bakerocb
Posted: Wed Apr 17, 2013 2:49 am Post subject: center stick question |
4/17/2013
Hello Robert Reed, You wrote: "Vance also came up with the center stick that
I am going to be using."
I am not familiar with this center stick modification. Can you please post a
description of it, maybe even a picture, and tell us why you are using it?
OC
Time: 03:49:53 PM PST US
Subject: Re: Re: door window
OC,=0A=0AI know that after this long period of time that many of the source
s will have =0Adried up but if we can locate those that are still out there
it will make life a =0Abit easier.=0A=0AVance also came up with the center
stick that I am going to be using.
| | - The Matronics KIS-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Wed Apr 17, 2013 6:06 am Post subject: center stick question |
Owen,
The why was to keep the KISS while still giving me the ability to have adjustable seats without a stick coming up between the legs. I wanted to maintain the same dynamics as the controls in the original kit and didn't want the complications of the yoke system that you are using. I sketched out a couple of ideas and passed them to Vance who refined them and produced the final control. It keeps the same push rod control for the elevator and just uses a couple of longer control rods for the connections to the aileron rocker arms. It keeps it SIMPLE
There is a drawing and a couple of photos at:
http://www.kisbuild.onfinal18.com/MyControlStick.html#Control
I didn't take any photos of the installation when I did the trial fit on the wings but everything worked as planned and all controls worked as designed.
Bob
To: robertr237(at)att.net; KIS-LIST MATRONICS <kis-list(at)matronics.com>
Sent: Wed, April 17, 2013 5:49:20 AM
Subject: center stick question
--> KIS-List message posted by: "Owen Baker " <bakerocb(at)cox.net (bakerocb(at)cox.net)>
4/17/2013
Hello Robert Reed, You wrote: "Vance also came up with the center stick that I am going to be using."
I am not familiar with this center stick modification. Can you please post a description of it, maybe even a picture, and tell us why you are using it?
OC
From: Robert Reed <robertr237(at)att.net (robertr237(at)att.net)>
= Photoshare, and much much avigator?KIS-List" target=_blank>http://www.matronics.com/Navigator?KIS-L-> http://forum - List Contribution Web Site -
bakerocb
Posted: Wed Apr 17, 2013 8:28 am Post subject: center stick question |
4/17/2013
Hello Bob Reed, Thanks for the quick response and the very interesting
design modification. May I ask a few questions?
1) So the single center control stick is to the right of pilot’s right leg
and to the left of the co pilot’s left leg as they are seated in the
cockpit?
2) If the answer to 1 is YES then the pilot really has normal access to the
stick only with his right hand and the co pilot only has normal access to
the stick with his left hand, correct?
3) Does it follow then that while flying the pilot must control the throttle
with his left hand and the co pilot must control the throttle with his right
hand?
4) If the answer to 3 is YES then the pilot and co pilot must each have
access to a separate throttle control mounted either on the fuselage inside
or on the far left and right corners of the instrument panel, correct?
5) And are you going to provide two separate side throttle controls?
6) When a right handed pilot is flying along with his kneeboard on top of
his right thigh, his right hand on the center control stick, and ATC makes a
radio transmission that the pilot must copy, how does he write it down?
Thanks for helping me understand your modification.
OC
PS: You wrote: “....... didn't want the complications of the yoke system
that you are using.”
I have the standard control stick arrangement on my KIS TR-1 with the two
control sticks coming up between the pilot’s and co pilot’s legs. I think
that it was Al Rosa who installed a two yoke system in his KIS four place.
Sent: Wednesday, April 17, 2013 10:05 AM
To: kis-list(at)matronics.com
Subject: Re: center stick question
Owen,
Bob
4/17/2013
OC
sstearns2(at)yahoo.com Guest
Posted: Wed Apr 17, 2013 11:26 am Post subject: center stick question |
I went with a center stick on my TR-1. It is very comfortable to fly with your fore arm resting on the center console and not have the stick between your legs, and your passengers legs, makes long trips a lot better. I love being able to fly with my iPad or my lunch in my lap.
The Cruiser Mark K and I are building will have a center stick and we may run the forward pitch tube under the fuselage to open up as much interior space as possible.
