ATC slo blo?
fvalarm(at)rapidnet.net
PostPosted: Wed Mar 06, 2013 8:37 pm    Post subject: ATC slo blo? Reply with quote
Is there such a thing as a slow blow fuse in an ATC format (for a fuse
block)?
Bevan
racerjerry
PostPosted: Thu Mar 07, 2013 5:53 am    Post subject: Re: ATC slo blo? Reply with quote
NO. Slow Blow not available in ATC format. ATC, by specification, is a fast acting low voltage automotive blade type fuse.
Jerry King
PostPosted: Thu Mar 07, 2013 5:57 am    Post subject: ATC slo blo? Reply with quote
block)?
No. What is the situation for which you perceive
a need for such a fuse?
PostPosted: Thu Mar 07, 2013 9:28 am    Post subject: ATC slo blo? Reply with quote
Hi Bob,
My P-mag manual says to use a breaker or slow blow fuse. I have already
wired the P-mags to a fuse block (ATC) and my field of breakers is already
full.
So plan B will be to replace the switches that control the power to the
P-mags with switch-breakers (5 amp) and replace the fuses with a max high
value to protect the wire to the switch-breakers.
The fuse size to protect 18 AWG wire (about 5 foot long), 10 or 15 amp?
(fast acting ATC).
Bevan
RV7A
PostPosted: Thu Mar 07, 2013 10:21 am    Post subject: ATC slo blo? Reply with quote
OK,
Maybe my memory has been fading. To clarify, the P-mags instructions say to
use a breaker (in another area they suggest a pullable breaker) and a switch
to control power to the P-mags. I may have got the fuse idea from the
Z-drawings for electronic ignition. Anyway...
I currently have 5-amp fuses in the always hot battery bus feeding the P-mag
power control switches. These switches in turn feed the power inputs of the
P-mags.
So the easy fix would be to replace the switches with a switch/breakers, and
replace the fuses protecting the feed to the switch with a higher value ATC
such as 10-15 amp. It's a 18 AWG wire all the way from the fuse block to
the P-mags. Each P-mag has it's own independent circuit, fuse, wire and
switch.
Bob, I would like to use the highest value fuse possible ahead of the switch
breaker. It is not supposed to trip unless the wire to the switch faults
hard. Could this be 15 amp?
Bevan
PostPosted: Thu Mar 07, 2013 12:55 pm    Post subject: ATC slo blo? Reply with quote
At 12:19 PM 3/7/2013, you wrote:
--> AeroElectric-List message posted by: "B Tomm" <fvalarm(at)rapidnet.net>
OK,
P-mags.
switch.
I think you're getting wrapped around the worry-axle my
friend. A p-mag needs power only to get an engine started
and to operate at idle/taxi rpms. After that, it runs
nicely on internal power alone.
During any given tank full of fuel, what's the likelihood of loosing
all 4 power sources for the pair of p-mags? They're PM alternators.
Further, they take very little power from the bus. Ordinary 5A fuses
to the e-bus are plenty robust.
Referring to the Emagair literature we see:
[img]cid:.0[/img]
Current draw for this system at max RPM is only 0.25 amps! There are no
inrush currents associated powering up this system. From a systems perspective,
they would like to have +12 available all the time. There's no reason to 'switch
the supply on and off except to test the internal power source . . . which
is exceedingly reliable.
If it were my airplane, I'd run the p-mags from the e-bus through
5A fuses and no switches. Also, 20AWG wire is plenty robust. Treat
them just as you would a magneto for engine control and pre-flight
testing of ignition systems. Periodically check internal power sources
by powering the e-bus down and make sure the engine runs at
RPM above 1500 with the opposite system turned OFF. This checks
internal sources. Power the e-bus back up and check to see that
the engine will start with a single p-mag switched ON . . . then
check the other. This will spot a 'missing' dc power path. Do it
at each oil change interval.
I wouldn't spend a lot of time crafting a 'golden' source of
DC power. Risks to the aircraft and occupants due to loss of
any one feature is zero, risk for loss of all 4 in any 4-hour
period is vanishingly small.
 Filesize:  165.64 KB
 Viewed:  8592 Time(s)
bicyclop(at)pacbell.net
PostPosted: Thu Mar 07, 2013 4:19 pm    Post subject: ATC slo blo? Reply with quote
tim2542(at)sbcglobal.net
PostPosted: Thu Mar 07, 2013 8:03 pm    Post subject: ATC slo blo? Reply with quote
Ummm, check me but I'm pretty sure the power to the PMAG is protected with a pull-able breaker or other, but it does not run power thru the switch. Also, you want the power from the switched side of the master relay not the always hot bus as you indicated because the PMAG draws power even when switched off via the P lead.
