24x7diy LED noise experiment (update)
holger-d(at)shadowbrush.c
PostPosted: Mon Mar 11, 2013 7:39 pm    Post subject: 24x7diy LED noise experiment (update) Reply with quote
Hi Bob, all,
Do you have an update on this project? I tried to follow the thread back to the start, but couldn't quite. Are you testing with these lights:
http://24x7diy.com/product_info.php/products_id/94
Are they emitting RF noise? A friend of mine installed lights similar to these:
http://www.ebay.com/itm/170941144735?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
He reports no discernible RF noise.
I was considering a pair of these for installation into the cowling:
http://www.ebay.com/itm/2x-40W-Work-Light-Flood-Spot-Lamp-Offroad-Truck-Mining-Boat-4WD-UTE-SUV-12V-24V-/150974253408?clk_rvr_id=458017945559&mfe=sidebar
One flood (60˚), another spot (30˚). The flood light could stay turned on at all times as collision protection.
Thank you,
Holger (the removable antenna guy)
On Feb 25, 2013, at 1:07 PM, Robert L. Nuckolls, III wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
The first-pass filter I crafted last week
only offers about 12 dB of attenuation of
noises in the VHF Comm spectrum. I've got
some tubing ordered that will let me
'box up' the filter components and bring
power connection out to a connector.
Working on plan-b.
========= PLAN B ===========
Wasn't able to put my hands on the tubing
I wanted but I ordered an alternative today
which is coming out of Oklahoma. Hope
to get a more effective filter crafted
shortly.
PostPosted: Tue Mar 12, 2013 6:46 am    Post subject: 24x7diy LED noise experiment (update) Reply with quote
At 10:38 PM 3/11/2013, you wrote:
Hi Bob, all,
Adapting commercial-off-the-shelf (COTS)
products into alternative environments comes
with some risks. Fortunately risks are very
low for the LED lighting experiments. One
first looks for a source of adequate light
output. After finding a suitable candidate,
is it easily mounted to the aircraft? Finally,
does it produce noise that exceeds limits for
your design goals?
For some builders, no amount of noise is a
big deal, no so for others.
The 23x7diy products are nicely packaged,
they DO produce a non-quantified level of
noise that the builder believed was problematic
and there's a nice recess at the rear of the
housing conducive to a well considered
installation of a filter. The last of the
materials I need came in the mail yesterday
so I'll proceed with the filter project for
these lamps.
The fixture you cited will have to go through
the same processes. First see if the light
output is adequate to your needs. I used to
shine a 6v fisherman's lantern around the
attendees of my seminars while asking them
to consider if the light output was sufficient
for night landings. I suggested that I'd
be willing to duct-tape it to my J-3's
struts and demonstrate adequacy to the task.
That was a 3-watt landing light!!! Bottom
line is that it takes very little total
light to assist you in conducting greasers on
the otherwise dark terra firma.
Then see if the noise (there is ALWAYS
emitted noise) is too much for your
situation, If too much, then you go after
it as a separate but final issue.
PostPosted: Tue Mar 12, 2013 8:41 am    Post subject: 24x7diy LED noise experiment (update) Reply with quote
On Mar 12, 2013, at 7:44 AM, Robert L. Nuckolls, III wrote:
The last of the
these lamps.
Thank you for your response, and update on your noise filter project. I'll wait to hear from your further findings. No noise would allow leaving the lights on for collision protection.
Also, I'm interested in as much light as I can get for an emergency off-field landing and when taxiing around in the dark.
Thanks!
Holger
PostPosted: Tue Mar 12, 2013 9:27 am    Post subject: 24x7diy LED noise experiment (update) Reply with quote
At 11:40 AM 3/12/2013, you wrote:
--> AeroElectric-List message posted by: Holger Selover-Stephan <holger-d(at)shadowbrush.com>
> The last of the
> these lamps.
Keep in mind that my work here is on one product
based on non-quantified perceptions of noise.
The owner of these lights complained about it,
I could detect it here and have a plan for
attenuating it . . . but just how much noise
is created compared to contemporary limits for
qualification onto a type certificated aircraft
cannot be known without going to the lab.