Like OC said the big concideration is that only your right hand can reach the controls so you need to be able to operate the radios, flaps, lights, etc with your left hand so those controls need to be on the left side of the panel.
There is a picture of my panel on Bob Reeds site showing the switches and autopilot on the far left of the panel and the Garmin 430 on the center-left. Works great.
I can send picture of my center stick mechanism if anyone would like to see it.
Scott
On Apr 17, 2013, at 9:28 AM, "Owen Baker " <bakerocb(at)cox.net> wrote:
4/17/2013
Hello Bob Reed, Thanks for the quick response and the very interesting design modification. May I ask a few questions?
1) So the single center control stick is to the right of pilot’s right leg and to the left of the co pilot’s left leg as they are seated in the cockpit?
2) If the answer to 1 is YES then the pilot really has normal access to the stick only with his right hand and the co pilot only has normal access to the stick with his left hand, correct?
3) Does it follow then that while flying the pilot must control the throttle with his left hand and the co pilot must control the throttle with his right hand?
4) If the answer to 3 is YES then the pilot and co pilot must each have access to a separate throttle control mounted either on the fuselage inside or on the far left and right corners of the instrument panel, correct?
6) When a right handed pilot is flying along with his kneeboard on top of his right thigh, his right hand on the center control stick, and ATC makes a radio transmission that the pilot must copy, how does he write it down?
OC
PS: You wrote: “....... didn't want the complications of the yoke system that you are using.”
I have the standard control stick arrangement on my KIS TR-1 with the two control sticks coming up between the pilot’s and co pilot’s legs. I think that it was Al Rosa who installed a two yoke system in his KIS four place.
Owen,
Bob
4/17/2013
OC
bakerocb
Posted: Thu Apr 18, 2013 6:22 am Post subject: center stick question |
4/18/2013
Hello Bob Reed, Thank you for the answers copied below. You wrote:
1) “Actually shouldn't be that difficult to keep a pad on the center console and write with right hand and fly with left crossed over.
“difficult” in any degree is not something that you want to deliberately build into the controls of an aircraft. But there is a very nice solution to the problem of providing full and appropriate access to a center stick and that is the T bar cyclic design used in the Robinson helicopters. See here:
http://www.helicoptersonly.com/contents/en-us/p1600.html
Or, if this URL does not come through, just google Robinson cyclic control.
Note that the portion of the horizontal T bar that extends over to the co pilot’s side can be quickly removed or replaced.
2) “I have considered separate controls for the throttle but the majority of my flying will be just me and my wife or me alone.”
When building an experimental amateur built aircraft one should keep in mind that someday yourself, your widow, or your children will be attempting to sell the aircraft and the reaction of potential buyers to unusual configuration features may affect its sales appeal.
OC
Sent: Wednesday, April 17, 2013 3:46 PM
To: Owen Baker (bakerocb(at)cox.net)
See Below:
To: kis-list(at)matronics.com; robertr237(at)att.net
Sent: Wed, April 17, 2013 11:28:18 AM
Subject: Re: KIS-List: center stick question
4/17/2013
Correct!
Correct again!
Correct again assuming dual throttle controls.
YES!
NO! I have considered separate controls for the throttle but the majority of my flying will be just me and my wife or me alone. A separate throttle could be incorporated if needed.
Very Carefully! Actually shouldn't be that difficult to keep a pad on the center console and write with right hand and fly with left crossed over. It's not like the control stick will be out of reach on either side.
OC
Sorry, I thought it was you for some reason. Ted Scott was also using the yoke system if I recall correctly this time.
Owen,
Bob
From: Owen Baker <bakerocb(at)cox.net (bakerocb(at)cox.net)>
To: robertr237(at)att.net (robertr237(at)att.net); KIS-LIST MATRONICS <kis-list(at)matronics.com (kis-list(at)matronics.com)>
4/17/2013
OC
bakerocb
Posted: Thu Apr 18, 2013 6:28 am Post subject: center stick question |
4/18/2013
Hello Scott, You wrote: ".... we may run the forward pitch tube under the
fuselage to open up as much interior space as possible."
Do you mean actually outside the bottom of the fuselage exposed to the air
flow and elements?
