crabandy(at)yahoo.com Guest
Posted: Tue Apr 02, 2013 6:57 am Post subject: Ebus Diode |
The drawing http://www.bandc.biz/pdfs/Diode_Installation.pdf
From B and C shows both ~ (I don't have the correct symbol horizontal s with -) terminals powered from the main bus with the + going to the Ebus and - unused.
Question: I could run power from the main bus to either ~ terminal and power the Ebus?
Powering both ~ terminals gains a little redundancy to power the Ebus?
Andy
kuffel(at)cyberport.net Guest
Posted: Tue Apr 02, 2013 8:16 am Post subject: Ebus Diode |
Andy,
<< Question: I could run power from the main bus to either ~ terminal and
power the Ebus? >>
Yes, but this misses the purpose of connecting both AC terminals (~) to the
source. The package has 4 diodes. It is used everywhere as an AC to DC
rectifier. In theory you could use one high current diode but the cost of
the same capacity is much higher than the 4 diode package due to the very
high economy of scale from the 4 diode configuration even though we are
"wasting" diodes. The mounting for this package is also simpler.
The main enemy of semiconductors is heat. With the connection to two
divides in parallel the current between them is divided, not evenly divided
but still shared between the two. This spreads out the heat generation
which makes the device more robust.
<< Powering both ~ terminals gains a little redundancy to power the Ebus?
As is hopefully explained above, the reason for using both ~ terminals is
spreading out the heat generation, not redundancy. If you have an Ebus
current of 15 amps, even if one diode carries 10 amps and the other only 5
amps, you are stressing the part less than having all 15 amps going through
1 diode. In other words, there is a good reason for connecting the source
to both ~ terminals which is what you should do.
Tom Kuffel
Posted: Tue Apr 02, 2013 9:22 am Post subject: Ebus Diode |
Great explanation!
Andy
On Apr 2, 2013, at 11:13 AM, "The Kuffels" <kuffel(at)cyberport.net> wrote:
Andy,
<< Question: I could run power from the main bus to either ~ terminal and power the Ebus? >>
Yes, but this misses the purpose of connecting both AC terminals (~) to the source. The package has 4 diodes. It is used everywhere as an AC to DC rectifier. In theory you could use one high current diode but the cost of the same capacity is much higher than the 4 diode package due to the very high economy of scale from the 4 diode configuration even though we are "wasting" diodes. The mounting for this package is also simpler.
The main enemy of semiconductors is heat. With the connection to two divides in parallel the current between them is divided, not evenly divided but still shared between the two. This spreads out the heat generation which makes the device more robust.
<< Powering both ~ terminals gains a little redundancy to power the Ebus? >>
As is hopefully explained above, the reason for using both ~ terminals is spreading out the heat generation, not redundancy. If you have an Ebus current of 15 amps, even if one diode carries 10 amps and the other only 5 amps, you are stressing the part less than having all 15 amps going through 1 diode. In other words, there is a good reason for connecting the source to both ~ terminals which is what you should do.
Tom Kuffel
Posted: Tue Apr 02, 2013 10:16 am Post subject: Ebus Diode |
At 09:56 AM 4/2/2013, you wrote:
| Quote: | The drawing http://www.bandc.biz/pdfs/Diode_Installation.pdf
Powering both ~ terminals gains a little redundancy to power the Ebus? |
No 'redundancy' just a potential tiny improvement in
thermal modeling. Not a big deal one way or another.
Run main bus power to either one or both AC input
terminals, one wire from (+) to e-bus.
Bob . . . [quote][b]
james(at)etravel.org Guest
Posted: Wed Apr 03, 2013 4:32 am Post subject: Ebus Diode |
On a related note, is there a way to determine if a heatsink is large enough? Â
I made a heatsink out of some scrap .020" aluminium -- half a dozen pieces of varying lengths, stacked and folded up at the ends to form fins. Â I've bolted it under the rectifier with some heatsink paste. Â
Seems like quite a lot of aluminium, and plenty of surface area, but it would nice to find a way of evaluating its effectiveness... other than waiting for the smell of burning semiconductor...
Many thanks,Â
James
On 2 April 2013 16:38, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
 Bob . . . | Quote: |
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
Posted: Wed Apr 03, 2013 5:54 am Post subject: Ebus Diode |
At 07:31 AM 4/3/2013, you wrote:
| Quote: | On a related note, is there a way to determine
What are your e-bus normal running loads?
I would not expect loads of 10A or less to
call for anything other than to simply mount
the diode a metal surface in the airplane.
I could run some tests here for higher currents
but keep in mind that the e-bus is for 'endurance'
loads . . . minimal equipment to conduct the
en route phase of flight . . . reduced energy
demands to save the battery for approach to
landing.
I suggested that big fat diode because of it's
convenience for mounting and wiring. The fact that
it is rated for 25 or 35 amps was in no way intended
to suggest that e-bus loads should/could be
that large.
The e-bus is a risk reduction feature that is
not likely to be needed more than once over the
lifetime of your airplane. It's a feature that
offers a degrees of System Reliability that
reduces probability that a main alternator failure
will cause you to break a sweat.
