jghrv6a(at)gmail.com Guest
Posted: Tue Mar 05, 2013 5:25 pm Post subject: RV6A Starter Contacter Problem |
Anybody had a problem with Van's Aircraft starter contactor ES 24021? It's reputed to be a Cole Hersee product designed to make and break 750 and 100 amps respectively using a 3-4 ohm coil. The original lasted about 100 hours before failing to provide12 volts to the "output terminal" when the starter switch triggered the internal connection for the high current terminals. This was confirmed by the sound of the moving "slug" and voltage measurements made at the "S" and both "high current" terminals. Hitting it with a hammer would make sometimes make it conduct properly but it eventually failed completely. Drilling out the rivets to inspect the contacts showed a mild discoloration and minimal overlap between the moving and fixed contacts but nothing else.
Now the replacement is doing the same thing after about 50 hours. An external diode protects the starter switch contacts. There has never been a problem with the pinion-ring gear engagement or disengagement, so the contactor is wired to the normal stud on the starter motor solenoid and the "jumper wire" was left in place. Any suggestions as to cause &/or solutions? Are there starter contractors that rotate the moving contact to even out wear etc.?
Jack H.
RV-6A
O-320 D1A with the standard Sky Tek
Posted: Tue Mar 05, 2013 7:38 pm Post subject: RV6A Starter Contacter Problem |
At 07:23 PM 3/5/2013, you wrote:
--> AeroElectric-List message posted by: Jack Haviland <jghrv6a(at)gmail.com>
That's a really old legacy design. Haven't really
heard of your situation before. Just for grins,
it would be interesting to try this style contactor.
They're about 40 years 'younger' in design than the
beer-barrel contactors. MUCH higher contact pressures.
[img]http://images.apwcontent.com/is/image/Autos/misw1951c_is?$[/img]
This form factor is common to several off the shelf
contactors you should be able pick up at a local
car-parts store.
Bob . . . [quote][b]
Posted: Wed Mar 06, 2013 4:03 am Post subject: RV6A Starter Contacter Problem |
On Mar 5, 2013, at 10:36 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | | Just for grins, it would be interesting to try this style contactor. They're about 40 years 'younger' in design than the beer-barrel contactors. MUCH higher contact pressures. |
Thanks Bob - I'll give it a try.
Jack H.
Posted: Wed Mar 06, 2013 6:47 am Post subject: RV6A Starter Contacter Problem |
At 06:01 AM 3/6/2013, you wrote:
| Quote: | On Mar 5, 2013, at 10:36 PM, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | Just for grins,
Thanks Bob - I'll give it a try. |
Great. Keep us apprised of your experience. Note
further that SOME off the shelf parts will have
a diode built in. If so, they'll probably say so
on the bottom with some words like "transient
protected", "diode installed", etc. If in doubt,
it doesn't hurt to install your own diode outside
the contactor. Two diodes is fine, no diodes is
really hard on your switch.