OC
Sent: Wednesday, April 17, 2013 3:25 PM
space as possible.
panel.
it.
Scott
Robert Reed
Posted: Thu Apr 18, 2013 7:09 am Post subject: center stick question |
Owen,
If we were talking about a stick position that was more out of the way than just accross your lap I would fully agree but I have sat in my seats and done trials with the stick and using my left hand on it wasn't a problem. I also didn't find any issues with using my left hand to reach the radio and other controls in the center position. Since there are no obstructions such as the stick in your lap or the much larger yoke setup in the way, reaching anything on the pilot side is very easy.
I have also considered that an easy fix if needed would be a short side extension to the stick that could be turned to either the pilot or copilot side when desired to turned to a forward position out of the way when not needed. It would allow for basically the same positioning as the between the leggs stick. I will look into this option if I encounter a problem with the center position.
As for the sales appeal for the future, I am building this plane for ME not someone else and while I may eventually need to sell it that is not my primary concern today. I have thought about dual throttle controls but haven't been able to come up with a design that I thought would be effective without actually making the controls less safe. I would welcome any design suggestions that would work without a huge amount of time and money.
Bob
To: Robert Reed <robertr237(at)att.net>; KIS-LIST MATRONICS <kis-list(at)matronics.com>; sstearns2(at)yahoo.com
Sent: Thu, April 18, 2013 9:22:22 AM
4/18/2013
OC
See Below:
4/17/2013
Correct!
Correct again!
YES!
OC
Owen,
Bob
4/17/2013
OC
[quote]http://www.="http://forums.matronics.com/" rel=nofollow target=_blank>http://for=========
fredorosa(at)gmail.com Guest
Posted: Thu Apr 18, 2013 7:59 am Post subject: center stick question |
OC,
Going one step further, a single "throw over" stick or yoke that is used in
some aircraft, would be better I think.
Al
On Thu, Apr 18, 2013 at 10:21 AM, Owen Baker <bakerocb(at)cox.net> wrote:
[quote] 4/18/2013
1) Actually shouldn't be that difficult to keep a pad on the center
difficult in any degree is not something that you want to deliberately
here:
pilots side can be quickly removed or replaced.
2) I have considered separate controls for the throttle but the majority
OC
*Sent:* Wednesday, April 17, 2013 3:46 PM
*To:* Owen Baker <bakerocb(at)cox.net>
*Subject:* Re: center stick question
See Below:
*To:* kis-list(at)matronics.com; robertr237(at)att.net
*Sent:* Wed, April 17, 2013 11:28:18 AM
4/17/2013
1) So the single center control stick is to the right of pilots right leg
and to the left of the co pilots left leg as they are seated in the
cockpit?
Correct!
Correct again!
his right hand?
YES!
OC
PS: You wrote: ....... didn't want the complications of the yoke system
that you are using.
control sticks coming up between the pilots and co pilots legs. I think
Posted: Thu Apr 18, 2013 10:34 am Post subject: center stick question |
Hi OC,
Yes, but there would be a fairing running down the belly. There would be a bellcrank under the baggage compartment floor to transition back to a tube inside the fuselage.
Scott
To: kis-list(at)matronics.com; sstearns2(at)yahoo.com
Sent: Thursday, April 18, 2013 7:28 AM
4/18/2013
Hello Scott, You wrote: ".... we may run the forward pitch tube under the fuselage to open up as much interior space as possible."
Do you mean actually outside the bottom of the fuselage exposed to the air flow and elements?
OC
--> KIS-List message posted by: Scott Stearns <sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)>
I can send picture of my center stick mechanism if anyone would like to see sp; - List Contribution Web Site -
_; &nbs=================
bakerocb
Posted: Thu Apr 18, 2013 11:43 am Post subject: center stick question |
4/18/2013
Hello Al Rosa, Some day the owner / primary pilot will be demonstrating (for sale maybe), or instructing (formally or otherwise) while sitting in the left pilots seat with the throw over control over on the co pilots side.
The co pilot / student / prospective buyer will do something so unexpected (stupid) and sudden that before the throw over control can be returned to the pilot for him to salvage the situation the aircraft will be damaged or worse.
