Something New!!!!!!
NeilsenRM(at)comcast.net
PostPosted: Fri Jun 09, 2006 8:22 pm    Post subject: Something New!!!!!! Reply with quote
I have a redrive VW powered MKIIIc that I'm trying to design a trailer for.
I have been trying to figure a easy/light way that I could build a
bracket/cart/something that I could clamp the tail boom to then fold the
wings and set them into this cart. Then with a electric winch just pull the
plane up and into the trailer. I want it easy to get the plane in and out of
the trailer.
I have a Toyota Mini Van that I have as a tow vehicle. I have a single axel
boat trailer that is light and long enough to do the job but the design
escapes me. Originally I had planned a cart the would run on rollers on a
tracks on the inside/sides of the trailer with track extensions so that the
plane could be connected and the wings folded easily before loading.
My latest idea is one track attached to the inside center top of the trailer
with a extension six to ten feet beyond the back of the trailer with slings
to hold the tail and wings. I would then winch the plane into the trailer.
The trailer will be 5' 6" wide at the back to accommodate the prop and
fuselage. At app. 6 ft from the back it will start to taper to about 2' 6"
at the front. The enclosure frame will be made from 1.5 to 2 inch steel
conduit then covered with corrugated steel roofing material.
I have been taking photos and looking at everyone else's ideas but I just
don't have what I feel is the good design. Any suggestions would be
appreciated.
Rick Neilsen
Steve Boetto
PostPosted: Sat Jun 10, 2006 6:03 am    Post subject: Something New!!!!!! Reply with quote
In a message dated 6/10/2006 12:28:04 A.M. Eastern Standard Time, NeilsenRM(at)comcast.net writes:
Rick,
I would not haul your MKIII backwards. I tried several configurations with my Firefly on floats. It is easier to load backwards but the plane takes a beating. I currently have FF#007 in an enclosed trailer (nose first). I have a $50 electric winch that I got at Harbor Freight. It pulls the airplane in very easy.
Steve Boetto
FF#007 on floats
Dave Pelletier
PostPosted: Sat Jun 10, 2006 6:32 am    Post subject: Something New!!!!!! Reply with quote
Steve,
    I have a MKIII and it loads into my enclosed trailer backwards.  I don't have any choice since whoever made the trailer designed it with a long, pointy nose so that's the only way my plane will fit.  But I don't understand why/how the plane would take a beating just because it is in the trailer a different way.  Couldja explain please!
AzDave
Rick,
Steve Boetto
FF#007 on floats
AzDave
Steve Boetto
PostPosted: Sat Jun 10, 2006 6:59 am    Post subject: Something New!!!!!! Reply with quote
In a message dated 6/10/2006 10:33:47 A.M. Eastern Standard Time, pelletier(at)cableone.net writes:
Steve,
AzDave
Dave, good point
 I assumed that Rick was talking about an open trailer.
Steve
PostPosted: Sat Jun 10, 2006 9:37 am    Post subject: Something New!!!!!! Reply with quote
Thanks All
Steve: I all ready have a trailer and it will be enclosed.
Will: The photos are great. I particularly liked the kneeling trailer.
The attached photo shows my boat trailer that I'm converting to a Kolb hauler. Note the brackets below the lights. The main gear will sit on the brackets when loaded and the wheels will be out in the open outside the trailer enclosure. I will be keeping the plane at a small airport community/county grass strip in Florida 4-5 months a year. They don't have many hangers and don't allow any on the airport grounds. I will keep my plane in the trailer while I'm down there. When parked I will take the wheels off the trailer and the main gear brackets will sit on the ground.
My problem is the enclosure and a system to get the plane in and out of the trailer with the least effort.
Rick Neilsen
Redrive VW powered MKIIIc
 Filesize:  102.09 KB
 Viewed:  568 Time(s)
Steven Green
PostPosted: Sat Jun 10, 2006 6:33 pm    Post subject: Something New!!!!!! Reply with quote
Rick,
This is what I use. If you are interested in more detail I will send you
more photos off list.
Steven Green
for.
the
of
the trailer.
axel
the
trailer
slings
appreciated.
Rick Neilsen
 Filesize:  38.82 KB
 Viewed:  557 Time(s)
Steven Green
Bob Dresden
PostPosted: Tue Jun 13, 2006 8:10 am    Post subject: Something New!!!!!! Reply with quote
Steve, Think of that trailer as a beam with one end secure and a spring
in the middle, not unlike a diving board. The secure end, the ball,
moves very little, the springs have a fixed travel, so you can see
where this is all going. The rear travels quite a bit. A G meter
would tell the ultimate story. In your case a good set of shocks is
about the best solution. I am still in the process of designing my
trailer with a forward loading and some semblance of streamlining.