As a renter, I have never enjoyed access to features
that we're building into OBAM aircraft. My personal
endurance package was carried around in the flight
bag. http://tinyurl.com/d5mrjgh
In fact, I've not turned a VOR receiver on in nearly
20 years. Not since I discovered the capabilities
of hand-held GPS receivers that were so cheap I could
give them away as door prizes at my seminars! My last
cross-country sojourns were managed with dual
GPS receivers stuck between the glare-shield and
windshield with little wads of windshield sealant.
It didn't matter if the airplane was a J-3 or A-36,
I was confident in my ability to get from point A to
Point B whether the ship's electrical system was
fully functional or not. That's a high degree of
failure tolerance and system reliability.
Posted: Wed Apr 03, 2013 6:42 am Post subject: Ebus Diode |
Thanks Bob, I have a theoretical max load of a little under 7A.Â
I agree with your sentiments about the essential bus. Â I don't anticipate needing it... but it's nice to know that it's there...
James
On 3 April 2013 14:52, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | On a related note, is there a way to determine if a heatsink is large enough? Â
  landing.
  that large.
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
e -
rickofudall
Posted: Wed Apr 03, 2013 7:36 am Post subject: Ebus Diode |
James, One of these should give you some numbers to play with to see how well your heatsink is working as you ebuss is loaded up.
http://www.harborfreight.com/infrared-thermometer-with-laser-targeting-non-contact-69465.html
Harbor Freight has a coupon out this month that reduces the price a further $10 to $25.99.
Just a thought
Rick Girard
On Wed, Apr 3, 2013 at 9:41 AM, James Kilford <james(at)etravel.org (james(at)etravel.org)> wrote:
| Quote: | Thanks Bob, I have a theoretical max load of a little under 7A.
I agree with your sentiments about the essential bus. I don't anticipate needing it... but it's nice to know that it's there...
James
| Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
landing.
that large.
MS -
e -
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Posted: Wed Apr 03, 2013 8:31 am Post subject: Ebus Diode |
At 09:41 AM 4/3/2013, you wrote:
| Quote: | Thanks Bob, I have a theoretical max load of a little under 7A.Â
Very good. No 'extra' heat sinking necessary.
Just bolt it to a metallic surface.
Posted: Wed Apr 03, 2013 8:46 am Post subject: Ebus Diode |
Well, that's more tricky. The firewall on this plane (Jodel) is a
sandwich of plywood and balsa... so I'm hoping the heatsink will
suffice. Worse-case scenario -- I could move the diode to the engine
compartment side of the firewall, which is covered with a thin sheet
of stainless steel.
James
On 3 April 2013 17:29, Robert L. Nuckolls, III
<nuckolls.bob(at)aeroelectric.com> wrote:
Posted: Wed Apr 03, 2013 10:17 am Post subject: Ebus Diode |
At 11:45 AM 4/3/2013, you wrote:
of stainless steel.
Hmmmm . . . okay. The heat sink you built
up from sheet metal will be fine. Don't
move it to the other side of the firewall.
dean.psiropoulos(at)veriz Guest
Posted: Wed Apr 03, 2013 5:27 pm Post subject: Ebus Diode |
If you want true redundancy then just use two rectifiers in parallel. When
I built my panel I ended up with a full IFR radio stack on the Ebus and some
other items that, together, take quite a bit of current. Not wanting to
risk over-taxing the single rectifier or reduce its life by running it near
maximum all the time, I simply installed a second one in parallel with the
first. I also mounted them to 1/16 inch thick aluminum brackets fastened to
the bulkhead behind the instrument panel to keep them as cool as possible.
Probably overkill but, so far so good.
Dean Psiropoulos
RV-6A N197DM
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Thu Apr 04, 2013 4:50 am Post subject: Re: Ebus Diode |
I've been selling these for a decade. My newest version can be used as two parallel, a Y-configuration or just a big diode. Heatsink included. See attached.
Power_Deuce_Schottky_ Manual.pdf |
241.64 KB |
336 Time(s) |
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Thu Apr 04, 2013 5:59 am Post subject: Ebus Diode |
At 08:25 PM 4/3/2013, you wrote:
<dean.psiropoulos(at)verizon.net>
Actually, if you want redundancy for a failed
diode, you would want to wire them in series.
Diodes generally fail shorted. So having a good
diode in parallel would a bad one would not
mitigate the failure. But of course, diodes in
series doubles the voltage drop and that's not
high on our list of design goals.
As long as they're adequately heat-sinked,
the diode will outlast the airplane. If
not heat adequately sinked, life expectancy
is short.
The first 'crowbar' ov protection system to
go into a TC aircraft can be found on the AA-1
Yankee. Alternator field was supplied through
a 3 or 5 amp glass cartridge fuse. I don't
recall which right now. Downstream of the fuse
they wired a 15 volt, 1-watt, glass zener to
ground.
In an ov condition, the zener was driven into
destructive conduction, it's junction melted
and shorted the field supply downstream of the
fuse. Crude but it did work . . . with limitations.