I have not seen everything in my 63 years of maintaining aircraft and 55 years of flying them, but I have seen enough to know that mighty bad unexpected things can happen very quickly. It should be the builders goal to prevent such events with sound design and construction.
The Robinson T bar design always gives the pilot in command access to the stick **and the removable section for the co pilot gives the option of having it there or not.
OC
**PS: Even with that ready access to the control stick for the pilot in command / instructor the history of the Robinson helicopter is filled with accidents wherein the instructor / pilot in command was not quick enough to salvage the situation. I believe that the number of Robinson helicopter accidents would be at least triple the actual number of accidents if the design had a throw over control.
PPS: As an exercise in education one could google throw over control accidents. Here is an extract from the accident report on just one of URLs that shows up:
Factors in the accident were the flight instructor's inability to take remedial action because the airplane was not equipped with a full set of dual flight controls.
Sent: Thursday, April 18, 2013 11:59 AM
OC,
Going one step further, a single "throw over" stick or yoke that is used in some aircraft, would be better I think.
Al
bakerocb
Posted: Thu Apr 18, 2013 1:10 pm Post subject: center stick question |
4/18/2013
Hello Robert Reed, Thanks for your response. You wrote:
1) “I also didn't find any issues with using my left hand to reach the radio and other controls in the center position.”
I understand and agree that there would be no issues if the cockpit is designed for left handed access for the individual sitting in the left seat. My primary concern is with the awkwardness / difficulty involved in right handed writing on a knee board or center console writing pad while controlling the airplane with a left arm crossed over (or under?) the right arm.
2) “I have also considered that an easy fix if needed would be a short side extension to the stick that could be turned to either the pilot or copilot side when desired to turned to a forward position out of the way when not needed.
There is an easy inexpensive fix, but it is not some version of a throw over control. Please see my response to Al Rosa’s throw over control suggestion.
3) “I have also considered that an easy fix if needed would be a short side extension to the stick.....” and “I would welcome any design suggestions that would work without a huge amount of time and money.”
And that suggestion is to adapt something similar to the Robinson helicopter pivoting horizontal T bar. Please check it out – I say again: easy and inexpensive.
4) “I have thought about dual throttle controls but haven't been able to come up with a design that I thought would be effective without actually making the controls less safe.”
I understand and consider the dual throttle situation more difficult to resolve than the center stick situation. I can offer no easy, inexpensive solution.
5) “As for the sales appeal for the future, I am building this plane for ME not someone else and while I may eventually need to sell it that is not my primary concern today.”
Correct, not a primary concern, but also not something that should be totally ignored if eventual acceptance to a buyer (sales appeal) can be accommodated safely, easily, and inexpensively. But it may not be you that is selling the airplane – put yourself in the position of your widow or child who is selling this airplane, hopefully, many years from now. ## The majority of potential buyers want a level of comfort created by the familiar, ** not the exotic or unusual that is off putting, or will require some effort on their part to accept and “correct” (in their mind).
OC
##PS: For all KIS builders, owners, pilots -- please take a look into what may be in the really far future, or not. When that proverbial beer truck accidentally squashes you like a bug who is going to assist your widow with demonstrating and assisting in selling your airplane? We have had some of our EAA Chapter members who had built experimental amateur built airplanes pass away. While none of their passings, so far, have been sudden and accidental the problem of having some one capable of demonstrating and assisting the widow with selling their airplanes was very real. My solution is to pick a friend that I trust, and who was willing, put him on my (liability only) insurance policy, and have him fly my KIS TR-1 about once a quarter so that he can conduct demonstration flights if needed.
**PPS: Look at the sales success of the Cirrus line of airplanes. It can largely be attributed to the fact that the cockpit looks very much like the Mercedes Benz, Lexus, Infinity, or other luxury automobile interiors that the potential buyer is familiar with. (Yes, we have pilots, or would be pilots, who are largely influenced by appearances alone – check out some of the pilot error Cirrus airplane accidents.)
Sent: Thursday, April 18, 2013 11:09 AM
Owen,
Bob
gbrighton(at)skymesh.com. Guest
Posted: Thu Apr 18, 2013 2:27 pm Post subject: center stick question |
Hi Guys,
I reworked my Stick to lighten the adjust Aileron feel .. and to be able to have my lapboard/Ipad etc on my lap .... also nice to have retracted for xcountry with the wing leveler engaged etc too
Bit novel but works fine fine .!