Bob Dresden Lurker
Back in the closet
Steve Boetto
PostPosted: Tue Jun 13, 2006 11:24 am    Post subject: Something New!!!!!! Reply with quote
In a message dated 6/13/06 2:09:52 PM Central Daylight Time, bdres(at)zirkel.us writes:
Bob Dresden  Lurker
Back in the closet
Thanks Bob,
But that was not the problem.  The I beam aluminum trailer was quite stiff and the axe placement was far aft. The stock 3500 lb torsion axle was replace with a special 1500 lb torsion axle.  The trailer hauled as smooth as silk.  The problem was on an open trailer the wind moving across a backwards Kolb beats up the tail feathers. I guess it is the reason that seagulls always stand Beak to the wind.
Steve
slyck(at)frontiernet.net
PostPosted: Tue Jun 13, 2006 11:42 am    Post subject: Something New!!!!!! Reply with quote
My, what a well mannered lurker! We need more like you.
One thing that will help smooth a ride on any vehicle is to design it
in a near full-loaded condition. Shocks will help prevent bottoming
out impact damage but when you get that airplane in there, stick in
and tie down enough extra weight to get close to a full load.
It took a long time to do it but auto designers finally realized that a
light car could be designed to ride as well as a luxury car as long as
the load was proper. -problem was the variable between solo and
four fat guys on board.
-BB do not archive
spring in the middle, not unlike a diving board. The secure end, the
ball, moves very little, the springs have a fixed travel, so you can
see where this is all going. The rear travels quite a bit. A G meter
Bob Dresden Lurker
Back in the closet
http://wiki.matronics.com
Richard Swiderski
PostPosted: Wed Jul 05, 2006 7:51 pm    Post subject: Re: Something New!!!!!! -Evolution Of a Kolb Trailer Reply with quote
Hello Rick,
I was out of the country for a month touring Poland (Hey Big Lar, I've got over 1200 pictures for you next time you pay me a visit!) so I am late posting. I have thought long and hard on how to best build a Kolb trailer pulled by a light 6 cylinder vehicle with 150 lbs max tongue wt. I have photographed & studied many smart people's designs and I believe I have combined the best ideas into an almost ideal trailer. The heart of the design is the basic concept of Dennis Souder's open air trailer I was thrilled to look at. He used a boat trailer with a rail down the center to guide & hold tailwheel & tail feathers up front. The brillance of the design was he had a dropped floor for the plane's wheels immediately behind the trailer's axle & only a few inches off the ground. It did not hit/drag on the ground because it was so close to the axle. That low height, meant you only had to lift the plane a few inches off the ground (translates easy to load!) When you use that concept in an enclosed trailer, it also eliminates the problem of scraping the leading eadge of wings on trailer floor. This concept forces the tongue weight up unexceptable high when using an enclosure as the axle is so far aft. I solved this issue by using 2 axles far apart (can't use leaf springs here) this also cushioned ride because when one wheel went into a hole, the other one still holds the trailer side up. The 2 axles apart was not enough to keep the tongue wt below 150 lbs. The secret was incorporating a truss just in front of the front axle, then using this truss to winch up the tail boom at the H-section behind the engine. This took all the weight that the trailer saw on the tail wheel & put it back on the front axle. My trialer now has the same tongue weight with my plane loaded or unloaded. There are many other things that help to make thing better/easier/more comfortable that I could share with you if you care to give me call, 352-307-9009 (just south of Ocala FL), but the dropped floor for plane's wheels; the 2 spread axles; & the truss to hold off the tail's weight off from the front, are the keys to the puzzle. I went overboard in details on mine & could have made it lighter than it's 2000 lbs by quit a bit, but it pulls perfectly straight with no wagging & this last Sun & Fun, I actually used my 4 cyl Ford Escort to pull it at 60mph! It is very streamlined aerodynamically, front & back, plus low to ground. I'll try to attach a picture.
richard swiderski
slingshot 003 waiting for my TIG welder to come in ( I cut out her backbone so I could drop my 175 lb, 110hp, turbocharged, intecooled, distributorless, port injected, dual computered, 2.32 : 1 SPG-2 gear redive, 3 cyl Suzuki engine)
 Filesize:  290.58 KB
 Viewed:  596 Time(s)
