hansjd(at)online.no Guest
Posted: Tue Apr 09, 2013 5:28 am Post subject: SV: Re: Drop in RPM/Mag drop |
Sendt fra en Samsung Mobilploucandco <jacques(at)platisource.com> skrev:
Hans, how much time was the plane in the hangar without engine running? I got pretty much the same issues after 3 months of heavy winter: snow and ice that prevented me to use the plane. Cracks in the radio and the 914 engine running squared due to oil in the air system.
The cracks in the radio disappeared after some minutes of communications, I suspect some oxydation.
The oil in the air system came from the turbo check valve that has weeped during the storage period. The oil needs to be cleaned from the airbox and the spark plugs. Also the carbs need to be checked if there is no residual oil.
Hope this helps, Jacques.
[/code]
http://forums.matronics.com/viewtopic.php?p=398225#398225