Graham
Sent: Friday, April 19, 2013 4:33 AM
Hi OC,
Scott
To: kis-list(at)matronics.com (kis-list(at)matronics.com); sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)
4/18/2013
OC
href="http://www.matronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-List
142.72 KB |
8139 Time(s) |
138.31 KB |
8139 Time(s) |
galinhdz(at)gmail.com Guest
Posted: Fri Apr 19, 2013 9:21 am Post subject: center stick question |
Grahm, can you post some photos of your setup?
On Thursday, April 18, 2013, Graham Brighton wrote:
[quote] Hi Guys,
Bit novel but works fine fine ..!
Graham
From: [url=javascript:_e({}, 'cvml', 'sstearns2(at)yahoo.com');]Scott Stearns[/url]
To: [url=javascript:_e({}, 'cvml', 'kis-list(at)matronics.com');]kis-list(at)matronics.com[/url]
Hi OC,
Scott
From: Owen Baker <[url=javascript:_e({}, 'cvml', 'bakerocb(at)cox.net');]bakerocb(at)cox.net[/url]>
To: [url=javascript:_e({}, 'cvml', 'kis-list(at)matronics.com');]kis-list(at)matronics.com[/url]; [url=javascript:_e({}, 'cvml', 'sstearns2(at)yahoo.com');]sstearns2(at)yahoo.com[/url]
--> KIS-List message posted by: "Owen Baker " <[url=javascript:_e({}, 'cvml', 'bakerocb(at)cox.net');]bakerocb(at)cox.net[/url]>
4/18/2013
OC
--> KIS-List message posted by: Scott Stearns <[url=javascript:_e({}, 'cvml', 'sstearns2(at)yahoo.com');]sstearns2(at)yahoo.com[/url]>
Posted: Fri Apr 19, 2013 3:47 pm Post subject: center stick question |
G'day Galin,
Actually I attached a couple pics with my post ..... Can resend later when I get hm if u haven't received ... just a simple 'twist lock' telescope setup ... Haven't figured how to balance elevator feel though ... Luv to hear if anyone has a fix for that ... ??
Graham
On 20/04/2013, at 3:20 AM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
[quote]Grahm, can you post some photos of your setup?
| Quote: | Hi Guys,
I reworked my Stick to lighten and adjust Aileron feel .. and to be able to have my lapboard/Ipad etc on my lap .... also nice to have retracted for xcountry with the wing leveller engaged tracking gps track etc too
Bit novel but works fine ..!
Graham
From: [url=javascript:_e({}, \'cvml\', \'sstearns2(at)yahoo.com\');]Scott Stearns[/url]
To: [url=javascript:_e({}, \'cvml\', \'kis-list(at)matronics.com\');]kis-list(at)matronics.com[/url]
Hi OC,
Scott
From: Owen Baker <[url=javascript:_e({}, \'cvml\', \'bakerocb(at)cox.net\');]bakerocb(at)cox.net[/url]>
To: [url=javascript:_e({}, \'cvml\', \'kis-list(at)matronics.com\');]kis-list(at)matronics.com[/url]; [url=javascript:_e({}, \'cvml\', \'sstearns2(at)yahoo.com\');]sstearns2(at)yahoo.com[/url]
--> KIS-List message posted by: "Owen Baker " <[url=javascript:_e({}, \'cvml\', \'bakerocb(at)cox.net\');]bakerocb(at)cox.net[/url]>
4/18/2013
OC
--> KIS-List message posted by: Scott Stearns <[url=javascript:_e({}, \'cvml\', \'sstearns2(at)yahoo.com\');]sstearns2(at)yahoo.com[/url]>
cs.com
matronics.com/contribution
Posted: Fri Apr 19, 2013 7:13 pm Post subject: center stick question |
THANKS! I was viewing the e-mail on my iPad so I didn't see the attached pics. :O)
On Fri, Apr 19, 2013 at 6:46 PM, Graham Brighton <gbrighton(at)skymesh.com.au (gbrighton(at)skymesh.com.au)> wrote:
[quote]G'day Galin,
Graham
| Quote: | Grahm, can you post some photos of your setup?
