Posted: Thu Mar 07, 2013 5:57 am Post subject: ELT antenna inside tube and fabric fuselage |
At 07:34 AM 3/7/2013, you wrote:
| Quote: | | They are, but according to posters on the J-sCub.com site Comm radio reception and transmit is very good with a dipole antenna from Advance Aircraft Electronics mounted inside. No one has addressed the ELT antenna but as I mentioned the ACK folks say installation inside of a (steel) tube and fabric fuselage will meet their criteria if the fabric is non-conductive. |
Interesting. I'm surprised that they would
climb out on that 'limb' unless their tests
for achieving TSO status included that
configuration . . . which I doubt.
Discussions like this are fraught with
the effects of variables that are unknown
and therefore cannot be part of the
deliberations. I do know that the uhf
signal is less likely to be severely
trashed by a surrounding, open mesh
'cage'. It would be interesting to
conduct some A-B experiments comparing
an internal antenna with an external
antenna with the assistance of some hams
having 70 cm radios and some rudimentary
tools for comparing signal strengths.
But suppose you deduced that for most
situations, the internal antenna was about
10 db down from the external one. Now what?
By what criteria is acceptability to be
judged? Without knowing the system's margins
for performance under various signal levels,
having such numbers doesn't go much beyond
'interesting'.
Be wary of advice that does not come from
someone who has access to applicable data
and knows how to interpret it. This applies
especially to individuals in the employ of
regulatory agencies who can exert power over
your activities.
The reports from fellow pilots about the
performance of internally mounted VHF antennas
is interesting. It's great if the installation
meets their communications needs. But their
observations are not quantified data. The
up side is that the physics is on your side.
The UHF feature on the modern ELT will be BETTER
disposed to adequate performance than the
VHF comm antenna.
The off-hand advice from folks without
numbers may NOT be on your side.
Bob . . . [quote][b]
klehman(at)albedo.net Guest
Posted: Thu Mar 07, 2013 7:50 am Post subject: ELT antenna inside tube and fabric fuselage |
An external antenna might reduce occupant exposure to additional RF
transmission energy if that is a concern to someone. Might also reduce
the rare RF caused instrumentation glitches that have been reported here.
Just a wild guess.
Ken
> fabric is non-conductive. **
'interesting'.
your activities.
VHF comm antenna.
Posted: Thu Mar 07, 2013 8:21 am Post subject: ELT antenna inside tube and fabric fuselage |
At 09:20 AM 3/7/2013, you wrote:
| Quote: | I'd mount all the antenna's outside. If there's enough aluminum in
the dope to protect the fabric from UV, it's going to be pretty
reflective of the RF from the radios. To much reflected power back
into the antenna can damage transmitters. Having your ELT inside, at
the very least, is going to reduce the range and make you harder to find.
The effects of suspended metal in aircraft
fabric finishes has been a point of debate
for years. It would be interesting to do some
experiments to explore real effects.
If anyone has the materials on hand to "finish"
an experimental enclosure (about the size of a
shoe box) as if it were a rag cover, I'd be
willing to use said enclosure to make some
shade tree measurements on radiation effects.
Further, having such a test article on hand
would offer an opportunity to do some lab
measurements at some time in the future wherein
I have access to the facilities.
If somebody can help produce the test enclosure,
drop me a note and let's discuss materials
and techniques. Thanks!
email(at)jaredyates.com Guest
Posted: Thu Mar 07, 2013 9:36 am Post subject: ELT antenna inside tube and fabric fuselage |
I have polyfiber leftovers to cover a box like that, and could use the opportunity as a covering demo/training for someone else.
On Mar 7, 2013, at 11:20, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
> I'd mount all the antenna's outside. If there's enough aluminum in the dope to protect the fabric from UV, it's going to be pretty reflective of the RF from the radios. To much reflected power back into the antenna can damage transmitters. Having your ELT inside, at the very least, is going to reduce the range and make you harder to find.