The fact that this particular product produced
detectable noise is not a guarantee that (1)
contemporary qualification limits will be achieve
with my experiments nor (2) does it guarantee
that user perceptions of noise will be driven
below acceptable limits.
Filters are NEVER 100.000% effective.
They are attenuators tailored to reduce noise
to acceptable levels which is never zero. For
example, here's a plot of the noise from a blower
motor that was tearing up the ADF on a King Air
after I crafted a filter for it.
All I had to do was get the noise below the limit line
. . . in this case the filter was exceedingly effective.
But had my efforts produced a plot that was still
trashy out to 30MHz, all I have to do is get
below the limit line.
[img]cid:.0[/img]
Until we do similar investigations for our experiments,
the best we can expect is: "This experiment reduced noise
to the point where the customer doesn't care about what's
left over." It may still fail miserably in the DO-160
lab. Just because the original observer is satisfied with
the outcome does not mean all future observers will share
the perception.
Okay, your design goals call for LOTS of light
but in situations that may amount to 0.0001%
and 1.0% of total operations respectively.
These may be situations wherein noise is the
last of your worries.
 Filesize:  30.65 KB
 Viewed:  9844 Time(s)
PostPosted: Tue Mar 12, 2013 8:26 pm    Post subject: 24x7diy LED noise experiment (update) Reply with quote
I think my expectations, or I should rather say: hopes, are in line with this. My aircraft is not type certified, and if there's a little noise during short-timed operation, I'll take that over paying several hundred dollars for one of the aviation lights, which might not fare all that much better even.
Interesting what you say. And I think I follow, aided by a background in science in my gray past, alas in a different field.
the perception.
OK, fair enough. My investment is time while waiting for another report from you, and some $150 for the lights. Should I, and maybe others, contribute to expenses of this experiment? Having an off-the-shelf, sub $200 landing light pair should be of interest to a few others as well. And yes, no guarantee for noise levels.
Agreed, in the case of an off-field landing and taxiing, noise isn't a great concern. But not so for the always-on flood light, and admittedly, that's a nice-to-have.
Holger
PostPosted: Wed Mar 13, 2013 7:07 am    Post subject: 24x7diy LED noise experiment (update) Reply with quote
I don't think there's much value in waiting
for me or anyone else to put a band-aid on
any particular COTS offering for lights.
That market is evolving very rapidly and as
OBAM aviation participants, limiting our
selection of products to those which have
be successfully 'bandaged' is counter-productive.
I think I've written on these pages numerous
times that I've never encountered a noise
problem that couldn't be whipped. With that
assertion in mind, I would encourage folks
to try anything that floats their boat. If
it produces light sufficient to your needs
then let's tackle noise problems as a separate
issue.
Dollars is not the limiting factor for my
efforts, it's time. Further, the time thing
is more involved than having a clear bench
or wrestling with procurement delays. The
elegant solution has to be tempered against
the tools I have to produce it along with
trading out assembly methods and techniques.
I can tell you that what I'm carving on now
for the 24x7diy assemblies is in its third
generation.
The risk is that once the elegant solution
for 24x7diy is achieved, they might go out
of business or something better might come
along. That's the down-side of OBAM aviation.
Things done on the TC side of the house tend
to become carved in stone. Some of my designs
at Electro-Mech are still in production after 30
years. Many of those out of production were
canned because critical components are not made
any more!
Things we do in OBAM aviation are more likely
to be pushed overboard because something better
came along, not because critical parts have
reached end of market life. It's a different
ball game entirely.
So I would advise you to search out and
try lighting products that meet your design
goals . . . let's whip what ever noise issues
arise later.
Tundra10
PostPosted: Wed Mar 13, 2013 7:12 am    Post subject: 24x7diy LED noise experiment (update) Reply with quote
It occurs to me that we could do a HID version
of this flasher that automatically forces a
one-minute warm up period before allowing wig-wag
operations to commence.
XeVision has a patent on the "technique" of delaying flashing until
the lamps have warmed up.
http://xevision.com/hid_pulsing.html
Many of their ballasts have a control input that allows flashing
without switching the power to the ballast.
