Posted: Tue Apr 16, 2013 5:40 pm Post subject: mounting hinges/Email Mechanics ;-) |
The editing can be changed after sending if you are posting on the
matronics.com forum. If you are doing it by email, then it can't be edited
after sending. Thanks for pointing that out.
Ralph B
Ralph B/Kolbers:
That is why I do it the way I do.
If I get lazy, don't proof read, send a less than good quality post; then I
have to correct the bad one with, hopefully, a good one.
BTW: Had a great week at Sun and Fun 2013, my 30th consecutive trip to
Lakeland. Certainly has changed a lot during the past 30 flyins. I'm old
fashioned. Still like the old way we did things best.
Got to visit with a lot of my old friends. What better way to spend the
day.
Looking forward to the 2013 Kolb Homecoming 17-19 May 2013.
I flew down at 10,000 feet. Had a 20 mph headwind where I normally fly, low
level. Started climbing out of Gantt IAP. By the time I got to 8,000 feet,
the wind had started to turn in my favor. 10,000 feet yielded a 20 mph tail
wind. Ain't tail winds great.
Flew 4,000 feet on the return flight. Not much help from the wind.
Round trip was 840 sm.
Surprisingly, I burned 5.0 gph at 5,200 rpm at 10,000 feet. At low
altitudes and 5,200 rpm, fuel burn is 5.5 gph.
_________________ John Hauck
Titus, Alabama |
Richard Pike
Posted: Tue Apr 16, 2013 7:45 pm Post subject: Re: mounting hinges/Email Mechanics ;-) |
Nice. What was your IAS?
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Thom Riddle
Posted: Wed Apr 17, 2013 3:11 am Post subject: Re: mounting hinges/Email Mechanics ;-) |
Surprisingly, I burned 5.0 gph at 5,200 rpm at 10,000 feet. At low altitudes and 5,200 rpm, fuel burn is 5.5 gph.
Should not be a surprise because at 10,000 feet 5200 rpm makes less power than at 4,000 feet due to less dense air. Less power means less fuel consumption.
Don't mean to split hairs, just asking:
Did you really mean you flew at 10,000 feet east bound against west bound IFR traffic, or perhaps you meant 9,500'?
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Wed Apr 17, 2013 3:28 am Post subject: mounting hinges/Email Mechanics ;-) |
Richard P/Kolbers:
Averaged about 75 to 80.
Titus, Alabama |
Posted: Wed Apr 17, 2013 3:58 am Post subject: mounting hinges/Email Mechanics ;-) |
consumption.
Thom Riddle
Thom R/Kolbers:
Yes, I was surprised. Up until this flight my 912ULS burned 5.5 gph at 5,200
rpm no matter what altitude I flew.
When I refueled at Cross City, FL, after 4.0 hours, it took 20.1 gals. Hope
it will keep on doing that.
Titus, Alabama |
ceengland7(at)gmail.com Guest
Posted: Wed Apr 17, 2013 10:47 am Post subject: mounting hinges/Email Mechanics ;-) |
consumption.
Thom Riddle
Thom R/Kolbers:
Does your 912 have a method to manually lean the mixture? If not, you
could probably do even better at altitude if you added that. As I'm sure
you know (but other, UL-only participants might not), not only do you
make less power up there, but the drag is quite a bit less, too, meaning
significantly lower power is required for the same speed.
Charlie
Posted: Wed Apr 17, 2013 11:13 am Post subject: mounting hinges/Email Mechanics ;-) |
Does your 912 have a method to manually lean the mixture? Charlie
912 Bing carbs are altitude and temperature compensating.
Titus, Alabama |
Posted: Wed Apr 17, 2013 11:34 am Post subject: mounting hinges/Email Mechanics ;-) |
Yes, but it's doubtful they can manage the extra leaning that's possible at lower power settings.
Posted: Wed Apr 17, 2013 5:34 pm Post subject: mounting hinges/Email Mechanics ;-) |
<ceengland7(at)gmail.com>
Charlie E/Kolbers:
The Bings lean as much as I want them too. The 912 is still
climbing at 14,500 feet. John Williamson was still climbing
at 15,000 feet. Midrange is tuned right next to too lean on
the 80 and 100 horse 912. I experienced a too lean
condition on my first flight to Alaska in 1994, but did not
have the experience with the engine, was brand new when I
departed Alabama, to properly diagnose what was going on. A
few months after returning from Alaska, when the weather
cooled in Alabama, I discovered the problem, raised the fuel
needles a notch, and cured my problem. Would have saved me
a bunch of grief in Alaska if I could have figured it out.
The guys at ROTAX couldn't figure it out either.
Titus, Alabama |
yellowbird1
Posted: Thu Apr 18, 2013 5:39 pm Post subject: mounting hinges/Email Mechanics ;-) |
Just out of curiosity, how big js/are your tank(s)?
Sent from my iPad
Brad
consumption.
Thom Riddle
Thom R/Kolbers:
_________________ Brad Nation,
Albuquerque, NM
MK3 Xtra |
Posted: Fri Apr 19, 2013 4:21 am Post subject: mounting hinges/Email Mechanics ;-) |
Sent from my iPad
Brad
Brad N/Kolbers:
Knew I was going to need a lot more than 10 gals of fuel,
based on my experience with the Ultrastar and Firestar.
During construction the mkIII, we designed and fabricated a
25 gal alum fuel tank. Built it out of 5052 .050 alum.
Sloshed it when complete. Has never had a leak. Have never
come up short on fuel, except once. Landed at Kit Carson
County Airport, Colorado, with .75 gal. That was too close.
Woodville, Florida
Titus, Alabama |
