LED strip lighting for panels
PostPosted: Tue Apr 02, 2013 11:14 am    Post subject: LED strip lighting for panels Reply with quote
If your airplane has a glare shield, you can
consider the used of LED strip lights similar
to these.
http://tinyurl.com/c3wozbj
These strips are assembled from an array
of LED trios in series fitted with the appropriate
series resistor to provide max illumination with
12vdc applied. Each trio occupies about 2" of
length.
Three white lights in series do not begin to
output until applied voltage rises to 7.5 volts
or so. At 12 volts, each group of 3 lamps
(about 2" in length) draws about 25 milliamps.
Assume you need 36" of strip to stretch
across the glare shield (18 trios). You'll
need a dimmer control capable of carrying
18 x .025 or 0.45 amps. This relatively
low current draw makes the noise-free, linear
regulators more attractive. Referring to this
drawing
http://tinyurl.com/ccrpzfa
You see the architecture for a dimmer set up for
incandescent lamps. I.e. 4.5 volts minimum. For service
with these strips, the minimum needs to be raised to
7.5 volts. Further, we want to fix the adjustment
range at 7.5 - 12v or a delta-V of 3.5 volts.
Since our stock "pot" is 2.5K, then to get 3.5
volts dropped across the pot at max resistance,
we need a divider current of 3.5/2500 or 1.4 milliamps.
The voltage across the upper resistor is fixed at
1.25 volts by internal characteristics of the
317 regulator. 1.25V/0.0014A = 892 (910 ohms
is close enough and a standard 5% value).
Okay, with the pot at min resistance, we need
7.5 volts total output. (7.5 - 1.25)/0.0014
equals 4464 ohms (4700 is also a standard
value and sufficiently close).
So, if you'd care to build your own dimmer the
390 ohm resistor is replaced with a 910 ohm
resistor; the 910 ohm resistor is replaced with
a 4700 ohm resistor. The TO220 plastic package
version of the LM317 on a modicum of heatsink
would be 'fat' enough and entirely free of noise.
That 15-foot chunk of strip lighting for $20 is
delivered toyour door at that price and is probably
enough lighting to do 5 airplanes. I've copied B&C
on this posting to see if they'd be interested in
offering an LED strip light version of their DIM5-14
product.
http://tinyurl.com/dylkufj
Bob . . . [quote][b]
raymondj(at)frontiernet.n
PostPosted: Tue Apr 02, 2013 11:35 am    Post subject: LED strip lighting for panels Reply with quote
Bob,
Do I understand correctly that you are controlling LED brightness by varying the voltage?
My understanding was that a PWM was needed to dim LEDs. Of course, I've been wrong before. :>)
Raymond Julian
Kettle River, MN.
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
On 04/02/2013 02:12 PM, Robert L. Nuckolls, III wrote:
[quote] If your airplane has a glare shield, you can
to these.
length.
drawing
product.
FisherPaulA(at)johndeere.
PostPosted: Tue Apr 02, 2013 11:42 am    Post subject: LED strip lighting for panels Reply with quote
I’m doing exactly that in my plane using red LED’s instead of white. I’ve got them installed by not wired yet (been too cold at the hanger!). I’m planning to use one of Eric’s dimmers (http://www.periheliondesign.com/egpavr.htm). I’ve tested the lights and dimmer in the shop and it all seems to work well. I’ll have to wait for some dark night to see how effective they actually are in the plane. I’m actually more concerned about having too much light. But so far it appears that I can dial it down far enough to not overpower my night vision.
Paul A. Fisher
RV-7A N18PF
Sent: Tuesday, April 02, 2013 2:12 PM
Subject: LED strip lighting for panels
to these.
… snip … [quote] [b]
PostPosted: Tue Apr 02, 2013 12:08 pm    Post subject: LED strip lighting for panels Reply with quote
At 02:35 PM 4/2/2013, you wrote:
Bob,
Not necessarily. The LED strip lights come with resistors
built in . . . these resistors combined with
minimum voltage necessary to get first light offers
an opportunity to dim either way. You wouldn't necessarily
want to do this to 'dim' high power leds . . . but the sum
total of power for a few feet of strip lets us consider
the linear, noise free option.
fvalarm(at)rapidnet.net
PostPosted: Tue Apr 02, 2013 12:33 pm    Post subject: LED strip lighting for panels Reply with quote
I used very similar lighting strips in my RV7A. At the the time the only place I found them was on Ebay from HongKong, but shipping was cheap. These work well with a two channel dimmer I already had from Steinair. One channel is used for the incandescent and the other for the LED strips as they dim as a different rate. I'm very happy with the results and would have bought from B n C if they stocked it.
I would also have bought the dropping resistors from B no for the wigwag flasher but they don't stock them. nudge nudge.
Bevan
Sent: Tuesday, April 02, 2013 12:12 PM
to these.
length.
drawing
product.
Bob . . . [quote]
Gilles.Thesee(at)ac-greno
PostPosted: Tue Apr 02, 2013 2:41 pm    Post subject: LED strip lighting for panels Reply with quote
to these.
Hi Bob and all,
Just for the fun, this is what we did.
(Hope attachments are allowed).
Best regards,
Gilles
http://contrails.free.fr
 Filesize:  29.12 KB
 Viewed:  5757 Time(s)
bicyclop(at)pacbell.net
PostPosted: Thu Apr 04, 2013 11:29 am    Post subject: LED strip lighting for panels Reply with quote
Bob,
Is the DIM5-14 the same item as in your drawing and can be modified for dimming the led strip lights by replacing resistors as you suggest?
Ed Holyoke
On 4/2/2013 12:12 PM, Robert L. Nuckolls, III wrote: [quote] If your airplane has a glare shield, you can
to these.
length.
drawing
product.
wynaire(at)citlink.net
PostPosted: Thu Apr 04, 2013 12:15 pm    Post subject: LED strip lighting for panels Reply with quote
FWIW: There are Ebay sites {China} now offering inexpensive LED dimmers, for stirp lighting. One is one it's way here. If it smokes, I will post the peticulars. As always, thanks for your advice.
Mike W.
PS: Now looking for an "inexpensive" CS prop governor for a Lyc IO-360 AV. Anyone building one in his shop? Wink)
Sent: Thursday, April 4, 2013 1:29 PM
Subject: Re: AeroElectric-List: LED strip lighting for panels
Bob,
Ed Holyoke
to these.
length.
drawing
product.
holger-d(at)shadowbrush.c
PostPosted: Thu Apr 04, 2013 1:28 pm    Post subject: LED strip lighting for panels Reply with quote
I have two of those $6 dimmers on order also. Others have already reported success using them in the RV forum.
Holger
On Apr 4, 2013, at 10:14 PM, wynaire(at)citlink.net (wynaire(at)citlink.net) wrote:
[quote]FWIW: There are Ebay sites {China} now offering inexpensive LED dimmers, for stirp lighting. One is one it's way here. If it smokes, I will post the peticulars. As always, thanks for your advice.
Mike W.
crabandy(at)yahoo.com
This is what was recommended by other builders, Kick KR6 $15-$20 on ebay. I haven't "fired" it up yet....
http://www.kicklighting.com/Kick-Lighting-KR6.pdf
From: "wynaire(at)citlink.net" <wynaire(at)citlink.net>
To: "aeroelectric-list(at)matronics.com" <aeroelectric-list(at)matronics.com>
Sent: Thursday, April 4, 2013 3:14 PM
Subject: Re: LED strip lighting for panels
Mike W.
Bob,
Ed Holyoke
to these.
length.
drawing
product.
