A Plane is born
kearney
PostPosted: Sun Apr 07, 2013 9:29 pm    Post subject: A Plane is born Reply with quote
Hi
After 6 years and 178 days, RV10 C-GCWZ took to the air at Camrose Airport in Alberta, Canada.
I would like to thank all the usual suspects but especially Tim Olson for his website, Matt Dralle for this list and Dave Saylor for his fiberglass seminar. Thanks to all those who answered my cries for help. Learning how to build a plane is harder and perhaps takes longer than the actual building process. Having access to the collective wisdom of this group was quite literally pricesless. In every sense you were my build partners.
Cheers
Les Kearney
#40-643 Now Flying!!!!!!!
kearney
PostPosted: Sun Apr 07, 2013 9:31 pm    Post subject: A Plane is born Reply with quote
Hi Again
I almost forgot - A very Special Thanks to David Maib with whom I did my transition training! He is an outstanding instructor.
Cheers
Les
Sent: April-07-13 11:28 PM
To: 'rv10-list(at)matronics.com'
Subject: A Plane is born
Hi
Cheers
Les Kearney
rleffler
PostPosted: Mon Apr 08, 2013 1:37 am    Post subject: A Plane is born Reply with quote
Congratulations Les!
Sent from my iPad
On Apr 8, 2013, at 1:28 AM, "Les Kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
[quote] <![endif]--> <![endif]-->
Hi
Cheers
Les Kearney
://www.matronics.com/Navigator?RV10-List
cs.com
matronics.com/contribution
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
Lew Gallagher
PostPosted: Mon Apr 08, 2013 3:23 am    Post subject: A Plane is born Reply with quote
That’s a small rotation for a man ... giant birth ... etc.! Awesome, Les! Post pics/ video when you can. At least more details.
Later, – Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
gipsowh(at)hotmail.com
PostPosted: Mon Apr 08, 2013 4:44 am    Post subject: A Plane is born Reply with quote
Way to go Les.  Hope everything went well with first flight and few minor squawks.  Let us know how she flew.
Bill
Sent from my iPhoneBill Gipson
On Apr 8, 2013, at 12:33 AM, "Les Kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
Hi
Cheers
Les Kearney
Strasnuts
PostPosted: Mon Apr 08, 2013 4:51 am    Post subject: A Plane is born Reply with quote
Can't wait to see it.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
dave.saylor.aircrafters(a
PostPosted: Mon Apr 08, 2013 5:08 am    Post subject: A Plane is born Reply with quote
Congratulations Les!  Keep up the good work and fly safe!
Dave Saylor
831-750-0284 CL
On Sun, Apr 7, 2013 at 10:28 PM, Les Kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
Hi
Cheers
Les Kearney
tp://forums.matronics.com
rv10free2fly(at)yahoo.com
PostPosted: Mon Apr 08, 2013 5:22 am    Post subject: A Plane is born Reply with quote
Congratulations mate, I wish you safe skies and tailwinds.
Your assistance with the composite cabin door frame and seal advice has inspired me Les, thank you.
Warm regards from down under.
Patrick
On 08/04/2013, at 2:58 PM, "Les Kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
Hi
Cheers
Les Kearney
cs.com
Tim Olson
PostPosted: Mon Apr 08, 2013 5:38 am    Post subject: A Plane is born Reply with quote
Hey congrats Les, tell us about the flight!
On 4/8/2013 12:28 AM, Les Kearney wrote:
Hi
build partners.
Cheers
Les Kearney
bill.peyton
PostPosted: Mon Apr 08, 2013 6:10 am    Post subject: Re: A Plane is born Reply with quote
Congratulations Les! Pictures?
Bill
WA0SYV
Aviation Partners, LLC
kearney
PostPosted: Mon Apr 08, 2013 6:52 am    Post subject: A Plane is born Reply with quote
Hi
Here is the pix with the obligatory RV grin. I have a vido but it is very large. I also need to get my daughter to clean it up a bit before I post it.
