RGray67968(at)aol.com Guest
Posted: Sun Jun 11, 2006 3:20 pm Post subject: VSI reads backwards |
Why would a VSI read backwards? There is only 1 port in the back of the VSI for connecting to the static source.
When the plane goes 'up' the VSI says it's descending and visa-versa.
Can this be repaired or reversed to read properly?
Thanks in advance,
Rick in Ohio at the Buffalo Farm
for the archives
alexpeterson(at)earthlink Guest
Posted: Sun Jun 11, 2006 3:36 pm Post subject: VSI reads backwards |
I think you need to fly below sea level. Or maybe inverted? I know, you need to fly in the southern hemisphere.
Seriously, it would seem to be mechanically mis-assembled, as it is hard to imagine what else would do it. If it were connected to the pitot, it would misbehave wildly, but not as you describe.
Alex Peterson
RV6-A N66AP 759 hours
Maple Grove, MN
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
| Quote: | From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RGray67968(at)aol.com
Sent: Sunday, June 11, 2006 6:16 PM
To: rv-list(at)matronics.com
Subject: VSI reads backwards
Thanks in advance,
for the archives
rv8(at)lazy8.net Guest
Posted: Sun Jun 11, 2006 3:52 pm Post subject: VSI reads backwards |
If the port is blocked, and the air pressure is changing within the body of the instrument...leak in the body or glass face.
jh
RGray67968(at)aol.com (RGray67968(at)aol.com) wrote: | Quote: | Why would a VSI read backwards? There is only 1 port in the back of the VSI for connecting to the static source.
Thanks in advance,
for the archives
Posted: Sun Jun 11, 2006 4:01 pm Post subject: VSI reads backwards |
Thanks in advance,
for the archives
| I'm going to tak. a wild guess. You've got the VSI hooked up to the static port. What's the answer???
Linn
Ed Anderson
Posted: Sun Jun 11, 2006 4:47 pm Post subject: VSI reads backwards |
Rick, I once had a VSI which about drove me crazy. Turns out I cracked the case when I installed it in the instrument panel which caused strange indications.
Ed
_________________ Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson@carolina.rr.com |
Posted: Sun Jun 11, 2006 6:21 pm Post subject: VSI reads backwards |
Again, this VSI doesn't behave erratically or give 'strange' indications......it's works as advertised....only it reads sdrawkcab (backwards).
[quote] Rick, I once had a VSI which about drove me crazy. Turns out I cracked the case when I installed it in the instrument panel which caused strange indications.
Ed
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Sun Jun 11, 2006 7:02 pm Post subject: VSI reads backwards |
Turn it 180 degrees in your panel!
Dale
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
truflite(at)yahoo.com Guest
Posted: Sun Jun 11, 2006 8:43 pm Post subject: VSI reads backwards |
You have to fly with the wheels side down and the
canopy side up for it to work properly.
Dave
Had the shot and took it:D
Thanks in advance,
for the archives
