Duncan McFadyean
Posted: Sun Apr 21, 2013 4:49 am Post subject: New pattern oil filter |
Anyone know how to get oil in to the new pattern (i.e. with anti backflow valve) 912 oil filter before screwing it on to the engine?
Otherwise the engine takes a massive gulp or air on start-up.
In fact, oil pressure comes up in about 15 seconds (to just above the minimum pressure specified, a further two minutes to get anywhere near to its normal pressure and nearly 1 hours running to stabilise back to where it always sits.
All because the filter can't be primed.
Duncan McF.
jimd4414(at)hotmail.com Guest
Posted: Sun Apr 21, 2013 5:49 am Post subject: New pattern oil filter |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Why not fill the filter with oil before installation?
Roger Lee
Posted: Sun Apr 21, 2013 6:02 am Post subject: Re: New pattern oil filter |
The new style filters that have been out for a couple of years can not be
pre-filled like the old style because of the check valve. The anti drain back membrane has nothing to do wit it. You should rotate the prop 20-30 times (this is in the maint. manual and old service bulletin) with the spark plugs in place and that will help facilitate pre-filling the oil filter. Rotax has determined that that small amount of air during the oil change is not detrimental.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