Jeff Page
Dream Aircraft Tundra #10
PostPosted: Wed Mar 13, 2013 10:36 pm    Post subject: 24x7diy LED noise experiment (update) Reply with quote
OK, understood, Bob. If it's that much of a moving target. I'll pipe up again when I have the lights and checked for noise.
Very much appreciate the time you took to explain the situation.
Holger
PostPosted: Fri Mar 22, 2013 2:31 pm    Post subject: 24x7diy LED noise experiment (update) Reply with quote
Bob, I ordered this light now:
http://www.ebay.com/itm/221136934512?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
..and will report my findings after returning from a trip abroad in a few weeks. This one had the most light output for the size I can fit into the cowling.
Holger
ceengland7(at)gmail.com
PostPosted: Fri Mar 22, 2013 4:03 pm    Post subject: 24x7diy LED noise experiment (update) Reply with quote
...and will report my findings after returning from a trip abroad in a few weeks. This one had the most light output for the size I can fit into the cowling.
Holger
Hi Holger,
I hope it works; that isn't a bad price for that power. However, it does
claim to be a 'flood' light. Got to wonder if it will have too wide a
spread to get enough throw to use as a landing light.
Charlie
PostPosted: Fri Mar 22, 2013 10:00 pm    Post subject: 24x7diy LED noise experiment (update) Reply with quote
On Mar 22, 2013, at 5:03 PM, Charlie England wrote:
Hi Holger,
I hope it works; that isn't a bad price for that power. However, it does claim to be a 'flood' light. Got to wonder if it will have too wide a spread to get enough throw to use as a landing light.
Charlie
Hi Charlie,
Good to hear from you! I wanted flood lights after seeing LED light "shoot outs" posted somewhere. Tail dragger driver here, I need some light on the runway edges. And at 40W LED, I hope the throw will be adequate. I'll let you know how they work out.
Holger
PostPosted: Sat Mar 23, 2013 10:23 pm    Post subject: 24x7diy LED noise experiment (update) Reply with quote
The light arrived today. I'm very pleased with the output and the distance. It does emit RF noise, drowning out an Icom A6 with the squelch turned down to level 8 and held closer than 5 ft. WX transmissions are still clear even with the radio right next to the light. No idea that means trouble later in flight. I may just take it up and turn it on to try it out.
The other thing is, it's fairly heavy: 1lb 12oz. I'll open it up to see if a lighter heatsink can be made for it. I'll report again in a few weeks.
Holger
PostPosted: Sun Mar 24, 2013 8:27 am    Post subject: 24x7diy LED noise experiment (update) Reply with quote
A couple more information about this light: it's sealed and I don't see a way of opening it up and closing it without damage to the case. I may do it anyway to do something about the weight. Also, the packaging reveals they come with these beam angle: 20˚, 30˚, 40˚, 60˚ and 120˚. I have the 40˚, and that may actually be the best option for a landing light. The manufacturer appears to be "Advanced German Technology - AGT", and the model number "SZW-SM12317: http://i.imgur.com/AEIcNNe.jpg
Holger
Holger
PostPosted: Sun Mar 24, 2013 12:32 pm    Post subject: 24x7diy LED noise experiment (update) Reply with quote
Hi Holger,
Thanks for the update; that's useful info. I'd love to hear about a
side-by-side comparison with one of the common homebuilt lights, and
with the 'stock' aviation landing light. If you have one of the older
systems to do the comparison, please post the results.
Charlie
Holger
> Holger
PostPosted: Sun Mar 24, 2013 1:58 pm    Post subject: 24x7diy LED noise experiment (update) Reply with quote
On Mar 24, 2013, at 1:25 PM, Charlie England wrote:
Hi Holger,
Thanks for the update; that's useful info. I'd love to hear about a side-by-side comparison with one of the common homebuilt lights, and with the 'stock' aviation landing light. If you have one of the older systems to do the comparison, please post the results.
Charlie
Hi Charlie,
Yes, I have a PAR-36 light here, and will point both lights down the runway when I'm back in town in 2-3 weeks.
Holger
