. (We
haven't had a prop strike teardown with a metal prop, yet.) The inertia of
energy is absorbed by the blades disintegrating or being shaved off.
I agree with your assessment of a hydraulic lock on startup, but not when
the engine fires and it pulls fuel or oil in from the intake tubes. If it
fires, there is a good likelihood that the accessory shaft will twist.
At landing speed, the aircraft travels 3.5 feet for each blade in contact
with the ground at initial point of contact. As the engine slows, this
increases. Consequently, the rearward deflection of a very thin blade
exceeds the rotational shearing. Additionally, the reduction of blade
length per rotation with a normal flare landing is less than a tenth of an
inch. In other words, the wood fails well before any engine parts are
stressed to the +400 foot/lbs of torque design load.
Jill
Posted: Wed Apr 24, 2013 7:24 am Post subject: Hydraulic Lock |
Actually this is very good information to keep in mind, and I am going
to chew on the physics of that answer for a day or two. It poses a very
interesting study in the stresses involved and should make for a rather
intense dinner table debate! (Not you, my engineering friends!)
Thanks for writing back Jill.
So given this information, what is the advice of M14P.com regarding prop
strikes and what should be done to the engine afterwards?
Mark
Posted: Fri Apr 26, 2013 9:32 am Post subject: Hydraulic lock |
Additionally, the calculations for torque at full power are 641 ft/lbs on
the crankshaft and 936 ft/lbs on the prop shaft. (Double-check of the
calculations are welcome.)
The numbers in the previous post were for a typical prop strike which is at
near idle on an "Oh, %*&$!" gear up landing. We have had some sudden
stoppage prop strikes where we fully expected damage to the accessory shaft
and there was no damage. This comes back to design limit loads on the
individual components and how much over those limits the parts are
engineered to. I do not have that engineering data.
Mark, the prop strike teardown boils down to the insurance companies and
also, the ultimate peace of mind of the owner and subsequent buyers of the
aircraft. This is a judgment call; which we handle on a case by case basis.
For practical discussion, much of what dictates the prop strike teardown -
in the U.S. - is liability.
Jill
Posted: Fri Apr 26, 2013 11:02 am Post subject: Hydraulic lock |
Good answer again Jill. Thank you.
I wrote a separate message about an engine that had a prop strike when
the left gear collapsed after touch-down. It took off after about a
foot on either end of the stock prop was ground off, then flew around
the pattern and landed. The engine was at idle, and the pilot stated
that he never even knew it happened until after he finally landed. I.E.
No sudden stop.
The engine has since had about 300 hours put on it with no problem
what-so-ever. Which is not to say it was not inspected, it was.
However, it was not totally torn down, only partially. Some of the
decisions were based on what your company published some time ago
concerning prop strikes based on the training they had received in
Russia. It seems it turned out to be the proper decision based on good
information.
The problem with replacing the engine is that you really don't know what
you're going to end up with there either. Hope for the best, but train
for the worst as they say.
In the end, my opinion is that there is a term called "PROP STRIKE!"
that we try to quantify into something that requires an exact action, no
matter what. This is what the FAA leans towards and if specific
information on the engine is unknown, they will also tend to apply
information made for other engines that they consider similar. This is
of course in many cases totally incorrect. Is the engine geared? What
about specific weak points (Accessory Shaft for instance)? These are
not the same from engine type to engine type even if they do both happen
to be "Radials". So EVERY case is unique and the actions taken can
vary within a fairly large margin, insurance companies and liabilities
excepted.
The other take-away from discussions like this is to realize that the
FAA reads the YAK LIST. This is not a guess. I know it for a fact. I
was confronted by an FAA Inspector for what I said on this list one time
and while some may say "so what, FREE SPEECH!", the fact is that when
confronted by these guys, it is not a fun experience no matter how much
"in the right" you might happen to be. Giving credit where credit is
due, I've eventually seen them make some good decisions, but the time
span in the interim is not something anyone wants to experience.
So while sharing good information is what this list is all about, I
would offer this one tiny suggestion: "WALLS HAVE EARS" Be careful
not to make arguments in public that could turn around and bite you in
the tail later on. Of course this is the "Pot calling the Kettle
Black", but hey, I'm learning.
Mark
Posted: Sat Apr 27, 2013 6:13 am Post subject: Hydraulic lock |
Mark & Group,
What is critical in assessing the potential for damage to the accessory
shaft on a prop strike is the rate of deceleration. If you have a 3-bladed
metal Hartzell prop on your plane and hit a fire hydrant at idle, the
potential for damage is much greater than a high speed pass down the runway,
shave the tips of the blades on a wood or composite prop.
| Quote: | From the AI-14RA Engine Maintenance Manual:
"In case of propeller blade damage/broken or cracked/ at distance exceeding
1m/3.3 ft./ from the engine axis without sharp braking due to striking
against ground irregularities - the engine may be used after replacement of
propeller. In other cases send the engine to manufacturing plant or
specialized workshop for inspection."
Bear in mind, this is referring to the wood, composite Wilga blades. The
AI-14 also has a weaker planetary system than the M-14P.
And then you have the Service Bulletin issued by OKBM:
http://www.termikas.com/engines/M-14P/direktyva_angl.jpg (One must ask
what motivated the factory to issue this bulletin. The repair factory in
Shakhty did most of the overhauls on the M-14P, not OKBM.)
Have a great weekend, group!