The chap in the right seat is local flight instructor. In Canada it is legal to have an instructor aboard during the fly off period. He took care of comms and help monitor the engine parameters for the flight. My engine is a 3.6L Subaru Tribeca with a 4 blade Quinti / Sensenich prop so there was a lot to keep an eye on during the first flight. I was wowed by how smooth and quite the engine was on takeoff!
Exterior pix are not all that interesting as I haven't done paint yet. It is very much a "coat of many colours" as my focus has been on getting airworthy and not pretty. I will post a couple later.
I am following the test flight syllabus laid out in Jerry Milek's "Test Flight Checklist" which can be found at www.javifix.com. It is well worth the cost. First flight lasted, by design, for about 11 minutes. The plan was to to check controls *gently* and then return to ground to check for leaks etc in the engine compartment. Based on the syllabus, each flight builds on the previous in a highly structured way. The intent is to carefully and methodically test the aircraft with a minimum of risk.
Cheers
Les
RV10 C-GCWZ
 Filesize:  0 Bytes
 Viewed:  14241 Time(s)
Phil White
PostPosted: Mon Apr 08, 2013 7:34 am    Post subject: Re: A Plane is born Reply with quote
Les: Congratulations! As a fellow auto-engine builder, I know how much extra time is involved in getting to flight. A major achievement on your part!
My Mazda 20B rotary is still in the 'build all the external support pieces to the engine' phase. Hope this warm season will allow getting to a running engine point.
Phil in IL
ps: Photo did not post. Try again.
partner14
PostPosted: Mon Apr 08, 2013 8:21 am    Post subject: A Plane is born Reply with quote
Welcome to the other side.... As you will soon discover, the RV10 has to be one of the greatest planes around.... in all aspects. Congrats.
Don McDonald
500+
--- On Mon, 4/8/13, LES KEARNEY <kearney(at)shaw.ca> wrote:
Subject: Re: Re: A Plane is born
Date: Monday, April 8, 2013, 9:51 AM
Hi
Cheers
Les
RV10 C-GCWZ
Don A. McDonald
40636
Mauledriver(at)nc.rr.com
PostPosted: Mon Apr 08, 2013 9:01 am    Post subject: A Plane is born Reply with quote
A big congratulations!!
Hi
Cheers
Les Kearney
Checked by AVG - www.avg.com
04/07/13 [b]
dmaib@me.com
PostPosted: Mon Apr 08, 2013 5:25 pm    Post subject: Re: A Plane is born Reply with quote
Congratulations Les! For some reason, I cannot access the photo, but I can imagine what that grin looks like! Have fun working through your test program. I hope to get a ride in your airplane someday.
David Maib
RV-10 #40559
New Smyrna Beach, FL
John Jessen
PostPosted: Thu Apr 11, 2013 9:58 am    Post subject: Re: A Plane is born Reply with quote
Les! Way to go, man. Enjoy!
John
John J
Wings
rv10flyer(at)live.com
PostPosted: Thu Apr 11, 2013 10:35 am    Post subject: A Plane is born Reply with quote
John;
Being you were my guide, via your detailed website for the tailcone (back in
2009!!) When will we be congratulating you on your completion?
rv10pro(at)gmail.com
PostPosted: Mon Apr 15, 2013 8:21 am    Post subject: A Plane is born Reply with quote
It is truly wonderful to hear of the completion and your addition of an Alternate Engined RV-10 to the stable of so many versatile 4 passenger - Experimental Built Cruisers.
On Sun, Apr 7, 2013 at 10:31 PM, Les Kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
Hi Again
Cheers
Les
From: Les Kearney [mailto:kearney(at)shaw.ca (kearney(at)shaw.ca)]
To: 'rv10-list(at)matronics.com (rv10-list(at)matronics.com)'
Hi
Cheers
Les Kearney
