nickc(at)mtaonline.net Guest
Posted: Tue Apr 09, 2013 9:36 am Post subject: mounting hinges |
Hello Kolbers,
I have built my wings, horizontal stabilizers, and vertical stabilizer. Now I need to mount my hinges…I remember someone split each hinges into thirds and mounted the hinge on both sides of the center line, on the trailing edge tube, rather than having the hinge mounted all on one side. This seems like a good idea to me, but I cannot find the “posts” in the Archives. I would be grateful if anyone has thoughts on the pro’s or con’s of this approach.
Nick Cassara
Palmer, Alaska
N607AK Kolbra #1
Ralph B
Joined: 14 Apr 2007 Posts: 367 Location: Mound Minnesota
Posted: Tue Apr 09, 2013 10:51 am Post subject: Re: mounting hinges |
"nickc(at)mtaonline.net" | Quote: | Hello Kolbers,
Nick Cassara
Palmer, Alaska
N607AK Kolbra #1 |
Nick, my Kolbra was built according to plan and the hinges were not split.
Ralph
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
Posted: Tue Apr 09, 2013 11:23 am Post subject: mounting hinges |
I went into the search engine and did a search on “x hinges” found this http://www.mindspring.com/~possums/Xhingestrailingedge.jpg and http://www.mindspring.com/~possums/HINGESML.jpg if you do the search, you may find more. as I remember, you have to cut out every other spot on each hinges that the wire hinge pin goes through. I have no experience to determine if it is a good idea or not. hope this is what you are looking for.
boyd young
Sent: Tuesday, April 09, 2013 11:36 AM
Subject: mounting hinges
Hello Kolbers,
Nick Cassara
Palmer, Alaska
N607AK Kolbra #1
Carolina Flyer
Joined: 03 Oct 2010 Posts: 62 Location: Buffalo, South Carolina
Posted: Wed Apr 10, 2013 12:12 am Post subject: Re: mounting hinges |
Nick,
Here is a Picture of the X-Hinge I am using on my Firestar II. I do not know if these can be bought but they are very easy to make. It takes twice as much hinge to make these. Some people think less is better, but I think I need to make things as good as I can if my life is depending on it. This is by far stronger, and maybe even over-kill but I will bet this set-up is less likely to fail.
Best Regards Joe
75.95 KB |
9076 Time(s) |
_________________ Kolb Firestar II
503 C-Box / RK400
Soon to have a
Rotax 670 DCDI
with a C-Box and
RK 400 Clutch
Challenger II
503 Tall Drive
Richard Pike
Posted: Wed Apr 10, 2013 4:45 am Post subject: Re: mounting hinges |
You can also split them this way:
59.49 KB |
9062 Time(s) |
63.81 KB |
9062 Time(s) |
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Wed Apr 10, 2013 5:16 am Post subject: mounting hinges |
Ref x hinges.
See if I can figure this out.
Cut half the loops off the hinge resulting in a stronger hinge?
Lot of work compared using the whole hinge.
There is no problem with current hinges or Kolb method of attachment.
Johnh
MkIII
Lakeland, FL
_________________ John Hauck
Titus, Alabama |
Posted: Wed Apr 10, 2013 5:36 am Post subject: mounting hinges |
I erred I my previous post. Didn't realize it took twice as much hinge for x hinge.
John h
MkIII
Lakeland, FL
Titus, Alabama |
Ralph B
Posted: Wed Apr 10, 2013 6:05 am Post subject: Re: mounting hinges |
Using the full hinge mount per plan lasts a long time as my Firestar is built that way and has 1000 hrs. Also, I removed the book-binding tape between the aileron and wing and didn't notice one bit of difference in banking the Kolbra.
John H: you can use the "edit" button to the right when making corrections in your posts. There is no need to write another post. It will make the changes in your original post. I may have mentioned this before, but it bears repeating.
Ralph
Kolb Kolbra 912uls
N20386
550 hours |
ceengland7(at)gmail.com Guest
Posted: Tue Apr 16, 2013 3:34 pm Post subject: mounting hinges |
On 04/10/2013 09:05 AM, Ralph B wrote:
Ralph
Ralph B
Original Firestar 447
N91493 E-AB
1000+ hours
26 years flying it
Kolbra 912ULS
N20386
200 hours
I don't know which method John uses, but if he's using email (I do),
posts can't be edited after sending.
Charlie
Ralph B
Posted: Tue Apr 16, 2013 4:55 pm Post subject: Re: mounting hinges |
"ceengland7(at)gmail.com" | Quote: |
Charlie |
The editing can be changed after sending if you are posting on the matronics.com forum. If you are doing it by email, then it can't be edited after sending. Thanks for pointing that out.
Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
Dana
Posted: Tue Apr 16, 2013 5:23 pm Post subject: mounting hinges |
At 08:55 PM 4/16/2013, Ralph B wrote:
| Quote: | | The editing can be changed after sending if you are posting on the matronics.com forum. If you are doing it by email, then it can't be edited after sending. Thanks for pointing that out. |
Note too that those of us who receive the posts by email will only get the original unedited version...
Dana
The supreme irony of life is that hardly anyone gets out of it alive. - RAH