| Quote: | Hi Guys,
Graham
Hi OC,
Scott
--> KIS-List message posted by: "Owen Baker " <bakerocb(at)cox.net>
4/18/2013
OC
--> KIS-List message posted by: Scott Stearns <sstearns2(at)yahoo.com>
cs.com
| | Quote: |
et="_blank">http://www.matronics.com/Navigator?KIS-List
bakerocb
Posted: Fri Apr 19, 2013 7:36 pm Post subject: center stick question |
4/19/2013
Hello Graham, You wrote: “Haven't figured how to balance elevator feel though ... Luv to hear if anyone has a fix for that ... ??”
What sort of balancing is needed for KIS TR-1 elevator feel?
OC
'O C' Baker says "The best investment you can make is the effort to gather and understand information."
From: Graham Brighton (gbrighton(at)skymesh.com.au)
Sent: Friday, April 19, 2013 7:46 PM
G'day Galin,
Actually I attached a couple pics with my post ..... Can resend later when I get hm if u haven't received ... just a simple 'twist lock' telescope setup .. Haven't figured how to balance elevator feel though ... Luv to hear if anyone has a fix for that ... ??
Graham
Posted: Sat Apr 20, 2013 3:59 am Post subject: center stick question |
Hi OC,
Sorry didn't mean something was specially wrong .... Is that most lighties share that common lack of harmony of control feel with roll and pitch .... ,
With our Ailerons which are specially wholesome ( non tapered) .. some 'leverage' ... is going to be required .. (specially with increased speed !) ...
Where as elevators are mostly light ..!? .. In theory achieving mechanical leverage advantage in equal measure to arrive at uniform control input between pitch and roll is straight fwd .... but carn't think of any ( admit am only ppl and not flown very many types ..!) .., that have achieved it ..?!
Playing with bell crank ratios is the logical way .. but would be super laborious I'm sure ... With my adjustable length stick ... roll is as light/heavy as my personal preference ( for whatever speed .. ) .... However pitch which is normally light gets lighter with extra leverage grrr .... Am surprised someone hasn't come up with some sort of fail safe dampener devise to enable Elevator input feel to be adjusted to harmonise together with Aileron input feel .... , probably there is ... but i just haven't stumbled across it sob ..,!?? , anybody ..??,
Anyway am happy at present to retract down the stick for xcrountry legs and map reading/iPad etc ...,
Just was that stick position came up that's all ... ,
Cheers
Graham
Posted: Sat Apr 20, 2013 7:18 pm Post subject: center stick question |
I modified my elevator bellcrank with 3 sets of holes so i could adjust it if needed. I fly with about 60% of the mechanical advantage as the stock set up and and I added 2" to the elevator chord. Drilling a couple bolt holes in the bellcrank to reduce the mechanical advantage is pretty simple and should make a noticable improvement.
I also added a bob weight so as the G forces build up the weight adds forward stick force. That helped a lot to smooth out turbulence and the airplane feels more solid during spirited maneuvering. I really recommend the bob weight. I have pics if anyone wants to see. Very cheap and simple.
My ailerons are still a too heavy but much better matched to the elevator compared to factory setup.
Far and away the best flying light airplane is a bonanza. Especially the short wing ones. The control harmony is perfect. I will never understand why all light airplanes do not have that kind of control harmony concidering is was nearly the first modern light airplane.
Scott
On Apr 20, 2013, at 4:54 AM, Graham Brighton <gbrighton(at)skymesh.com.au (gbrighton(at)skymesh.com.au)> wrote:
[quote]Hi OC,
Cheers
Graham
On 20/04/2013, at 1:36 PM, "Owen Baker " <bakerocb(at)cox.net (bakerocb(at)cox.net)> wrote:
| Quote: | 4/19/2013
OC
G'day Galin,
Graham
cs.com
cs.com
Posted: Sun Apr 21, 2013 4:18 am Post subject: center stick question |
G'Day,
Scott ... sounds like u have given this some thought too .. would luv to see any pics u have ... the bob weights sound a good idea ..but nor sure where u have them situated .!?
Cheers
Graham