I ran some tests on this configuration
at Electro-Mech after an OEM engineer asked me
about it . . . I think it was a guy at Mooney.
Sure 'nuf. Fault the regulator, bus votlage jumps,
zener discolors and turns black, fuse pops, event
over. MUCH slower than legacy OV protection systems
that operate in tens of milliseconds . . . but
certainly better than no OV protection.
I heard of variations on the theme that proved
unsatisfactory . . . like replacing the fast-fuse
with a slow-blow. Or replacing the zener with
its plastic cousin. Plastic zeners and diodes
like to blow apart when fused.
There was an alternator supplier at OSH one year
who advertised "built in OV protection".
Some guy came by the B&C booth to tell me about
it . . . he was skeptical. I walked over to see
what was being offered. Without introducing myself
I asked the vendor to tell me all about it. It
pointed to a plastic, 1-w zener wired across the
alternator's B-terminal to ground. I took some
literature and thanked him for the info.
Some time later, somebody on the Compuserve
AVSIG forum was asking about this same product.
He said his alternator went bad and his OV
protection 'disappeared' without having done
it's job. Upon further inquiry, he said the
little wires were still there . . . just the
black plastic part was gone.
This was an internally regulated alternator
and could not be easily fitted with OV protection.
Certainly the little glob of plastic was not
up to the task.
mrspudandcompany(at)veriz Guest
Posted: Thu Apr 04, 2013 10:32 am Post subject: Ebus Diode |
| Quote: | I've been selling these for a decade. My newest version can be used as two
attached.
Eric M. Jones
Eric,
In looking at your attached diagram, it is my assumption that you are using
the diodes to supply power to critical for flight devices. My thought is
that you would be much better off using 2 fuel pumps and 2 ECU's each
running through their own switches to separate batteries and eliminate the
diodes. This is a little more costly but my thinking is that it will
increase your safety factor by an order of magnitude. Am I wrong on this
approach?
Roger
Posted: Wed Apr 10, 2013 4:38 am Post subject: Ebus Diode |
Thanks Rick. A handy device and good price too. Not sure it would
make sense getting it across the pond, but I note that similar devices
are available for about the same money. It could be a useful and
interesting investment.
James
On 3 April 2013 16:35, Richard Girard <aslsa.rng(at)gmail.com> wrote:
| Quote: | James, One of these should give you some numbers to play with to see how
$10 to $25.99.
Just a thought
Rick Girard
> James
>>> enough? Â
>> landing.
>> that large.
>> Bob . . .
>> ric-List"
>> MS -
>> e -
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Thanks Bob. I'll give it a check with the Eric finger temperature scale too.
On 3 April 2013 19:14, Robert L. Nuckolls, III
> of stainless steel.
henador_titzoff(at)yahoo. Guest
Posted: Wed Apr 10, 2013 5:17 am Post subject: Ebus Diode |
Everyone,
It isn't given on the website below what this device's temperature range is, so I downloaded the manual. Here are the specs:
- Measurement Range: -36F to 968F (-38C to 520C)
- Accuracy: ±2% above 32F, ±4.5% below 41F
If you have uncalibrated fingers, this may be the way to go.
Henador Titzoff
Sent: Wednesday, April 10, 2013 8:38 AM
Subject: Re: Ebus Diode
--> AeroElectric-List message posted by: James Kilford <james(at)etravel.org (james(at)etravel.org)>
James
On 3 April 2013 16:35, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
$10 to $25.99.
Just a thought
Rick Girard
> James
>>> enough? Â
>> landing.
>> that large.
>> Bob . . .
>> ric-List"
>> MS -
>> e -
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
>ectric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-Lista href="http://forums.matronics.com/" target="_blank">http://forums.mat &nbs//www.matronics.com/contribution" target="_blank">http://www.matronics.co==================
edpav8r(at)yahoo.com Guest
Posted: Wed Apr 10, 2013 8:28 am Post subject: Ebus Diode |
I bought one of these on eBay not too long ago for even less (delivered) than HF's price. The one I got has a lighted display, C and F temp displays, on/off selectable laser aiming spot, display hold button and temp range of -50C to 380C. It even came with a 9V battery. Works beautifully.
Make and model are "SainSonic SS5380".
This [http://bit.ly/10LgGez ] and this [ http://bit.ly/10V8tnP ] have different markings but appear otherwise identical, right down to the brand of battery.
Eric
On Apr 10, 2013, at 5:38 AM, James Kilford <james(at)etravel.org> wrote:
| Quote: | Thanks Rick. A handy device and good price too. Not sure it would make sense getting it across the pond, but I note that similar devices are available for about the same money. It could be a useful and interesting investment.
James
> Just a thought
> Rick Girard
Posted: Wed Apr 10, 2013 9:17 am Post subject: Ebus Diode |
Thanks Eric. Appreciate the update.
On 10 April 2013 17:27, Y! edpav8r <edpav8r(at)yahoo.com> wrote:
Eric
> James
>> Just a thought
>> Rick Girard
