Heated pitot
bruce1hwjohnson(at)yahoo.
PostPosted: Fri Mar 01, 2013 7:16 am    Post subject: Heated pitot Reply with quote
What is the consensus on the choice for heated pitot? I am getting close to paint and want to install before I do. Thanks
Bruce 151BJ
Strasnuts
PostPosted: Fri Mar 01, 2013 7:49 am    Post subject: Heated pitot Reply with quote
From personal experience I would not buy the Gretz again. The first one melted and the second one I have now is cracked. My panel has the labeling and holes drilled permenantly for the status lights so hard to change to a different pitot at this point.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
carl.froehlich(at)verizon
Dynon SkyView. You get a heated pitot and AOA in one – for the same price as just a heated pitot. If you’re not using SkyView EFIS, then never mind.
The mount however is applicable to other pitot options – so perhaps just picking the mount for now solves your “get to paint” issue. I suggest however painting the wings and mount separate. Dynon recommends a mount like the Gretz: http://www.aircraftspruce.com/pages/in/pitot_accessories/gretzbrackets.php
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bruce Johnson
Sent: Friday, March 01, 2013 10:14 AM
Subject: Heated pitot
Bruce 151BJ
[/b]
http://forums.matronics.com[/url] - List Contribution Web generous nbsp;   --> http://www.matronics.com/c=[/b] [/quote]
rleffler
PostPosted: Fri Mar 01, 2013 7:51 am    Post subject: Heated pitot Reply with quote
Gretz and dynon are probably the most popular. Both use the same mount, which is all you should need for paint.
On Mar 1, 2013, at 10:14 AM, Bruce Johnson <bruce1hwjohnson(at)yahoo.com (bruce1hwjohnson(at)yahoo.com)> wrote:
Bruce 151BJ
://www.matronics.com/Navigator?RV10-List
cs.com
matronics.com/contribution
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
PostPosted: Fri Mar 01, 2013 10:02 am    Post subject: Heated pitot Reply with quote
Thanks for the input, I will get the mount for paint. Just curious does the Gretz still work with the crack?
Sent: Friday, March 1, 2013 8:49 AM
Subject: Re: Heated pitot
Strasnuts
PostPosted: Fri Mar 01, 2013 10:17 am    Post subject: Heated pitot Reply with quote
So far it does work with the crack. I've used it probably ten times in 300 hours.
780 Hours
SuperSTOL 60 hours
jdriggs49(at)msn.com
PostPosted: Fri Mar 01, 2013 11:30 am    Post subject: Heated pitot Reply with quote
The Dynon unit works pretty well. I like the "smart" aspect of the heating unit. Besides its was cheaper.  Smile
Subject: Re: RV10-List: Heated pitot
Date: Fri, 1 Mar 2013 11:16:47 -0700
Dick Sipp
PostPosted: Fri Mar 01, 2013 11:41 am    Post subject: Heated pitot Reply with quote
No issues with Getz 460 hours.
Dick Sipp
Bruce 151BJ
Tim Olson
PostPosted: Fri Mar 01, 2013 12:03 pm    Post subject: Heated pitot Reply with quote
Me either. I wonder if they changed the plastics formula
or something strange. Sean, are they being good about support?
Will they send you another one? So far I'm planning to use
one again on the RV-14, unless I hear of lots of issues. I've
got the gretz mount for it already.
Tim Olson - RV-10 N104CD
Dick Sipp
*From:* Bruce Johnson <mailto:bruce1hwjohnson(at)yahoo.com>
*Sent:* Friday, March 01, 2013 10:14 AM
*To:* rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
*Subject:* Heated pitot
What is the consensuson the choice for heated pitot? I am getting close
Bruce 151BJ
Bob Turner
PostPosted: Fri Mar 01, 2013 1:44 pm    Post subject: Re: Heated pitot Reply with quote
I have the Dynon. Cannot say how well the heat works as I have never had the 10 in icing conditions. As mentioned it has a temperature controller so you can just leave it on all the time if you wish. I have a Dynon D6 as backup efis and, with the Dynon pitot, it provides a visual and audio angle of attack warning.
Bob Turner
RV-10 QB
Strasnuts
PostPosted: Sat Mar 02, 2013 8:01 am    Post subject: Heated pitot Reply with quote
Hey Tim,
I'm not going to replace unless it stops working. Stein replaced it last time it melted down. They had a bad batch. My new one is kind of a bad batch Smile
> Dick Sipp
> Bruce 151BJ
> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
> href="http://forums.matronics.com">http://forums.matronics.com
> href="http://www.matronics.com/contribution">http://www.matronics.com/c
780 Hours
SuperSTOL 60 hours
gengrumpy(at)aol.com
PostPosted: Sat Mar 02, 2013 8:23 am    Post subject: Heated pitot Reply with quote
Mine has been installed and working for 6 years, no problems to date.
grumpy
n184jm
On Mar 1, 2013, at 9:49 AM, Seano wrote:
[quote]From personal experience I would not buy the Gretz again. The first one melted and the second one I have now is cracked. My panel has the labeling and holes drilled permenantly for the status lights so hard to change to a different pitot at this point.
[quote]---