Jill
________________________________ Message 7
_____________________________________
Time: 12:02:54 PM PST US
Subject: RE: RE: Hydraulic lock
From: "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil>
I wrote a separate message about an engine that had a prop strike when the
left gear collapsed after touch-down. It took off after about a foot on
either end of the stock prop was ground off, then flew around the pattern
and landed. The engine was at idle, and the pilot stated that he never even
No sudden stop.
decisions were based on what your company published some time ago concerning
prop strikes based on the training they had received in Russia. It seems it
turned out to be the proper decision based on good information.
you're going to end up with there either. Hope for the best, but train for
matter what. This is what the FAA leans towards and if specific information
on the engine is unknown, they will also tend to apply information made for
other engines that they consider similar. This is of course in many cases
totally incorrect. Is the engine geared? What about specific weak points
(Accessory Shaft for instance)? These are not the same from engine type to
excepted.
The other take-away from discussions like this is to realize that the FAA
reads the YAK LIST. This is not a guess. I know it for a fact. I was
confronted by an FAA Inspector for what I said on this list one time and
while some may say "so what, FREE SPEECH!", the fact is that when confronted
by these guys, it is not a fun experience no matter how much "in the right"
you might happen to be. Giving credit where credit is due, I've eventually
seen them make some good decisions, but the time span in the interim is not
not to make arguments in public that could turn around and bite you in the
tail later on. Of course this is the "Pot calling the Kettle Black", but
hey, I'm learning.
Mark
Mozam
Posted: Mon Apr 29, 2013 4:27 am Post subject: Re: Hydraulic Lock |
A couple years ago I watched as one of our NE guys tried to make a left turn onto a taxiway in his -52TD just as his right brake froze up. The nose went over, with a high power setting, and the prop hit the pavement.
The last 12 inches or so of every blade was reduced to a million splinters in about one second! (Hence, his new callsign.) A broom and dustpan was used to sweep up what used to be three prop blades.
I don't believe the engine was damaged at all.
ReadeG(at)cairnwood.com Guest
Posted: Mon Apr 29, 2013 6:10 am Post subject: Hydraulic Lock |
This is true - it was an amazing shower of sawdust! It did not tip up
very fast - it was a slow motion kind of thing which meant that I knew
exactly what was about to happen even with stick full aft and pulling
the power. We tore down the nose case and had the components tested
however they needed to be tested and nothing was out of order. We had
other tests done that were either prescribed in the manuals or deemed
appropriate for the situation. Results were all nominal. We put it
back together and that was probably 200 hours ago.
Splinter
676.16 KB |
12583 Time(s) |
654.38 KB |
12583 Time(s) |
Posted: Mon Apr 29, 2013 6:39 am Post subject: Hydraulic Lock |
Was the engine checked in any way, or was it just assumed it was fine and a
new prop bolted on before continuing to fly?
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
drc(at)wscare.com Guest
Posted: Mon Apr 29, 2013 10:22 am Post subject: Hydraulic Lock |
Reade, Holy shit what a picture !! I would have been sick I think.
I was worried about mine - happened in 2005, taxing at OSH prior to air venture - hit something with only one blade. They were establishing all the alternative ground taxi patterns. Other 2 blades ok.
Now 300 hours later no issues.
Dr. Herb Coussons, MD
drc(at)wscare.com
2641 Development Drive
Green Bay, WI 54311
Cell 920-639-8434
Work 920-338-6868
Fax 920-338-6869
On Apr 29, 2013, at 9:07 AM, "Genzlinger, Reade" <ReadeG(at)Cairnwood.com> wrote:
[quote] This is true - it was an amazing shower of sawdust! It did not tip up
Splinter
694.46 KB |
12582 Time(s) |
665.31 KB |
12582 Time(s) |
Posted: Mon Apr 29, 2013 10:58 am Post subject: Hydraulic Lock |
Yeah - it was not a great way to end the day. It was the last flight of
the day - I was doing a practice 4 ship flight as lead. As I was
taxiing I could not get it to turn left. I stopped and tried to taxing
again attempting a left turn and all it wanted to do was go straight
-but it did seem to exhibit some left braking. I stopped again and then
tried once more trying a little extra power to use the rudder to help.
As I began to move forward cycling the brake handle about the third
squeeze the brakes just locked up and the tail began to rise from power
and momentum. I pulled it back but too late. The one fortunate thing
is that the engine stopped with one of the blades on the ground - in
other words the blade held the cowl off the ground. After the Oscar
Sierra moment I shut everything down, a couple of buddies came over and
pulled the tail out of the sky and we got out and promptly pushed it out
of the way and into a hangar. As noted by Mozam, just a lot of
splinters on the ground. Not one mark out of the pavement.
Interestingly, the FAA was at this event. I had to provide my paperwork
(she looked at everything - program letter, registration, AC, parachute
repack date - all was in order!) and she wrote up a report. The next
day an inspector came out and determined that no property was damaged
and he simply called it an incident and not an accident. I had to let
them know when it was made airworthy again and that was it.
The MT prop is wonderful. But it is crazy expensive and the lead times
are awful. Insurance less deductible worked as expected. Needless to
say, the out of pocket still had some sting to it. The brake reduction
valve was replaced and all has been fine ever since. One expensive and
humbling way to get a call sign!
Reade Genzlinger
Cairnwood Cooperative Corporation
215.914.0370