The switch operates just as a P lead to kill the ignition, but it does not interrupt power to the unit.
A pull-able breaker is desired so you can check the internal alternator function as part of your run up. Pull the breaker, kill the other ignition and it should keep running.
One other tip, be sure to pull the breaker when using a battery charger, PMAGs have had problems and its mentioned in the manual.
Tim
On Mar 7, 2013, at 10:19 AM, "B Tomm" <fvalarm(at)rapidnet.net> wrote:
Anyway...
P-mags.
switch.
PostPosted: Thu Mar 07, 2013 8:07 pm    Post subject: ATC slo blo? Reply with quote
OK,
Thanks Bob,
I will leave things as they. Thanks for your time.
Bevan
Sent: Thursday, March 07, 2013 12:52 PM
Subject: RE: ATC slo blo?
OK,
P-mags.
switch.
[img]cid:593270504(at)08032013-355A[/img]
 Filesize:  165.64 KB
 Viewed:  8582 Time(s)
PostPosted: Thu Mar 07, 2013 9:13 pm    Post subject: ATC slo blo? Reply with quote
Thanks Tim.
I understand the drawing from Emagair, and Bob's comment makes sense to me.
I have a very non-standard (comprehensive) electrical system. It includes a
very small always hot bus located 6 inches from the battery. This bus
supplies power (via two independent circuits) to the P-mag power switches,
not to be confused with the magneto kill switches (which are part of the
keyed ignition). These switches must be turned on or the engine will not
start. These switches are the ones you would turn off to test the internal
alternators (periodically, not on each runup). They are also turned off at
the end of flight, otherwise the battery will run down.
This is how I have chosen to build my system and flows well with the rest of
my electrical system. I know it is not for everyone, but I have like the
way I have it.
My original question came up as I was told (and I believed) that the P-mags
should have a breaker/switch and not fuse/switch. With the very small
current flows according to Bob M, (the Emagair spec sheet does not indicate
current flow), and no unusually high inrush currents, fuses should be fine
as long as I also have switches to power down the mags.
On the other hand, my WigWag module (by Sound Off Signal) is solid state and
does require a fast acting fuse to protect the controller portion, but
that's a story for another day.
Bevan
PostPosted: Thu Mar 07, 2013 9:47 pm    Post subject: ATC slo blo? Reply with quote
Oh I see, sounds like we're on the same page then. I thought you were leaving them powered up from the way I read it.
Tim
On Mar 7, 2013, at 9:12 PM, "B Tomm" <fvalarm(at)rapidnet.net> wrote:
Thanks Tim.
way I have it.
Bevan
PostPosted: Fri Mar 08, 2013 6:26 am    Post subject: ATC slo blo? Reply with quote
The circuit protection philosophy and the means by
the circuit is controlled are separate issues. The
Emagair drawing suggests they might be combined but
it's one of many options.
The only utility for the switch is to be able to test
internal power for the emag . . . which means seeing
if the engine will run from a single mag that has been
deprived of battery power. This suggests that the
power path be controllable. Obviously, one can kill
the bus by simply turning the battery switch off. So
doing a periodic test of internal power for the Emags
is no big deal if one chooses to leave the suggested
switches out.
As a separate consideration, protecting any wire that's
tied to a high fault current source (alternator/battery
fed busses) is worthy of protection. Breakers or fuses
of several types may be considered in the development
personal design goals.
With the very small
current flow),
Note 4 of the image I purloined from the Emagair website
states a 20 mA idle current and 0.25A max running current.
What is your perception of need to "power down" the mags
by any means other than simply turning the 'mag switch' to
off?
Note 2 of the same image states that the DC supply is
switched only for the purposes of testing internal
power feature on p-mags. Just how that power is removed
is open to the spirit and intent of design goals. Given
the inherent reliability of the internal sources combined
with the fact that each source is but one of four sources,
any one of which will fly the airplane, the need for
counting all your marbles before each flight is unnecessary.
It follows that adding more switches on the panel for
the convenience of conducting a periodic test only
drives up parts count and relative panel clutter.
Fuses to protect hardware? Can you direct me to the
citation?
PostPosted: Fri Mar 08, 2013 10:02 am    Post subject: ATC slo blo? Reply with quote
Thanks Bob,
citation?
See the paragraph titled "WARNING".
http://sos-production.s3.amazonaws.com/images/ETHDSS-SP%20Fold%20A.pdf
It calls for fast a acting fuse, not a fusible link, slow blow or circuit
breaker.
Bevan
PostPosted: Fri Mar 08, 2013 10:33 am    Post subject: ATC slo blo? Reply with quote
At 12:01 PM 3/8/2013, you wrote:
Thanks Bob,
citation?
breaker.
Interesting. Thanks!
